1 Reply Latest reply on Mar 8, 2007 10:18 AM by Newsgroup_User
    FLV streaming through PHP help
    infoVac
      First of all i know nothing of PHP, but after this incident i will teach myself.
      I found this link: http://www.flashcomguru.com/index.cfm/2005/11/2/Streaming-flv-video-via-PHP-take-two
      It shows you how to stream FLV's and use a scrub bar without using a streaming server using a PHP file. The problem is i dont know exactly what to do to make the PHP file work for me. I've tried a number of things but it wont work. please help me.
      PHP code given:
      security improved by by TRUI
      www.trui.net
      Originally posted at www.flashcomguru.com
      //full path to dir with video.
      $path = 'C:/.../clips/';
      $seekat = $_GET["position"];
      $filename = htmlspecialchars($_GET["file"]);
      $ext=strrchr($filename, ".");
      $file = $path . $filename;
      if((file_exists($file)) && ($ext==".flv") && (strlen($filename)>2) && (!eregi(basename($_SERVER['PHP_SELF']), $filename)) && (ereg('^[^./][^/]*$', $filename)))
      header("Content-Type: video/x-flv");
      if($seekat != 0) {
      print("FLV");
      print(pack('C', 1 ));
      print(pack('N', 9 ));
      $fh = fopen($file, "rb");
      fseek($fh, $seekat);
      while (!feof($fh)) {
      print (fread($fh, filesize($file)));
      fclose($fh);
      else
      print("ERORR: The file does not exist"); }
        • 1. Re: FLV streaming through PHP help
          Level 7
          Hi infoVac,
          what have you got so far?
          OTTOMH, you should query the php from the
          ns.play("......php?file=yada.flv&position=bitnumberofkeyframe")
          the thing is that the php streams the file in chunks to the flashplayer.
          The flv itself can only be played from a keyframe onwards so the php
          file needs to know:
          * which file
          * from which position (bit)
          the bit info on the keyframes can be aquired throu use of the FLVMDI
          from BURAKS ( http://www.buraks.com/flvmdi/)
          HTH
          Manno
          > I found this link:
          > -two
          > please help me.
          > PHP code given:
          > www.trui.net
          > $filename)))
          > if($seekat != 0) {
          > print("FLV");
          > fclose($fh);
          > else
          Manno Bult
          http://www.aloft.nl
          manno@xs4all.nl
