1 Reply Latest reply on Jan 15, 2015 1:38 PM by A.T. Romano
    Using Safe Margins in PE11 Video Clips
    andrew-dd_1937 Level 1
      1. Is it possible to manually resize a video clip in Premiere Elements 11 so that it fits inside the safe margin frame?  If so how do I do this?
      2. Also, is it possible to get rid of video clips' black side bars in PE!!?  If so how how do I do this?
      Thank you,
        • 1. Re: Using Safe Margins in PE11 Video Clips
          A.T. Romano Level 7
          What computer operating system is your Premiere Elements 11 running?
          1. With the Safety Margins on in the Edit area monitor and the video clip selected, scale the image in the monitor to fit the area of interest.
          Scaling can be done by clicking on the monitor to bring up the image's bounding box and then dragging on one of the handles of the bounding
          box for the scaling.
          Tip: Depending on the specification of your TV, you can alter the Safety Margins in Edit Menu/Project Settings/General targeting
          Title Safe Area
          Action Safe Area
          Also, in Applied Effects Tab/Applied Effects Palette/Motion Panel expanded, you can uncheck the option Constrain Proportion so that
          you can scale width and height separately.
          Scaling can also be done by selecting the Timeline clip and then using the Scale Slider found Applied Effects Tab/Applied Effects Palette/Motion
          Panel expanded and its Scale property.
          Where are you seeing these black border in Premiere Elements....?
          When you first drag your import to the Expert workspace Timeline or some place else. If at export, then you (manually) or the project
          (automatically) have not set the correct project preset to match the properties of the source media. So, more information on what is
          happening here.
          Please let me know if I have interpreted your questions correctly. If not, please more details.
