1 Reply Latest reply on Jan 16, 2015 4:05 PM by duanlook
    how rename  and sort spot channel by javascript?
    duanlook Level 1
      The name of a spot color channel is English letters or numbers.such aschannel is  a1 ,b3, ce, hh, ....or  vc, bg, kk, 1, 2, 3.....etc,.The spot color channel name,renamed in 1, 2, 3...
      exmple:
      1.
      spot channel name  a1 change to 1
      spot channel name   b3 change to 2
      spot channel name   ce change to 3
      spot channel name   hh change to 4
      2.
      spot channel name   vc   change to  1
      spot channel name   bg  change to   2
      spot channel name   kk  change to   3
      spot channel name   1   change to   4
      spot channel name   2   change to   5
      spot channel name   3   change to   6
        • 1. Re: how rename  and sort spot channel by javascript?
          duanlook Level 1
          i try to change by Getting Channel Information
          thx Michael L Hale
          change to:
          function getProperty( psClass, psKey, index ){// integer:Class, integer:key
              var ref = new ActionReference();
              if( psKey != undefined ) ref.putProperty( charIDToTypeID( "Prpr" ), psKey );
              if(index != undefined ){
                  ref.putIndex( psClass, index );
              }else{
                  ref.putEnumerated( psClass , charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ) );
              try{
                  var desc = executeActionGet(ref);
              }catch(e){ return; }// return on error
              if(desc.count == 0) return;// return undefined if property doesn't exists
              var dataType = desc.getType(psKey);
              switch(dataType){// not all types supported - returns undefined if not supported
                  case DescValueType.INTEGERTYPE:
                      return desc.getInteger(psKey);
                      break;
                  case DescValueType.ALIASTYPE:
                      return desc.getPath(psKey);
                      break;
                  case DescValueType.BOOLEANTYPE:
                      return desc.getBoolean(psKey);
                      break;
                      break;
                  case DescValueType.UNITDOUBLE:
                      return desc.getUnitDoubleValue(psKey);
                      break;
                  case DescValueType.STRINGTYPE:
                      return desc.getString(psKey);
                      break;
                  case  DescValueType.OBJECTTYPE:
                      return desc.getObjectValue(psKey);
                      break;
                  case  DescValueType.LISTTYPE:
                      return desc.getList(psKey);
                      break;
                  case  DescValueType.ENUMERATEDTYPE:
                      return desc.getEnumerationValue(psKey);
                      break;
          var channelCount = app.activeDocument.channels.length;
          var channelNames = [];
          for(var channelIndex=1;channelIndex<=channelCount;channelIndex++){
              var channelNames =getProperty(charIDToTypeID("Chnl"),charIDToTypeID("ChnN"),channelIndex);
          if(channelIndex==1){
          else if(channelIndex==2){
          else if(channelIndex==3){
          else if(channelIndex==4){
          else if(channelIndex>=5){
          var idslct = charIDToTypeID( "slct" );
              var desc329 = new ActionDescriptor();
              var idnull = charIDToTypeID( "null" );
                  var ref246 = new ActionReference();
                  var idChnl = charIDToTypeID( "Chnl" );
                  ref246.putName( idChnl, ""+channelNames);
              desc329.putReference( idnull, ref246 );
          executeAction( idslct, desc329, DialogModes.NO );
          var idsetd = charIDToTypeID( "setd" );
              var desc330 = new ActionDescriptor();
                  var ref247 = new ActionReference();
                  var idOrdn = charIDToTypeID( "Ordn" );
                  var idTrgt = charIDToTypeID( "Trgt" );
                  ref247.putEnumerated( idChnl, idOrdn, idTrgt );
              desc330.putReference( idnull, ref247 );
              var idT = charIDToTypeID( "T   " );
                  var desc331 = new ActionDescriptor();
                  var idNm = charIDToTypeID( "Nm  " );
                  desc331.putString( idNm, """"""+channelIndex-4 );
              var idSCch = charIDToTypeID( "SCch" );
              desc330.putObject( idT, idSCch, desc331 );
          executeAction( idsetd, desc330, DialogModes.NO );
          if spot channel name is number such as spot channel sequence: 2,1,3,6,8,9...can't success!...other success!
