1 Reply Latest reply on Jan 12, 2015 1:54 PM by Peferling
    Is anyone else having serious issues with Dynamically linked clip render times in CC 2014.2
    dv416 Level 1
      The timeline plays back fine over "normal" clips, then falls apart once it passes over a dynamically linked clip. And I don't just mean in the usual way (usually it stutters or freezes up). I mean, where even if you stop and pre render those clips, they don't render. Or rather, they take so long, that you won't actually let it finish because it's at a virtual standstill.
      I've noticed arbitrary little fixes, such as re-opening the after effects window, then going back into the premiere window causes the render to instantly speed back up in some cases.
      A restart of the program I believe solves the issue too. As does simply rendering the clip out in after effects.
      Anyone have any experience with issues like this?
      Running PP CC2014.2 on a tricked out 2011 Macbook pro 17" OSX Yosemite
