2 Replies Latest reply on Feb 27, 2007 4:19 AM by MergeThis
    what is PSS file?
      I am tyring to get into my database however, it is giving me error massage "xxx.pss" files checked out to some other user. what should I do? every time I want to use this database I have go as admin and undo the check out and login again.
        • 1. what is PSS file?
          Sounds like you have used the command File > Get Folders from within RoboSource Control Explorer to insert your project into the database. This adds the files .pss, .cpd, and possibly .ldb, but these files must not be part of the database.
          Your best bet is opening the database again using RoboSource Control Explorer and deleting these files from it. After performing a Get All from within RSE, your problems should be vanished.
          Oh, and in the future allway use the Add to Source Control command from within RoboHelp Office to add a project to your source control system.
          ---Dirk Bock
          • 2. Re: what is PSS file?
            MergeThis Level 4
            In addition to the three files mentioned by Dirk, keep the .hhp file out of source control, as well. To recap, the files to eliminate are .cpd, .hhp, .ldb, and .pss.
