1 Reply Latest reply on Jan 19, 2015 1:17 PM by Kevin-Monahan
    i have been getting the wierdest, most ridiculous issues using PP 2014 here is a list:
    deadvessel Level 1
      i have been getting the wierdest, most ridiculous issues using PP , 2014 here is a list:
      unsyncing single-source a/v when aplying effects.
      exporting the resynced clip to an even more out-of-sync clip
      freeze frame. when applying stabilizer, clip will just stall on a frame whereas before the effect, it didn't
      losing 2-3 hours of work due to auto-save failure. quitting premiere like normal but still having to force quit
      ramdom green frames that just suddenly appear
      constant crashing
      crashing without auto saving
      severe artifacting
      timeline, source, project thumbnails won't play
      toggle to previous/next edit point won't work
      significant, work-hidering issues in 90% of my project that collegues have never heard of
      pefferences will suddenly change. auto-save set to every 5 minutes and 100 versions will reset to default and audio scrubbing has just turned off
      no video, sound only during playback. freeze framing during playback
      pasting an item other than what was copied. copied a mask, pasted and mask of diferent size and shape
      inserting single frames between clips that i didn't add
      mixing unused video during transitions
      mixing unused video into masks.
      the above image is a mask that is being distorted by the image on the left below but it is only occuring in the mask.
      media pending sceen remains long after all content is loaded
      artifacting in the form of green pixel fields after exporting
      these issues are seriously hindering my ability to work. failed solutions i have run thru are:
      closing and reopening PP
      deleting render files and re-rendering
      replacing the distored clip with a  fresh clip
      rebuilding the mask
      restarting my computer
      PRAM and smc resets
      uninstalling and re-installing PP
      what is going on???
