2 Replies Latest reply on Jan 19, 2015 7:52 AM by TheCycoONE
    org.apache.axis2.AxisFault: com.ctc.wstx.exc.WstxIOException: Attempted read on closed stream. on local .NET webservice
    TheCycoONE Level 1
      To facilitate code sharing between ColdFusion and our .NET applications we have a .NET webservice running through IIS on localhost.
      Occasionally, under what appears to be high or persistent load, this connection errors out, which it didn't do with ColdFusion 9.  Is there something I can change on either the service or the in ColdFusion to prevent this from coming up?
      Note that the service uses basicHttpBinding (<basicHttpBinding>) .  It is listening to localhost on port 8888, and is not https.
      The fault returned when invoking the web service operation is:
      at org.apache.axis2.AxisFault.makeFault(AxisFault.java:430)
      at org.apache.axis2.transport.TransportUtils.createSOAPMessage(TransportUtils.java:124)
      at org.apache.axis2.transport.TransportUtils.createSOAPMessage(TransportUtils.java:68)
      at org.apache.axis2.description.OutInAxisOperationClient.handleResponse(OutInAxisOperation.j ava:354)
      at org.apache.axis2.description.OutInAxisOperationClient.send(OutInAxisOperation.java:421)
      at org.apache.axis2.description.OutInAxisOperationClient.executeImpl(OutInAxisOperation.java :229)
      at org.apache.axis2.client.OperationClient.execute(OperationClient.java:165)
      at org.tempuri.ErmsInternalStub.textToSpeech(ErmsInternalStub.java:828)
      at sun.reflect.GeneratedMethodAccessor46.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
      at java.lang.reflect.Method.invoke(Method.java:606) at coldfusion.xml.rpc.Axis... ''
