5 Replies Latest reply on Jan 17, 2015 10:17 AM by A.T. Romano
    dvd di foto fatto con premiere 11 e uscito malissimo, foto quasi doppie, perchè?
    renator97884597
      Buongiorno, ho fatto ieri un dvd di foto con Premiere 11, e...speravo uscisse meglio...bello perché si possono mettere dei pezzetti di musica ma, come foto, viste dopo sul televisore, proprio brutte, si vedono male, perché ?       ci vogliono foto più pesanti per farle uscire bene o il contrario, più leggere ?           grazie dell'interessamento    cordiali saluti         Renato
        • 1. Re: dvd di foto fatto con premiere 11 e uscito malissimo, foto quasi doppie, perchè?
          A.T. Romano Level 7
          renator
          The translate button here is not working. The following is the translation from Google Translate
          Good morning, I made yesterday a DVD of photos with Premiere 11, and ... I was hoping to come out better ... nice because you can put the pieces of music but, like photos, views later on the TV, just ugly, you see evil, because ? takes photos heavier for them out good or not, lighter? because of the interest best regards Renato
          What computer operating system is your Premiere Elements running on?
          Many factors influence what you see when viewing your Premiere Elements DVD-VIDEO on DVD disc
          1. Expectations. Even if your original photos have high pixel dimensions (way over 1920 x 1080 pixels), the resolution of the final product will be determined by the specifications of the end product format. For PAL DVD-VIDEO on DVD disc
          a. 720 x 576 pixels, standard 4:3
          b. 720 x 576 pixels, widescreen 16 (16:9 flag stretches the image for display to 1056 x 576 pixels after encoding)
          Are you doing DVD-VIDEO on DVD disc or AVCHD format on DVD disc? The AVCHD format on DVD disc will allow for the 1920 x 1080 pixels display.
          2. Project Setup.
          a. What project preset are you (manually) or the program (automatically) setting to match the properties of the source media?
          For the sharpest results, if applicable, use 1920 x 1080 photos imported into a project with the manually set preset of
          PAL\DSLR\1080p\DSLR 1080p25
          b What are the pixel dimensions of the photos that you have imported into the project and how many photos?
          c. What is the end product PAL DVD-VIDEO standard or widescreen on DVD disc or other?
          Please review and consider. Lots more to discuss. If any questions or need clarification, please do not hesitate to ask.
          Thank you.
          ATR
          • 2. Re: dvd di foto fatto con premiere 11 e uscito malissimo, foto quasi doppie, perchè?
            renator97884597 Level 1
            Buongiorno, grazie della risposta, il sistema operativo è Windows 8.1 e fatto un DVD-VIDEO PAL widescreen per essere visto su tv...le foto erano 663 da 1 a 3 MB per foto...     grazie delle informazioni       saluti       Renato
            • 3. Re: dvd di foto fatto con premiere 11 e uscito malissimo, foto quasi doppie, perchè?
              A.T. Romano Level 7
              renator
              Premiere Elements 11 on Windows 8.1 (assumed 64 bit)....
              Thanks for the reply. Could you tell us what the pixel dimensions of the photos were (width and height in pixels)?
              for Originals ______?
              for Photos that were actually imported into the project ______?
              How much larger than 1920 x 1080 pixels were they?
              Also, how many of them were put into your project? And, what was the project preset that you (manually) or the project (automatically) set. This information is important
              to define the project setup which can markedly influence the end result.
              If you do not know the project preset for the project, please tell us what you read for Editing Mode, Timebase, Frame Size, and Pixel Aspect ration under Edit Menu, Timebase, Frame Size, and Pixel Aspect Ratio, even if the fields look grayed out.
              Thanks. Looking forward for helping you get the better quality slideshow that you seek.
              ATR
              • 4. Re: dvd di foto fatto con premiere 11 e uscito malissimo, foto quasi doppie, perchè?
                Grazie, mi sa che effettivamente ho esagerato come dimensioni...   il sistema operativo è Windows 8.1 a 64 bit, esatto, e le foto, guardando i pixel, sono per la maggior parte, da 4000 x 3000 pixel, 663 foto per una durata di 1 ora e 10 minuti sul DVD...      devo diminuire i pixel o farlo in formato AVCHD sempre su DVD ?              grazie            saluti      Renato
                • 5. Re: dvd di foto fatto con premiere 11 e uscito malissimo, foto quasi doppie, perchè?
                  A.T. Romano Level 7
                  Renato
                  Thanks for the follow up with important details of your Premiere Elements workflow. Definitely too great a photo resolution for that number of photos. Your computer resources will define just how much you can get away with before you see negative consequences to the project.
                  1. Consider, crop/resize your photos to 1920 x 1080 16:9
                  2. Import the 1920 x 1080 16:9 into a project with a manually set project preset of
                  PAL
                  DSLR
                  1080p
                  DSLR 1080p25
                  3. When you get to export...
                  a. if you want DVD-VIDEO on DVD disc, use the preset PAL_Widescreen_Dolby DVD
                  b. if you want AVCHD on DVD disc, use the preset H.264 1920 x 1080i PAL Dolby
                  But, keep in mind, that the AVCHD on DVD disc will not play back on the ordinary DVD player. It needs a Blu-ray player or one of those multi format type players.
                  Please let us know if any of the above improved your Premiere Elements workflows. Any questions or need clarification on the above, please do not hesitate to ask.
                  Thank you.
                  ATR
                  Add On...details of manually setting project preset can be found
                  ATR Premiere Elements Troubleshooting: PE11: Accuracy of Automatic Project Preset (New Project Dialog) Setting
