1 Reply Latest reply on Mar 2, 2007 7:11 AM by MotionMaker
    Size Limit of FLV Video?
      Can a FLV video w/ a frame size of 800x450 reliably play off of a CD-ROM? (It has a simple voiceover audio track, and will be around 5 minutes long. The FLV will be embedded in an 800x600 flash movie.)
        • 1. Re: Size Limit of FLV Video?
          MotionMaker Level 1
          Should be doable.
          Depends on:
          1. Performance of the playback computer.
          2. The encoding compression selected for FLV also impacted by how much changes in the video
          The bottom line is you simply should test this. Use the Flash 8 encoder to encode under best and worst two 5 minute digital video files.
          Open Flash 8 pro, drop in the FLVPlayer component, publish as projector, burn projector and flv and test it.
