0 Replies Latest reply on Jan 16, 2015 1:08 AM by GJ du Toit
    Tagged text: index number style override not imported (ID CS6)
    GJ du Toit Level 1
      I want to import InDesign tagged text documents that contain index markers, some of which use number style overrides. (If "number style override" doesn't ring a bell, see the note at the bottom.)
      To check the correct tagging, I exported sample text containing index entries with number style overrides to tagged text. The following tag is inserted into the entry: <IdxEnStyle:RangeBeg> (in this case for a style called RangeBeg).
      However, if I re-import that same unaltered  text back into InDesign, the number style overrides disappear.
      How can I tag it so that the number style override will be imported?
      Number style override
      It's the option in the index entry dialog whereby you can assign a character style to particular page references, for instance to have references to pictures underlined, e.g.:
      which can then give you something like:
      Dogs
        boxer, 12, 13, 16
