9 Replies Latest reply on Jan 18, 2015 1:43 AM by Test Screen Name
    ID Export PDF/EPS page size problems
      Hello InDesigners,
      I have set up a document with the following properties 265mm x 375mm (no bleed or slug), as may be seen in the pictures below. However, when exported to PDF or EPS the page size reduces a little bit (see third picture). Is there any way to fix this and export exact page sizes? I am using InDesign CS6 - v8.0.2.
      Thank you in advance for your assistance.
      P.S. The same problem also occurs for standard paper sizes such as A4 and A3.
      ID Doc Setup.png (ID Doc Settings)
      ID Paper size.png(EPS Size when opened in Illustrator)
      ACRO properties.png (Acrobat properties for exported PDF)
