quote:
-server -Dsun.io.useCanonCaches=false -Xbootclasspath/a:"{application.home}/../lib/webchartsJava2D.jar" -Djavax.xml.parsers.SAXParserFactory=com.macromedia.crimson.jaxp.SAXParserFactoryImpl -Djavax.xml.parsers.DocumentBuilderFactory=com.macromedia.crimson.jaxp.DocumentBuilderFactoryImpl -XX:NewSize=64m -XX:PermSize=32m -XX:MaxPermSize=128m -XX:+UseConcMarkSweepGC -XX:+DisableExplicitGC
quote:
Symptom: CPU spins at 100% - and high memory usage - about every hour after startup (large memory use too).
Here's a common one that some fall into going from development to production. The default for storing client variables is "REGISTRY". Once the number of records in the registry is large, the query to get all records and delete expired client records can take 100% CPU for minutes at a time.
Registry client storage should never be used for production systems but often developers fall into this by accident by not explicitly specifying a data source (and the ColdFusion admin defaulting to "REGISTRY"). Since the registry isn't a real database, ColdFusion has to retrieve the entire registry client tree (high memory usage) and compare the date/time one at a time to decide whether to purge a record. This is a CPU-intensive operation with an hourly purge that may only delete a few records.
Since this is a system task, it's running in a scheduler thread instead of a jrpp thread. Here's a case where a scheduler thread is relevant.
