2 Replies Latest reply on Jan 23, 2015 6:24 AM by Loic.Aigon
    Export data from Indesign to Mysql
    vishnuw29597582
      I have an indesign file. I can open the indesign file in adobe in design. This can export the full xml for the created indesign.
      Now what i need is from Indesign i need to export contents directly to my sql database by giving field mapping for title description.
      Do we have any plugin in indesign to map the tables and insert it directly from indesign.
      Can we insert images in this format from the indesign file. Which format will the image be sorted image.
      Physical image file will be copied and path can be modified or these images are copied as bits in database.
      Do we have to have the same image location shared as indesign files and images will be on a different server and the website which is working on database will be on a different server.
