8 Replies Latest reply on Sep 8, 2018 11:42 AM by gkaiseril
    Custom Calculation Script Help
    MzHeather Level 1
      I am in need of the correct calculation script in order to complete:
      I am making an evaluation form. This form contains several columns that indicate a point system. Column 1 = 1 point, Column 2 = 2 points, etc.
      I need to be able to have a user mark an "X" in each form field and have the value predetermined depending on which column they marked the "X" in. Example: They mark an "X" in one of the form fields in Column 2, that form field should then have a value of 2 and be inputted into the Sub Total form field. Then I will need all of the values totaled and added into each Sub Total field for each column. Can someone please provide the calculation script to enable this to happen?
