3 Replies Latest reply on Jan 18, 2015 9:00 PM by Sajeev Sridharan
    How do i parse a csv into my inDesign script?
    sierraoscardelta
      hi there, having real trouble with this:
      // target the latest version of InDesign
      #target "InDesign-10"
      // This will parse a delimited string into an array of
      // arrays. The default delimiter is the comma, but this
      // can be overriden in the second argument.
      // http://www.bennadel.com/blog/1504-ask-ben-parsing-csv-strings-with-javascript-exec-regular -expression-command.htm
      function CSVToArray( strData, strDelimiter ){
          // Check to see if the delimiter is defined. If not,
          // then default to comma.
          strDelimiter = (strDelimiter || ",");
          // Create a regular expression to parse the CSV values.
          var objPattern = new RegExp(
                  // Delimiters.
                  "(\\" + strDelimiter + "|\\r?\\n|\\r|^)" +
                      // Quoted fields.
                      // Standard fields.
                      "([^\"\\" + strDelimiter + "\\r\\n]*))"
              "gi"
          // Create an array to hold our data. Give the array
          // a default empty first row.
          var arrData = [[]];
          // Create an array to hold our individual pattern
          // matching groups.
          var arrMatches = null;
          // Keep looping over the regular expression matches
          // until we can no longer find a match.
          while (arrMatches = objPattern.exec( strData )){
              // Get the delimiter that was found.
              var strMatchedDelimiter = arrMatches[ 1 ];
              // Check to see if the given delimiter has a length
              // (is not the start of string) and if it matches
              // field delimiter. If id does not, then we know
              // that this delimiter is a row delimiter.
              if (
                  strMatchedDelimiter.length &&
                      (strMatchedDelimiter != strDelimiter)
                  // Since we have reached a new row of data,
                  // add an empty row to our data array.
                  arrData.push( [] );
              // Now that we have our delimiter out of the way,
              // let's check to see which kind of value we
              // captured (quoted or unquoted).
              if (arrMatches[ 2 ]){
                  // We found a quoted value. When we capture
                  // this value, unescape any double quotes.
                  var strMatchedValue = arrMatches[ 2 ].replace(
                      new RegExp( "\"\"", "g" ),
              } else {
                  // We found a non-quoted value.
                  var strMatchedValue = arrMatches[ 3 ];
              // Now that we have our value string, let's add
              // it to the data array.
              arrData[ arrData.length - 1 ].push( strMatchedValue );
          // Return the parsed data.
          return( arrData );
      // read source file
      var csv = CSVToArray(File("../data/source.csv"), ",");
      // create new document using specified presets
      var myDocument              = app.documents.add();
      var myTextFrame             = myDocument.pages.item(0).textFrames.add();
      myTextFrame.geometricBounds =  ["6p", "6p", "24p", "24p"];
      myTextFrame.contents        = "// this is where i want to pull a value from a specific cell within the csv.  I will have multiple TextFrames in the final script but want to see proof of concept before complicating further"
