1 Reply Latest reply on Jan 21, 2015 11:16 AM by TrentHappel
    Render and Replace Different Format In Same Sequence
    arti post
      Is there any way to keep the Interpret Footage settings after make Render and Replace option?
      I have a sequence setting in 1080 50p with two different formats  50p 720 (interpret in 25p) / 1080 25p, I did a render and replace of the total. And the result was that the rendered footage doesn´t  respect me the interpret settings.
      Thanks.
        • 1. Re: Render and Replace Different Format In Same Sequence
          TrentHappel Adobe Employee
          Render and Replace is currently designed to transcode the clip and keep the Interpret Footage settings applied to the clip (not burned/rendered in). There is a feature request to burn/render in Interpret Footage (and other effects) to the transcoded clip.
          Not ideal, but a possible workaround would be to export the clips with "Import into project" selected in Export Settings, then Replace with Clip to get your desired outcome.
