Neal,
Here is the command that you need to use to compile java
classes. I should have mentioned that before as you need to include
few jar's in the command itself
javac -deprecation -classpath
C:/CFusionMX7/lib/axis.jar;C:/CFusionMX7/lib/xml-apis.jar;C:/CFusionMX7/lib/saaj.jar;C:/CFusionMX7//lib/jaxrpc.jar;.
[path_to_java_folder]/*.java
So, in details, you need to specify -deprecation parameter
and then classpath and include 3 libraries separated by
semicolons(;). At the end you have to pot dot (.) and then provide
path to your java files. You have to repeat this for all your
folders that have been created in step 1. As you can see, among
included jars there is axis.jar file, so that should solve all your
errors.
Let me know how it goes.
