1 Reply Latest reply on Jan 16, 2015 3:14 AM by Rick Gerard
    Adding to Media Encoder Render Queue Failure
      Hey guys,
      So every time I attempt to add my composition to the render queue (media encoder) it always just results in my AE crashing and it does not get exported to Media Encoder. Any solutions to this?
        • 1. Re: Adding to Media Encoder Render Queue Failure
          No idea why because I don't know anything about your OS or your version of AE or your project. Try this. Create a new AE project that is 8 bit. Create a new standard HD comp that is 10 seconds long. Add a shape layer or a text layer or a solid to the project. Save your project and then see if you can add it to the AME. If you can, then there's something in your composition that is causing the problem and you need to give us a complete description of what is in the composition. The easiest way to do that is select all of the layers in your timeline and press the U key twice to reveal all changed properties or added effects. Then post a screenshot. If you project contains pre-comps then a flow chart and the timelines from he nested comps will also help.
