4 Replies Latest reply on Jul 21, 2015 1:12 PM by mrtorrent
    keyframes don't work on adjustment layer
    maayanb Level 1
      hi,
      i'm trying to put camera blur on adjustment layer and animate the position with keyframes but it doesn't work...
      somebody knows why?
      thank you!
      maayan
        • 1. Re: keyframes don't work on adjustment layer
          Kevin-Monahan Adobe Employee
          Hi Maayanb,
          somebody knows why?
          It's working perfectly for me. Can you describe your process so we can better help you?
          Kevin
          • 2. Re: keyframes don't work on adjustment layer
            maayanb Level 1
            Hi Kevin,
            Thank you for your quick respond
            I'm creating a new adjustment layer and apply camera blur on it
            now i'm trying to move the layer from right to left using position keyframes
            when i put a keyframe the layer "does't want" to move
            the numbers in the position effect control are moving but the layer does not.
            i tried to do the same in after effects and it works perfectly but i need it in my premiere project...
            thank you
            maayan
            • 3. Re: keyframes don't work on adjustment layer
              DrewPost Level 1
              Hi Kevin, seeing similar behavior here. CC (2014) Mac, 10.8.5, 1080p/23.976 sequence with ProRes MOV clips.
              I was trying to create a custom transition this way (dip to color w/ blur), that I could drop on a track above footage. I needed this transition in a bunch of places in the edit, so building it into the V1 clips didn't make sense.
              Doesn't work. As soon as I applied keyframes to parameters in Fast Blur, Levels, or the core Opacity value, the effect broke - Premiere ignored the keyframes and their values. As soon as I deleted the keyframes it behaved again.
              It's also impossible to apply a transition (such as Cross Dissolve) to an adjustment layer: it disables its transparency (and therefore its impact on anything beneath it).
              Since it was a short 6-frame transition, I ended up splitting the adjustment layer into 6 single-frame adjustment layer clips, and manually putting in non-keyframed values in each. That worked.
              • 4. Re: keyframes don't work on adjustment layer
                mrtorrent Level 1
                I ran into the same issue on CC 2015 a couple weeks ago. They always tell everybody to send in a bug report, so make sure you do that: Feature Request/Bug Report Form
