1 Reply Latest reply on Jan 19, 2015 2:55 PM by A.T. Romano
    problem combining project files
    sdfasdfqsdfasdf
      I have made several PE 13 NTSC Wide projects. I use the Publish + Share:Computer: AVI:DV?NTSC Wide to produce the output file.
      I import these files into the master project.
      When I burn DVD for each individual file they come out beautiful.
      When I burn a DVD with the combined files the images flicker terribly!
      For each Project is set the setting to D1/DV NTSC Wide
      When I burn the individual project I use NTSC Widescreen. The individual project DVD looks great
      When I combine files then the DVD flickers?!
      HELP!!
        • 1. Re: problem combining project files
          A.T. Romano Level 7
          sdfasdfqsdfasdf
          Given that your export products from each of the individual projects is NTSC DV.AVI widescreen from Publish+Share/Computer/AVI with Presets = DV NTSC Widescreen.
          When you went into the final project, what was your project preset? Did you let the project set it automatically based on the properties of the first file dragged to the Expert workspace Timeline or did you set the project preset manually (File Menu/New/Project)?
          Please tell us what you see for Editing Mode, Timebase, Frame Size, Pixel Aspect Ratio found under Edit Menu/Project Settings/General of the grand project from which all these individual .avi files were burned to DVD-VIDEO on DVD disc?
          Thank you.
          ATR
