4 Replies Latest reply on Jan 16, 2015 5:24 AM by Peter Spier
    Hanging when open Files
    KontrastCC
      Hi community,
      I’m using Mac OS X 10.9.5 with InDesign CC 9.2.2.
      When open files (local or network) in InDesign the CPU Usage increase to 100% and will start to hanging after 5-6 documents.
      Can anyone confirm the problem or has a solution?
        • 1. Re: Hanging when open Files
          Doc Maik Level 4
          I can confirm this behaviour, but it is (usually) not a problem and has a pretty normal reason.
          Does this also happen with other software and files from the HDD/network?
          Did it happen before, like it was always this way, or just recently? If so, what did you change?
          Will the 100% CPU usage remain or sink after the file is completely loaded?
          "After (opening) 5-6 documents" means opened "all at once" or "subsequent"? If all at once, how much RAM do you have and is there enough space left on the HDD for cache?
          Is preflight activated?
          Do the documents have broken cross-refs to other documents?
          What means "hanging"? Hanging like "for a while" or like "forever"?
          • 2. Re: Hanging when open Files
            KontrastCC Level 1
            Sorry my misstake.
            InDesign will hang while open file permanent and can't open file really. i was waiting more then 30 minutes and nothing happen (CPU everytime 100%)
            with after 5-6 documents i mean they was open normal.
            • 3. Re: Hanging when open Files
              Doc Maik Level 4
              Yes, but still, 5-6 documents with one open each time or all 6 open at once? If latter, then it could have run out of memory.
              • 4. Re: Hanging when open Files
                Particularly if the user never does a Save As to remove useless change information in files that have been edited many times.
