11 Replies Latest reply on May 10, 2015 5:23 PM by AFCathaCA
    Uncaught exception error
    dhmiller Level 1
      Brand new iMac 27' retina, Yosemite (10.10.1), AE Cs2014 (13.2). I got the following error, which crashed AE:
      Application Specific Information:
      *** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: 'Couldn't posix_spawn: error 35'
      terminating with uncaught exception of type NSException
      abort() called
      Any clues?
      32 GB RAM
      etc
        • 1. Re: Uncaught exception error
          dhmiller Level 1
          Just got a similar error with PS 2014. New machine, didn't expect these issues (so frustrating):
          Crashed Thread:        0  Dispatch queue: com.apple.main-thread
          PS crash:
          Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
          Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000008
          VM Regions Near 0x8:
              __TEXT                 000000010c1e6000-0000000110ac3000 [ 72.9M] r-x/rwx SM=COW  /Applications/Adobe Photoshop CC 2014/Adobe Photoshop CC 2014.app/Contents/MacOS/Adobe Photoshop CC 2014
          • 2. Re: Uncaught exception error
            dhmiller Level 1
            Here's the start of the error message from AE:
            Process:               After Effects [10529]
            Path:                  /Applications/Adobe After Effects CC 2014/Adobe After Effects CC 2014.app/Contents/MacOS/After Effects
            Identifier:            com.adobe.AfterEffects
            Version:               13.2 (13.2)
            Code Type:             X86-64 (Native)
            Parent Process:        ??? [1]
            Responsible:           After Effects [10529]
            User ID:               502
            Date/Time:             2015-01-19 20:54:25.151 -0500
            OS Version:            Mac OS X 10.10 (14A389)
            Report Version:        11
            Anonymous UUID:        0CFE6B21-BDC2-3E0B-5FA5-E28E6DDBFE19
            Sleep/Wake UUID:       FFB2C0D6-87FF-4E0F-86A8-9520972E9543
            Time Awake Since Boot: 140000 seconds
            Time Since Wake:       20000 seconds
            Crashed Thread:        33
            Exception Type:        EXC_CRASH (SIGABRT)
            Exception Codes:       0x0000000000000000, 0x0000000000000000
            • 3. Re: Uncaught exception error
              CoSA_DaveS Adobe Employee
              I also just received a "NSInternalInconsistencyException Couldn't posix_spawn: error 35" in my system console when an app I was debugging (not AE) crashed. It's a low-level OS error. Here's an example of an unrelated app running into the same problem: Sequel Pro Crash Logs - Viewing Log For Issue #1717. I found that once I was in this state, I couldn't even create a new Terminal window without it failing in a strange way. The console started filling with errors. Rebooting fixed it. If anyone has any ideas what causes this state, please post.
              I too am on 10.10.1, using a 16GB Mac Book Pro Retina.
              Error 35 is apparently this:
              #define EAGAIN 35  /* Resource temporarily unavailable */
              And indeed that was the error reported by Terminal when I tried to create a new shell. Not that it helps much.
              • 4. Re: Uncaught exception error
                dhmiller Level 1
                Same here - could;t run Terminal. Had to reboot. Have had similar problems now with all 3 Adobe apps I use daily - LR, AE and PS.
                what a drag.
                other issues trying to render some UHD frames in AME.
                • 5. Re: Uncaught exception error
                  If anyone else runs into the "Couldn't posix_spawn: error 35", please post a description of your OS version and what you were doing. Maybe we can figure this out with more data.
                  -DaveS
                  • 6. Re: Uncaught exception error
                    KiersM Level 1
                    I'm getting it in Indesign - just trying to start it up, albeit after a hang/crash. OSX Mavericks, Indesign CC 2014.
                    First chunk of the log is as follows (Can send whole thing if you'd like):
                    Process:         Adobe InDesign CC 2014 [9360]
                    Path:            /Applications/Adobe InDesign CC 2014/Adobe InDesign CC 2014.app/Contents/MacOS/Adobe InDesign CC 2014
                    Identifier:      com.adobe.InDesign
                    Version:         10.1.0.71 (10100)
                    Parent Process:  launchd [1166]
                    Responsible:     Adobe InDesign CC 2014 [9360]
                    User ID:         501
                    Date/Time:       2015-01-23 11:31:42.140 +0000
                    OS Version:      Mac OS X 10.9.5 (13F34)
                    Report Version:  11
                    Anonymous UUID:  9970510D-4662-013A-6348-EAA44C4BCFA9
                    Sleep/Wake UUID: E31868CA-2579-43E6-8D8E-75269427EDEB
                    abort() called
                    Application Specific Backtrace 1:
                    0   CoreFoundation                      0x00007fff8cd1325c __exceptionPreprocess + 172
                    1   libobjc.A.dylib                     0x00007fff89be7e75 objc_exception_throw + 43
                    2   CoreFoundation                      0x00007fff8cd1310c +[NSException raise:format:] + 204
                    3   Foundation                          0x00007fff8526c644 -[NSConcreteTask launchWithDictionary:] + 3167
                    4   Foundation                          0x00007fff8526b3e8 +[NSTask launchedTaskWithLaunchPath:arguments:] + 200
                    5   AdobeCrashReporter                  0x0000000108366cc0 AdobeCrashReporterInitialize + 2242
                    6   PublicLib.dylib                     0x00000001053ad34a _ZN13MCrashHandlerC1Ev + 106
                    7   Adobe InDesign CC 2014              0x00000001041b2691 main + 49
                    8   Adobe InDesign CC 2014              0x00000001041b25f4 start + 52
                    9   ???                                 0x0000000000000001 0x0 + 1
                    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
                    0   libsystem_kernel.dylib         0x00007fff8ce20866 __pthread_kill + 10
                    1   libsystem_pthread.dylib       0x00007fff903e935c pthread_kill + 92
                    2   libsystem_c.dylib             0x00007fff84881b1a abort + 125
                    3   libc++abi.dylib               0x00007fff83e17f31 abort_message + 257
                    4   libc++abi.dylib               0x00007fff83e3d952 default_terminate_handler() + 264
                    5   libobjc.A.dylib               0x00007fff89be830d _objc_terminate() + 103
                    6   libc++abi.dylib               0x00007fff83e3b1d1 std::__terminate(void (*)()) + 8
                    7   libc++abi.dylib               0x00007fff83e3ae7b __cxa_rethrow + 109
                    8   libobjc.A.dylib               0x00007fff89be8049 objc_exception_rethrow + 40
                    9   com.apple.Foundation           0x00007fff8526c9cb -[NSConcreteTask launchWithDictionary:] + 4070
                    10  com.apple.Foundation           0x00007fff8526b3e8 +[NSTask launchedTaskWithLaunchPath:arguments:] + 200
                    11  com.adobe.AdobeCrashReporter   0x0000000108366cc0 AdobeCrashReporterInitialize + 2242
                    12  PublicLib.dylib               0x00000001053ad34a MCrashHandler::MCrashHandler() + 106
                    13  com.adobe.InDesign             0x00000001041b2691 main + 49
                    14  com.adobe.InDesign             0x00000001041b25f4 start + 52
                    Thread 1:: Dispatch queue: com.apple.libdispatch-manager
                    0   libsystem_kernel.dylib         0x00007fff8ce21662 kevent64 + 10
                    1   libdispatch.dylib             0x00007fff82ba5421 _dispatch_mgr_invoke + 239
                    2   libdispatch.dylib             0x00007fff82ba5136 _dispatch_mgr_thread + 52
                    Thread 2:
                    0   libsystem_kernel.dylib         0x00007fff8ce20716 __psynch_cvwait + 10
                    1   libsystem_pthread.dylib       0x00007fff903eac77 _pthread_cond_wait + 787
                    2   com.apple.CoreServices.CarbonCore 0x00007fff8f75b9e7 TSWaitOnConditionTimedRelative + 148
                    3   com.apple.CoreServices.CarbonCore 0x00007fff8f72c145 MPWaitOnQueue + 192
                    4   PMRuntime.dylib               0x0000000105952b12 0x105951000 + 6930
                    5   com.apple.CoreServices.CarbonCore 0x00007fff8f72c6c3 PrivateMPEntryPoint + 58
                    6   libsystem_pthread.dylib       0x00007fff903e8899 _pthread_body + 138
                    7   libsystem_pthread.dylib       0x00007fff903e872a _pthread_start + 137
                    8   libsystem_pthread.dylib       0x00007fff903ecfc9 thread_start + 13
                    Thread 3:
                    0   libsystem_kernel.dylib         0x00007fff8ce20e6a __workq_kernreturn + 10
                    1   libsystem_pthread.dylib       0x00007fff903e9f08 _pthread_wqthread + 330
                    2   libsystem_pthread.dylib       0x00007fff903ecfb9 start_wqthread + 13
                    Thread 4:
                    Thread 0 crashed with X86 Thread State (64-bit):
                      rax: 0x0000000000000000  rbx: 0x00007fff75073310  rcx: 0x00007fff5ba4e0c8  rdx: 0x0000000000000000
                      rdi: 0x0000000000000707  rsi: 0x0000000000000006  rbp: 0x00007fff5ba4e0f0  rsp: 0x00007fff5ba4e0c8
                       r8: 0x00007fff83e3e959   r9: 0x00007fff848a98d0  r10: 0x0000000008000000  r11: 0x0000000000000206
                      r12: 0x00007fff5ba4e250  r13: 0x00006080000849c0  r14: 0x0000000000000006  r15: 0x00007fff5ba4e130
                      rip: 0x00007fff8ce20866  rfl: 0x0000000000000206  cr2: 0x00000001043a7000
                    Logical CPU:     0
                    Error Code:      0x02000148
                    Trap Number:     133
                    • 7. Re: Uncaught exception error
                      Matchwho
                      Also getting this error.
                      Any idea how to fix?
                      Process:               Adobe Illustrator [48774]
                      Path:                  /Applications/Adobe Illustrator CC 2014/Adobe Illustrator.app/Contents/MacOS/Adobe Illustrator
                      Identifier:            com.adobe.illustrator
                      Version:               18.1.1 (18.1.1)
                      Responsible:           Adobe Illustrator [48774]
                      User ID:               501
                      Date/Time:             2015-01-26 20:54:32.910 +0000
                      OS Version:            Mac OS X 10.10.1 (14B25)
                      Report Version:        11
                      Anonymous UUID:        AB028816-B379-6F9D-B23C-77556AF5A9FE
                      Sleep/Wake UUID:       0093D021-7359-405C-B3AB-4AD5B5990B6F
                      Time Awake Since Boot: 110000 seconds
                      Tim
                      • 8. Re: Uncaught exception error
                        If you're talking about the "Couldn't posix_spawn: error 35", the only fix I know of is to reboot. It hasn't happened again for me since then.
                        -DaveS
                        • 9. Re: Uncaught exception error
                          geertss
                          getting the same issue with lightroom and photoshop.
                          the error for lightroom
                          Process:               Adobe Photoshop Lightroom 5 [56553]
                          Path:                  /Applications/Adobe Photoshop Lightroom 5.app/Contents/MacOS/Adobe Photoshop Lightroom 5
                          Identifier:            com.adobe.Lightroom5
                          Version:               Adobe Photoshop Lightroom 5.7.1 [994773] (5.7.1)
                          Responsible:           Adobe Photoshop Lightroom 5 [56553]
                          User ID:               501
                          Date/Time:             2015-01-26 22:47:46.234 +0100
                          OS Version:            Mac OS X 10.10.2 (14C94b)
                          Report Version:        11
                          Anonymous UUID:        A215BD21-D577-D2D8-18EB-2FDE82D8EE51
                          Sleep/Wake UUID:       E0864629-715F-44ED-90B1-5AB3AAFDC74B
                          Time Awake Since Boot: 56000 seconds
                          Time Since Wake:       67 seconds
                          abort() called
                          • 10. Re: Uncaught exception error
                            KieranBrennanDublin Level 1
                            abort() called
                            This happened for me after a boot also.
                            My colleague had an issue with Illustrator crashing also and was fixed by you guys locating an compatibility issue with 'Suitcase Fusion' so I thought that was my problem too but it ain't
                            Re-booted, with Suitcase Fusion deactivated, works fine.
                            Re-booted with Suitcase Fusion activated, works fine
                            • 11. Re: Uncaught exception error
                              AFCathaCA Level 1
                              I've experienced the same issue but with Acrobat DC only (so far).
                              iMac (27-inch, Mid 2011)
                              OSX details: v. 10.10.3, 16GB RAM,
                              Crash details (for those who read Klingon):
                              Process:               AdobeAcrobat [2489]
                              Path:                  /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat
                              Identifier:            com.adobe.Acrobat.Pro
                              Version:               15.007.20033 (15.007.20033)
                              Responsible:           AdobeAcrobat [2489]
                              User ID:               502
                              Date/Time:             2015-05-10 17:11:39.888 -0700
                              OS Version:            Mac OS X 10.10.3 (14D136)
                              Report Version:        11
                              Anonymous UUID:        627EA817-0531-E245-88C5-3BE78E48F35B
                              Sleep/Wake UUID:       05711976-EA5D-490C-941B-50086FBC856D
                              Time Awake Since Boot: 18000 seconds
                              Time Since Wake:       3600 seconds
                              Crashed Thread:        15
                              abort() called
                              0   CoreFoundation                      0x00007fff9721b03c __exceptionPreprocess + 172
                              1   libobjc.A.dylib                     0x00007fff9a43476e objc_exception_throw + 43
                              2   CoreFoundation                      0x00007fff9721aeed +[NSException raise:format:] + 205
                              3   Foundation                          0x00007fff92aa6bbf -[NSConcreteTask launchWithDictionary:] + 3119
                              4   amtlib                              0x0000000115808f5e AMTRecordCodecInvocation + 164087
                              5   amtlib                              0x000000011585c7fb AMTRecordCodecInvocation + 506260
                              6   amtlib                              0x000000011585776f AMTRecordCodecInvocation + 485640
                              7   amtlib                              0x0000000115858940 AMTRecordCodecInvocation + 490201
                              8   amtlib                              0x00000001157fbf37 AMTRecordCodecInvocation + 110800
                              9   amtlib                              0x00000001157f6def AMTRecordCodecInvocation + 89992
                              10  amtlib                              0x00000001157f5a65 AMTRecordCodecInvocation + 84990
                              11  amtlib                              0x00000001157f65fd AMTRecordCodecInvocation + 87958
                              12  amtlib                              0x0000000115800541 AMTRecordCodecInvocation + 128730
                              13  amtlib                              0x000000011584204c AMTRecordCodecInvocation + 397797
                              14  libsystem_pthread.dylib             0x00007fff930c9268 _pthread_body + 131
                              15  libsystem_pthread.dylib             0x00007fff930c91e5 _pthread_body + 0
                              16  libsystem_pthread.dylib             0x00007fff930c741d thread_start + 13
                              Thread 0:: Dispatch queue: com.apple.main-thread
                              0   libsystem_kernel.dylib         0x00007fff990c04de mach_msg_trap + 10
                              1   libsystem_kernel.dylib         0x00007fff990bf64f mach_msg + 55
                              2   com.apple.CoreFoundation       0x00007fff97129eb4 __CFRunLoopServiceMachPort + 212
                              3   com.apple.CoreFoundation       0x00007fff9712937b __CFRunLoopRun + 1371
                              4   com.apple.CoreFoundation       0x00007fff97128bd8 CFRunLoopRunSpecific + 296
                              5   com.apple.HIToolbox           0x00007fff8e3ae56f RunCurrentEventLoopInMode + 235
                              6   com.apple.HIToolbox           0x00007fff8e3ae2ea ReceiveNextEventCommon + 431
                              7   com.apple.HIToolbox           0x00007fff8e3ae12b _BlockUntilNextEventMatchingListInModeWithFilter + 71
                              8   com.apple.AppKit               0x00007fff8ec069bb _DPSNextEvent + 978
                              9   com.apple.AppKit               0x00007fff8ec05f68 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 346
                              10  com.apple.AppKit               0x00007fff8ebfbbf3 -[NSApplication run] + 594
                              11  com.adobe.Acrobat.framework   0x0000000109cae35b 0x109ca6000 + 33627
                              12  com.adobe.Acrobat.framework   0x0000000109cacc40 RunAcrobat + 236
                              13  com.adobe.Acrobat.Pro         0x0000000109c9fcb2 main + 86
                              14  com.adobe.Acrobat.Pro         0x0000000109c9fc54 start + 52
                              0   libsystem_kernel.dylib         0x00007fff990c6232 kevent64 + 10
                              1   libdispatch.dylib             0x00007fff965a4a6a _dispatch_mgr_thread + 52
                              Thread 2:: Dispatch queue: NSOperationQueue 0x618000227c80 :: NSOperation 0x618000227d00 (QOS: USER_INITIATED)
                              0   libsystem_kernel.dylib         0x00007fff990c548a __semwait_signal + 10
                              1   com.apple.Foundation           0x00007fff92b2b5c0 +[NSThread sleepForTimeInterval:] + 154
                              2   com.adobe.Acrobat.framework   0x000000010abd247b 0x109ca6000 + 15910011
                              3   com.apple.Foundation           0x00007fff92ad9a6c -[__NSOperationInternal _start:] + 653
                              4   com.apple.Foundation           0x00007fff92ad9543 __NSOQSchedule_f + 184
                              5   libdispatch.dylib             0x00007fff965a1c13 _dispatch_client_callout + 8
                              6   libdispatch.dylib             0x00007fff965a5365 _dispatch_queue_drain + 1100
                              7   libdispatch.dylib             0x00007fff965a6ecc _dispatch_queue_invoke + 202
                              8   libdispatch.dylib             0x00007fff965a46b7 _dispatch_root_queue_drain + 463
                              9   libdispatch.dylib             0x00007fff965b2fe4 _dispatch_worker_thread3 + 91
                              10  libsystem_pthread.dylib       0x00007fff930c9637 _pthread_wqthread + 729
                              11  libsystem_pthread.dylib       0x00007fff930c740d start_wqthread + 13
                              Thread 3:
                              0   libsystem_kernel.dylib         0x00007fff990c5136 __psynch_cvwait + 10
                              1   com.adobe.AGM                 0x000000010c5f42e2 AGMMessageQueueImpl::Pull() + 68
                              2   com.adobe.AGM                 0x000000010c5f421d AGMWorkQueueTask::operator()() + 73
                              3   com.adobe.AGM                 0x000000010c98a6c3 boost::(anonymous namespace)::thread_proxy(void*) + 136
                              5   libsystem_pthread.dylib       0x00007fff930c91e5 _pthread_start + 176
                              Thread 4:
                              Thread 5:
                              Thread 6:
                              0   libsystem_kernel.dylib         0x00007fff990c594a __workq_kernreturn + 10
                              Thread 7:
                              5   com.apple.AppKit               0x00007fff8ecce66b _NSEventThread + 137
                              6   libsystem_pthread.dylib       0x00007fff930c9268 _pthread_body + 131
                              7   libsystem_pthread.dylib       0x00007fff930c91e5 _pthread_start + 176
                              8   libsystem_pthread.dylib       0x00007fff930c741d thread_start + 13
                              Thread 8:
                              1   com.adobe.Acrobat.framework   0x000000010a11402f 0x109ca6000 + 4644911
                              2   com.adobe.Acrobat.framework   0x000000010a104db1 0x109ca6000 + 4582833
                              3   com.adobe.Acrobat.framework   0x000000010ac5b8bf 0x109ca6000 + 16472255
                              4   com.adobe.Acrobat.framework   0x000000010a100753 0x109ca6000 + 4564819
                              5   com.adobe.Acrobat.framework   0x000000010a10e804 0x109ca6000 + 4622340
                              Thread 9:
                              0   libsystem_kernel.dylib         0x00007fff990c621a kevent + 10
                              1   com.adobe.Acrobat.framework   0x000000010b3782bd 0x109ca6000 + 23929533
                              2   libsystem_pthread.dylib       0x00007fff930c9268 _pthread_body + 131
                              3   libsystem_pthread.dylib       0x00007fff930c91e5 _pthread_start + 176
                              4   libsystem_pthread.dylib       0x00007fff930c741d thread_start + 13
                              Thread 10:
                              5   com.adobe.AcrobatPlugin.EFS   0x000000011417541b 0x11415b000 + 107547
                              6   com.apple.Foundation           0x00007fff92abedc2 __NSThread__main__ + 1345
                              7   libsystem_pthread.dylib       0x00007fff930c9268 _pthread_body + 131
                              8   libsystem_pthread.dylib       0x00007fff930c91e5 _pthread_start + 176
                              9   libsystem_pthread.dylib       0x00007fff930c741d thread_start + 13
                              Thread 11:: com.apple.NSURLConnectionLoader
                              5   com.apple.CFNetwork           0x00007fff9145c220 +[NSURLConnection(Loader) _resourceLoadLoop:] + 434
                              Thread 12:
                              Thread 13:: com.apple.CFSocket.private
                              0   libsystem_kernel.dylib         0x00007fff990c53fa __select + 10
                              1   libsystem_pthread.dylib       0x00007fff930c9268 _pthread_body + 131
                              2   libsystem_pthread.dylib       0x00007fff930c91e5 _pthread_start + 176
                              3   libsystem_pthread.dylib       0x00007fff930c741d thread_start + 13
                              Thread 14:
                              Thread 15 Crashed:
                              0   libsystem_kernel.dylib         0x00007fff990c5286 __pthread_kill + 10
                              1   libsystem_c.dylib             0x00007fff963b1b53 abort + 129
                              2   libc++abi.dylib               0x00007fff94185a21 abort_message + 257
                              3   libc++abi.dylib               0x00007fff941ad9d1 default_terminate_handler() + 267
                              4   libobjc.A.dylib               0x00007fff9a4387d6 _objc_terminate() + 103
                              5   libc++abi.dylib               0x00007fff941ab0a1 std::__terminate(void (*)()) + 8
                              6   libc++abi.dylib               0x00007fff941aad48 __cxa_rethrow + 99
                              7   libobjc.A.dylib               0x00007fff9a4385f4 objc_exception_rethrow + 40
                              8   com.apple.Foundation           0x00007fff92aa6f34 -[NSConcreteTask launchWithDictionary:] + 4004
                              9   com.adobe.amtlib               0x0000000115808f5e 0x1157de000 + 175966
                              10  com.adobe.amtlib               0x000000011585c7fb 0x1157de000 + 518139
                              11  com.adobe.amtlib               0x000000011585776f 0x1157de000 + 497519
                              12  com.adobe.amtlib               0x0000000115858940 0x1157de000 + 502080
                              13  com.adobe.amtlib               0x00000001157fbf37 0x1157de000 + 122679
                              14  com.adobe.amtlib               0x00000001157f6def 0x1157de000 + 101871
                              15  com.adobe.amtlib               0x00000001157f5a65 0x1157de000 + 96869
                              16  com.adobe.amtlib               0x00000001157f65fd 0x1157de000 + 99837
                              17  com.adobe.amtlib               0x0000000115800541 0x1157de000 + 140609
                              18  com.adobe.amtlib               0x000000011584204c 0x1157de000 + 409676
                              19  libsystem_pthread.dylib       0x00007fff930c9268 _pthread_body + 131
                              20  libsystem_pthread.dylib       0x00007fff930c91e5 _pthread_start + 176
                              21  libsystem_pthread.dylib       0x00007fff930c741d thread_start + 13
                              Thread 15 crashed with X86 Thread State (64-bit):
                                rax: 0x0000000000000000  rbx: 0x0000000000000006  rcx: 0x0000000115970cf8  rdx: 0x0000000000000000
                                rdi: 0x0000000000005527  rsi: 0x0000000000000006  rbp: 0x0000000115970d20  rsp: 0x0000000115970cf8
                                 r8: 0x0000000000000000   r9: 0x00007fff963dbd70  r10: 0x0000000008000000  r11: 0x0000000000000206
                                r12: 0x0000000115970e80  r13: 0x00006180002834d0  r14: 0x0000000115973000  r15: 0x0000000115970d60
                                rip: 0x00007fff990c5286  rfl: 0x0000000000000206  cr2: 0x00007fff7d0d3fd8
                              Logical CPU:     0
                              Trap Number:     133
                              Binary Images:
                                     0x109c9e000 -        0x109ca0fff +com.adobe.Acrobat.Pro (15.007.20033 - 15.007.20033) <FD883658-7F81-3781-BF5A-E7160ECDEA5E> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat
                                     0x109ca6000 -        0x10c150ff7 +com.adobe.Acrobat.framework (15.007.20033 - 15.007.20033) <22778E59-6EA4-3260-96A9-1641284117D2> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/Acrobat.framework/Versions/A/Acrobat
                                     0x10c483000 -        0x10c5d0ff7 +com.adobe.ACE (AdobeACE 2.20.02.34252 - 2.20.02.34252) <DF2FA57B-FF8B-3AB3-8202-A48B685F3AF9> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                                     0x10c5e7000 -        0x10cbe3fff +com.adobe.AGM (AdobeAGM 4.30.57.1 - 4.30.57.1) <717F95AB-749A-3578-9109-42CC1DC7DF89> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                                     0x10d0cb000 -        0x10d0eafff +com.adobe.BIB (AdobeBIB 1.2.03.34252 - 1.2.03.34252) <AC4C9DD4-7FFA-3ABC-AF3D-5BB1201EC482> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                                     0x10d0f3000 -        0x10d418ff7 +com.adobe.CoolType (AdobeCoolType 5.14.04.34252 - 5.14.04.34252) <6E348DF6-055E-3008-8B75-3D9A6EB0C16E> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                                     0x10d4e5000 -        0x10d50cff7 +com.adobe.AcrobatPlugin.Updater (15.007.20033 - 15.007.20033) <8C9191EB-FD53-3D1D-B351-5903B6584CC1> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Updater.acroplugin/Contents/MacOS/Updater
                                     0x10d516000 -        0x10d518fff +AcrobatUpdateHelperLib.dylib (1) <A1B780FD-80BE-3A94-BB16-2C771662B2B5> /Library/Application Support/Adobe/*/AcrobatUpdateHelperLib.dylib
                                     0x111b67000 -        0x111b67fef +cl_kernels (???) <29DAFF58-A634-42FF-AD9A-80A0103B0BB8> cl_kernels
                                     0x111b76000 -        0x111b76ff5 +cl_kernels (???) <E3E31445-7D59-41B8-9B10-7EF8EC72A68D> cl_kernels
                                     0x111ec0000 -        0x111ee4ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.9.0.33931 - 3.9.0.33931) <FC64B09E-8B23-3E05-B03A-5CB9BFB60586> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8Shared Expat
                                     0x11218f000 -        0x112207fff +com.adobe.AcroSQLite (AcroSQLite - 1.0.0) <231E5716-70E9-3ECF-8F9D-C802F14DE920> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AcroSQLite.framework/Versions/A/AcroSQLite
                                     0x112212000 -        0x1122befff  ColorSyncDeprecated.dylib (442) <3518239D-60D5-39AF-A68C-E7B12564103C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/Resources/ColorSyncDeprecated.dylib
                                     0x11400d000 -        0x11411cff7 +IMSLib.dylib (9.0.1.5 - 9.0.1.5) <AC77A2DA-B4AC-3F26-95C6-E649631A0A99> /Applications/Utilities/Adobe Application Manager/*/IMSLib.dylib
                                     0x11415b000 -        0x114185fff +com.adobe.AcrobatPlugin.EFS (15.007.20033 - 15.007.20033) <A0971EEF-0C45-37F3-859B-16E4846C7125> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/EFS.acroplugin/Contents/MacOS/EFS
                                     0x11443b000 -        0x1144b5ff7  com.apple.xquery (1.3.1 - 30) <9D868AE3-C5A0-34BD-8C33-EB5F8EDD7ACA> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
                                     0x1144f1000 -        0x114ce2ff7 +com.adobe.AcrobatPlugin.Comments (15.007.20033 - 15.007.20033) <D44862C6-B06C-35E7-80CF-D8CC6F38BD10> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Plugins/Comments.acroplugin/Contents/MacOS/Comments
                                     0x1152f1000 -        0x1153d7fef  unorm8_bgra.dylib (2.4.5) <7BFE1DA8-2BE4-3B4F-8A7F-F3D6D4D36ADA> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra .dylib
                                     0x1157de000 -        0x1158dffff +com.adobe.amtlib (9.0.0.2 - 9.0.0.2) <3F115300-9436-3FC8-96E3-0CAFC726F02C> /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/amtlib.framework/amtlib
                                  0x7fff63328000 -     0x7fff6335e837  dyld (353.2.1) <65DCCB06-339C-3E25-9702-600A28291D0E> /usr/lib/dyld
                                  0x7fff8b716000 -     0x7fff8b782ff3  com.apple.MMCS (1.3 - 327.5) <FC998246-ED60-334D-9E94-453F35EF9C78> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
                                  0x7fff8b783000 -     0x7fff8b807fff  com.apple.PerformanceAnalysis (1.0 - 1) <599AED3E-B689-3C40-8B91-93AD36C97658> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                                  0x7fff8b808000 -     0x7fff8b825ffb  libresolv.9.dylib (57) <26B38E61-298A-3C3A-82C1-3B5E98AD5E29> /usr/lib/libresolv.9.dylib
                                  0x7fff8b826000 -     0x7fff8b872ff7  libcups.2.dylib (408.2) <E8AD18F9-61E4-3791-B840-504468C25556> /usr/lib/libcups.2.dylib
                                  0x7fff8b98e000 -     0x7fff8b9a8ff3  com.apple.Ubiquity (1.3 - 313) <DF56A657-CC6E-3BE2-86A0-71F07127724C> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
                                  0x7fff8b9a9000 -     0x7fff8b9a9ff7  libkeymgr.dylib (28) <77845842-DE70-3CC5-BD01-C3D14227CED5> /usr/lib/system/libkeymgr.dylib
                                  0x7fff8b9aa000 -     0x7fff8ba18ffb  com.apple.Heimdal (4.0 - 2.0) <7697A837-98B8-3BDB-A7D2-8ED4C9ABC510> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                                  0x7fff8ba19000 -     0x7fff8ba88fff  com.apple.SearchKit (1.4.0 - 1.4.0) <80883BD1-C9BA-3794-A20E-476F94DD89A9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                                  0x7fff8bbe6000 -     0x7fff8bbeefe7  libcldcpuengine.dylib (2.4.5) <0E9B5292-1EBC-379D-A706-83A27C05D742> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
                                  0x7fff8c478000 -     0x7fff8c4afffb  com.apple.LDAPFramework (2.4.28 - 194.5) <CAFB9695-000F-34EA-8DF5-09996929C26A> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                                  0x7fff8c4b0000 -     0x7fff8c72fff7  com.apple.CoreData (111 - 526.3) <5A27E0D8-5E5A-335B-B3F6-2601C7B976FA> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                                  0x7fff8c730000 -     0x7fff8c75cfff  com.apple.framework.SystemAdministration (1.0 - 1.0) <B427BF0A-36DC-357F-B807-1B1AA2AFB7BA> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdminis tration
                                  0x7fff8c75d000 -     0x7fff8c779ff7  libsystem_malloc.dylib (53.1.1) <19BCC257-5717-3502-A71F-95D65AFA861B> /usr/lib/system/libsystem_malloc.dylib
                                  0x7fff8c8bf000 -     0x7fff8cc2afff  com.apple.VideoToolbox (1.0 - 1562.235) <0E996B8C-BE1C-3749-ACCA-DACBC89AFABB> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                                  0x7fff8cc4e000 -     0x7fff8ccdcff7  com.apple.CorePDF (4.0 - 4) <9CD7EC6D-3593-3D60-B04F-75F612CCB99A> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
                                  0x7fff8ccdd000 -     0x7fff8cd18fff  com.apple.QD (301 - 301) <C4D2AD03-B839-350A-AAF0-B4A08F8BED77> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                                  0x7fff8cd19000 -     0x7fff8cd20ff7  libcompiler_rt.dylib (35) <BF8FC133-EE10-3DA6-9B90-92039E28678F> /usr/lib/system/libcompiler_rt.dylib
                                  0x7fff8cd6f000 -     0x7fff8cdb0fff  libGLU.dylib (11.1.2) <4C54F0D1-2ADC-38A0-92D1-F479E9B99355> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                                  0x7fff8d083000 -     0x7fff8d085ffb  libCGXType.A.dylib (779.11) <51607E77-F183-3CC2-A78C-238AFBDF6262> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
                                  0x7fff8d086000 -     0x7fff8d3b9ff7  libmecabra.dylib (666.7) <0ED8AE5E-7A5B-34A6-A2EE-2B852E60E1E2> /usr/lib/libmecabra.dylib
                                  0x7fff8d853000 -     0x7fff8d977ff7  com.apple.LaunchServices (644.56 - 644.56) <20AABB1C-9319-3E4D-A024-51B0DD5FCD3B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                                  0x7fff8d99d000 -     0x7fff8d99dfff  com.apple.quartzframework (1.5 - 1.5) <26C982A3-2FC3-3F50-B5F4-3C545C3BAC10> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                                  0x7fff8d99e000 -     0x7fff8d9eafff  com.apple.corelocation (1486.17 - 1615.24) <8825B3E2-E053-3E01-AE31-793443962D06> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
                                  0x7fff8d9fe000 -     0x7fff8da0dfff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <D1E527E4-C561-352F-9457-E8C50232793C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                                  0x7fff8da0e000 -     0x7fff8da33ff7  libPng.dylib (1237) <CFBF1344-36AB-3AAE-B2EB-9FC1369F967F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                                  0x7fff8da34000 -     0x7fff8da4efff  com.apple.AppleVPAFramework (1.4.3 - 1.4.3) <AE62A92E-EDA7-37AD-8AF0-7912E9381A1F> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
                                  0x7fff8da4f000 -     0x7fff8dbddfff  libBLAS.dylib (1128) <497912C1-A98E-3281-BED7-E9C751552F61> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                                  0x7fff8dbe1000 -     0x7fff8dbe2ffb  libremovefile.dylib (35) <3485B5F4-6CE8-3C62-8DFD-8736ED6E8531> /usr/lib/system/libremovefile.dylib
                                  0x7fff8dbe3000 -     0x7fff8e10cfff  com.apple.QuartzComposer (5.1 - 332) <BCEDA75A-684E-34A7-8204-65E0ECB760B2> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
                                  0x7fff8e10d000 -     0x7fff8e21cff3  com.apple.desktopservices (1.9.3 - 1.9.3) <FEE11342-5BC4-37A7-8169-DA48BE17B9C9> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                                  0x7fff8e292000 -     0x7fff8e2e3ff7  com.apple.AppleVAFramework (5.0.31 - 5.0.31) <FED294D2-13CB-381D-98D0-BDA909AACA32> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                                  0x7fff8e2e4000 -     0x7fff8e37bfff  com.apple.CoreMedia (1.0 - 1562.235) <21EB4AB6-2DBC-326B-B17E-E88BAA9E9200> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                                  0x7fff8e37c000 -     0x7fff8e681ff3  com.apple.HIToolbox (2.1.1 - 758.7) <6711FAA9-904A-3B49-9665-FC8D13B93C42> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                                  0x7fff8e682000 -     0x7fff8e6dffff  com.apple.QuickLookFramework (5.0 - 675.42) <A9B7668D-60EF-35B2-9ACB-0E68DE335B15> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                                  0x7fff8e6e0000 -     0x7fff8e712ff3  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <C6DB0A07-F8E4-3837-BCA9-225F460EDA81> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
                                  0x7fff8e713000 -     0x7fff8e71fff7  com.apple.OpenDirectory (10.10 - 187) <1E07769D-68DE-3BF2-8E9E-A1E98BF70D1B> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                                  0x7fff8e720000 -     0x7fff8e72bfff  libGL.dylib (11.1.2) <BF99CC65-215A-3C7D-87D7-3F7EE6E9B3DD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                                  0x7fff8e72c000 -     0x7fff8e75cff3  com.apple.CoreAVCHD (5.7.5 - 5750.4.1) <3E51287C-E97D-3886-BE88-8F6872400876> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
                                  0x7fff8e75d000 -     0x7fff8e75efff  libDiagnosticMessagesClient.dylib (100) <2EE8E436-5CDC-34C5-9959-5BA218D507FB> /usr/lib/libDiagnosticMessagesClient.dylib
                                  0x7fff8e75f000 -     0x7fff8e787fff  libRIP.A.dylib (779.11) <88434DA0-B6B8-304A-9DC0-41D3947E8734> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
                                  0x7fff8e78d000 -     0x7fff8e822ff7  com.apple.ColorSync (4.9.0 - 4.9.0) <9150C2B7-2E6E-3509-96EA-7B3F959F049E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                                  0x7fff8e928000 -     0x7fff8ea8fffb  com.apple.audio.toolbox.AudioToolbox (1.12 - 1.12) <5678FC94-456A-3F5F-BA9A-10EB6E462997> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                                  0x7fff8ea91000 -     0x7fff8ea99fff  libsystem_dnssd.dylib (561.1.1) <62B70ECA-E40D-3C63-896E-7F00EC386DDB> /usr/lib/system/libsystem_dnssd.dylib
                                  0x7fff8ea9a000 -     0x7fff8eaa0ff7  com.apple.XPCService (2.0 - 1) <AA4A5393-1F5D-3465-A417-0414B95DC052> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
                                  0x7fff8eaa1000 -     0x7fff8eaeefff  com.apple.ImageCaptureCore (6.3 - 6.3) <44B6E670-16ED-3C81-9E8D-34543CD71273> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                                  0x7fff8eb71000 -     0x7fff8eb74fff  com.apple.xpc.ServiceManagement (1.0 - 1) <9E025823-660A-30C5-A568-223BD595B6F7> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                                  0x7fff8eb75000 -     0x7fff8f6f6ff7  com.apple.AppKit (6.9 - 1347.57) <B214D528-7D1C-39B2-BE36-821D417A0297> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                                  0x7fff8f6f7000 -     0x7fff8f76dfe7  libcorecrypto.dylib (233.1.2) <E1789801-3985-3949-B736-6B3378873301> /usr/lib/system/libcorecrypto.dylib
                                  0x7fff8f76e000 -     0x7fff8f76ffff  libffi.dylib (18.1) <0F6C6A4D-1210-3585-8DA1-B8A94B9924A5> /usr/lib/libffi.dylib
                                  0x7fff8f770000 -     0x7fff8f783ff7  com.apple.CoreBluetooth (1.0 - 1) <8D7BA9BA-EB36-307A-9119-0B3D9732C953> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
                                  0x7fff8f784000 -     0x7fff8f786fff  libsystem_sandbox.dylib (358.20.5) <4CF77128-6BE0-3958-B646-707FA9CE61B2> /usr/lib/system/libsystem_sandbox.dylib
                                  0x7fff8f7b2000 -     0x7fff8f7e1ff7  com.apple.CoreServicesInternal (221.7.2 - 221.7.2) <B93D4775-149C-3698-B38C-9C50673D455C> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                                  0x7fff8f897000 -     0x7fff8f915fff  com.apple.CoreServices.OSServices (640.4 - 640.4) <20121A5E-7AB5-3624-8CF0-3562F97C8A95> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                                  0x7fff8f916000 -     0x7fff8f91afff  com.apple.LoginUICore (3.2 - 3.2) <417954C5-1675-31A8-9631-6B56E9AA3E93> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore. framework/Versions/A/LoginUICore
                                  0x7fff8f926000 -     0x7fff8f957ff7  com.apple.ProtectedCloudStorage (1.0 - 1) <D0903EA8-D861-3488-BCF5-9D8E7C6D01FA> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
                                  0x7fff8f958000 -     0x7fff8f960ff3  com.apple.CoreServices.FSEvents (1210.20.1 - 1210.20.1) <84F79D3E-7B5E-3C93-8479-35794A3F125E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
                                  0x7fff8f977000 -     0x7fff8f97ffff  libMatch.1.dylib (24) <C917279D-33C2-38A8-9BDD-18F3B24E6FBD> /usr/lib/libMatch.1.dylib
                                  0x7fff8f9b0000 -     0x7fff8fa94fff  libcrypto.0.9.8.dylib (52.20.2) <977DA067-2588-3BF8-A7B2-F08FC6E9088F> /usr/lib/libcrypto.0.9.8.dylib
                                  0x7fff8fa98000 -     0x7fff8fae3fff  com.apple.CloudDocs (1.0 - 321.6) <4C54EDB7-4377-3722-8C47-F3C3D260FCBA> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
                                  0x7fff8fb21000 -     0x7fff8fb92ffb  com.apple.ApplicationServices.ATS (360 - 375.2) <2338AF23-528F-359A-847F-8B04E49E2B84> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                                  0x7fff904d9000 -     0x7fff904efff7  com.apple.CoreMediaAuthoring (2.2 - 951) <C3E7D4C1-400D-34FA-9FE1-8C68C03CE969> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                                  0x7fff904f0000 -     0x7fff9050dfff  com.apple.MultitouchSupport.framework (263.9.1 - 263.9.1) <6ABD3AE2-DF6A-3AB2-994B-9C0FB42CE2B7> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                                  0x7fff90510000 -     0x7fff90516fff  com.apple.speech.recognition.framework (5.0.9 - 5.0.9) <BB2D573F-0A01-379F-A2BA-3C454EDCB111> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                                  0x7fff90517000 -     0x7fff90542ff3  libarchive.2.dylib (30) <8CBB4416-EBE9-3574-8ADC-44655D245F39> /usr/lib/libarchive.2.dylib
                                  0x7fff90543000 -     0x7fff90548fff  com.apple.DiskArbitration (2.6 - 2.6) <0DFF4D9B-2AC3-3B82-B5C5-30F4EFBD2DB9> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                                  0x7fff90549000 -     0x7fff9054cfff  com.apple.IOSurface (97.4 - 97.4) <AE11CFBC-4D46-30F3-BEEC-4C8131079391> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                                  0x7fff905b3000 -     0x7fff905ecfff  com.apple.AirPlaySupport (2.0 - 215.18) <6AF8E973-3643-3FEE-AA8F-541B9F093EEE> /System/Library/PrivateFrameworks/AirPlaySupport.framework/Versions/A/AirPlaySupport
                                  0x7fff905ed000 -     0x7fff905f2ff7  com.apple.MediaAccessibility (1.0 - 61) <00A3E0B6-79AC-387E-B282-AADFBD5722F6> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
                                  0x7fff905f3000 -     0x7fff90612fff  com.apple.CoreDuet (1.0 - 1) <36AA9FD5-2685-314D-B364-3FA4688D86BD> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
                                  0x7fff90613000 -     0x7fff90636ff7  com.apple.framework.familycontrols (4.1 - 410) <E491AFDB-2E12-37D0-B093-6E93091019C4> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                                  0x7fff90637000 -     0x7fff9063eff7  libCGCMS.A.dylib (779.11) <5D33FF8C-AC74-3B7B-A602-4AA470FEAF79> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
                                  0x7fff9063f000 -     0x7fff90640ff3  libSystem.B.dylib (1213) <CCEC13A5-D0D9-31C5-B0B0-1C564B4A20A6> /usr/lib/libSystem.B.dylib
                                  0x7fff9066f000 -     0x7fff90670fff  com.apple.TrustEvaluationAgent (2.0 - 25) <2D61A2C3-C83E-3A3F-8EC1-736DBEC250AB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                                  0x7fff90671000 -     0x7fff90aa1fff  com.apple.vision.FaceCore (3.1.6 - 3.1.6) <C3B823AA-C261-37D3-B4AC-C59CE91C8241> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
                                  0x7fff90aa2000 -     0x7fff90aa4fff  libCVMSPluginSupport.dylib (11.1.2) <6EFEC4A6-2EAC-3C27-820E-C28BE71B9FCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                                  0x7fff90aa5000 -     0x7fff90b4cfff  com.apple.PDFKit (3.1 - 3.1) <717B6DB9-4C81-3326-AFB7-6B003FBF1311> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
                                  0x7fff90b4d000 -     0x7fff90b50ff7  libdyld.dylib (353.2.1) <9EACCA38-291D-38CC-811F-7E9D1451E2D3> /usr/lib/system/libdyld.dylib
                                  0x7fff90b51000 -     0x7fff90b52fff  liblangid.dylib (117) <B54A4AA0-2E53-3671-90F5-AFF711C0EB9E> /usr/lib/liblangid.dylib
                                  0x7fff90b53000 -     0x7fff90b57fff  libcache.dylib (69) <45E9A2E7-99C4-36B2-BEE3-0C4E11614AD1> /usr/lib/system/libcache.dylib
                                  0x7fff90b58000 -     0x7fff90b88fff  com.apple.GSS (4.0 - 2.0) <A37BAF76-C262-3292-B82D-F004CAC5F333> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                                  0x7fff90bb5000 -     0x7fff90be1fff  libsandbox.1.dylib (358.20.5) <C84D0EA1-CE60-3328-A196-D55874BE83D1> /usr/lib/libsandbox.1.dylib
                                  0x7fff90be2000 -     0x7fff90d43fff  com.apple.avfoundation (2.0 - 889.210) <0CFF0D47-7C6B-388E-87BD-404F43A6B1E0> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                                  0x7fff90d44000 -     0x7fff90d45ff7  libodfde.dylib (22) <52D0ABCD-F464-362C-86EA-ACA10993F556> /usr/lib/libodfde.dylib
                                  0x7fff90d46000 -     0x7fff91007ff7  com.apple.WebKit (10600 - 10600.5.17) <5724ED63-1C75-3090-B60A-DA484A9DBDE2> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
                                  0x7fff910a2000 -     0x7fff911e9ffb  com.apple.WebKitLegacy (10600 - 10600.5.17) <B44AA3ED-CF33-3F14-9A57-06A10C653EF5> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/ Versions/A/WebKitLegacy
                                  0x7fff911fb000 -     0x7fff91203ff7  com.apple.AppleSRP (5.0 - 1) <01EC5144-D09A-3D6A-AE35-F6D48585F154> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
                                  0x7fff912a5000 -     0x7fff912baff7  com.apple.AppContainer (4.0 - 238.20.2) <2AA2EF49-9F38-31F6-8B08-8CC7C26F57F3> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
                                  0x7fff912bb000 -     0x7fff913f8fff  com.apple.ImageIO.framework (3.3.0 - 1237) <138A800C-14B7-36C2-AB04-E162602C97E3> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                                  0x7fff91453000 -     0x7fff91660ff3  com.apple.CFNetwork (720.3.13 - 720.3.13) <69E15385-5784-3912-88F6-03B16F1C1A5C> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                                  0x7fff918f8000 -     0x7fff918fafff  com.apple.CoreDuetDebugLogging (1.0 - 1) <9A6E5710-EA99-366E-BF40-9A65EC1B46A1> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebug Logging
                                  0x7fff91910000 -     0x7fff9192aff7  libextension.dylib (55.2) <3BB019CA-199A-36AC-AA22-14B562138545> /usr/lib/libextension.dylib
                                  0x7fff9192b000 -     0x7fff9193bff7  libbsm.0.dylib (34) <A3A2E56C-2B65-37C7-B43A-A1F926E1A0BB> /usr/lib/libbsm.0.dylib
                                  0x7fff91947000 -     0x7fff91d54ff7  libLAPACK.dylib (1128) <F9201AE7-B031-36DB-BCF8-971E994EF7C1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                                  0x7fff91d55000 -     0x7fff91d6cff7  libLinearAlgebra.dylib (1128) <E78CCBAA-A999-3B65-8EC9-06DB15E67C37> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
                                  0x7fff91d6f000 -     0x7fff91d72ff7  com.apple.Mangrove (1.0 - 1) <6326024D-5C8D-3F59-9468-ACA1E01BC70C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
                                  0x7fff91d73000 -     0x7fff91f58ff7  libicucore.A.dylib (531.48) <3CD34752-B1F9-31D2-865D-B5B0F0BE3111> /usr/lib/libicucore.A.dylib
                                  0x7fff91f59000 -     0x7fff91f5aff7  com.apple.print.framework.Print (10.0 - 265) <3BC4FE7F-78A0-3E57-8F4C-520E7EFD36FA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                                  0x7fff91f5b000 -     0x7fff91f60ff7  libmacho.dylib (862) <126CA2ED-DE91-308F-8881-B9DAEC3C63B6> /usr/lib/system/libmacho.dylib
                                  0x7fff91f61000 -     0x7fff92053fff  libxml2.2.dylib (26) <B834E7C8-EC3E-3382-BC5A-DA38DC4D720C> /usr/lib/libxml2.2.dylib
                                  0x7fff9205e000 -     0x7fff92151ff7  libJP2.dylib (1237) <A48C29E6-9E9F-3449-B873-160DE8E94008> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                                  0x7fff92152000 -     0x7fff921d3ff7  com.apple.CoreUtils (1.1 - 110.1) <C98E1441-3FCB-3BC6-BB51-5380BD39EA88> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
                                  0x7fff92268000 -     0x7fff926bbfc7  com.apple.vImage (8.0 - 8.0) <33BE7B31-72DB-3364-B37E-C322A32748C5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                                  0x7fff926f2000 -     0x7fff928a2ff3  com.apple.QuartzCore (1.10 - 361.18) <ACA61D8F-9535-3141-8FDD-AC3EF6BF0806> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                                  0x7fff928a3000 -     0x7fff928a7fff  com.apple.TCC (1.0 - 1) <CCA42EE2-3400-3444-9486-BC454E60D944> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                                  0x7fff928a8000 -     0x7fff928aaff7  libutil.dylib (38) <471AD65E-B86E-3C4A-8ABD-B8665A2BCE3F> /usr/lib/libutil.dylib
                                  0x7fff928ab000 -     0x7fff92912ffb  com.apple.datadetectorscore (6.0 - 396.1.1) <9B0B3198-DDBE-36C0-8BA9-3EC89C725282> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                                  0x7fff92a48000 -     0x7fff92a64fff  com.apple.GenerationalStorage (2.0 - 209.11) <9FF8DD11-25FB-3047-A5BF-9415339B3EEC> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                                  0x7fff92a74000 -     0x7fff92a76fff  com.apple.SecCodeWrapper (4.0 - 238.20.2) <C6C126F0-6BF4-3E29-A9B7-7BAD8D17EE4F> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
                                  0x7fff92a77000 -     0x7fff92a7efff  com.apple.NetFS (6.0 - 4.0) <1581D25F-CC07-39B0-90E8-5D4F3CF84EBA> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                                  0x7fff92a7f000 -     0x7fff92a7ffff  libOpenScriptingUtil.dylib (162.1) <E0605012-0DDB-3150-8FD0-699376FA3CD0> /usr/lib/libOpenScriptingUtil.dylib
                                  0x7fff92a80000 -     0x7fff92db1fff  com.apple.Foundation (6.9 - 1153.20) <F0FF3A5D-C5B7-34A1-9319-DE1EF928E58E> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                                  0x7fff92db2000 -     0x7fff92db6fff  com.apple.CommonPanels (1.2.6 - 96) <F9ECC8AF-D9CA-3350-AFB4-5113A9B789A5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                                  0x7fff92dde000 -     0x7fff930c5ffb  com.apple.CoreServices.CarbonCore (1108.6 - 1108.6) <8953580E-7857-33B2-AA64-98296830D3A8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                                  0x7fff930c6000 -     0x7fff930cffff  libsystem_pthread.dylib (105.10.1) <3103AA7F-3BAE-3673-9649-47FFD7E15C97> /usr/lib/system/libsystem_pthread.dylib
                                  0x7fff93164000 -     0x7fff93433ff3  com.apple.CoreImage (10.3.4) <C1AE8252-A95D-3BF4-83B8-BE85E979F2CB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
                                  0x7fff93434000 -     0x7fff93576fff  libsqlite3.dylib (168) <7B580EB9-9260-35FE-AE2F-276A2C242BAB> /usr/lib/libsqlite3.dylib
                                  0x7fff9359d000 -     0x7fff935afff7  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <CE9FABB4-1C5D-3F9B-9BB8-5CC50C3E5E31> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDae monProtocol
                                  0x7fff93606000 -     0x7fff93636fff  libsystem_m.dylib (3086.1) <1E12AB45-6D96-36D0-A226-F24D9FB0D9D6> /usr/lib/system/libsystem_m.dylib
                                  0x7fff93637000 -     0x7fff9366afff  com.apple.MediaKit (16 - 757.2) <2912E5C2-085F-3FE2-8531-23B6E894B0F0> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
                                  0x7fff9366b000 -     0x7fff936beffb  libAVFAudio.dylib (118.6) <2441D4C1-D8FB-3DA9-9DD7-914E03413882> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
                                  0x7fff936bf000 -     0x7fff93baffff  com.apple.MediaToolbox (1.0 - 1562.235) <9813E9A6-5BD6-3E56-9D20-0023703D5096> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                                  0x7fff93bb0000 -     0x7fff93bfaff7  com.apple.HIServices (1.22 - 522.1) <E8BD41E4-7747-3CAF-807A-5CA9AD16B525> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                                  0x7fff93bfb000 -     0x7fff93c48ff7  com.apple.print.framework.PrintCore (10.3 - 451.1) <DE992474-0841-38A1-B4F6-46D653E454D5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                                  0x7fff93c49000 -     0x7fff93c62ff7  com.apple.CFOpenDirectory (10.10 - 187) <790ED527-EFD2-3EA6-8C97-A8C04E96EBA7> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                                  0x7fff93c63000 -     0x7fff94178ffb  com.apple.JavaScriptCore (10600 - 10600.5.10) <ED4CABC6-0952-3E28-A3CD-32CA5CE22252> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                                  0x7fff94185000 -     0x7fff941b0fff  libc++abi.dylib (125) <88A22A0F-87C6-3002-BFBA-AC0F2808B8B9> /usr/lib/libc++abi.dylib
                                  0x7fff941b1000 -     0x7fff941e9fff  libsystem_network.dylib (412.20.3) <589A5F67-BE2A-3245-A181-0ECC9B53EB00> /usr/lib/system/libsystem_network.dylib
                                  0x7fff941ea000 -     0x7fff941f8ff7  com.apple.opengl (11.1.2 - 11.1.2) <864B35BF-1E76-382B-8D5F-38C7282621E6> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                                  0x7fff941f9000 -     0x7fff9421ffff  com.apple.ChunkingLibrary (2.1 - 163.6) <29D4CB95-42EF-34C6-8182-BDB6F7BB1E79> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                                  0x7fff94239000 -     0x7fff9436bff7  com.apple.MediaControlSender (2.0 - 215.18) <86E901A7-64C3-3D2C-BBD4-E385405831D3> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSen der
                                  0x7fff9436c000 -     0x7fff94377ff7  libkxld.dylib (2782.20.48) <28EF8328-E3E2-336A-974B-FB1BF119D55A> /usr/lib/system/libkxld.dylib
                                  0x7fff94401000 -     0x7fff94413ff7  com.apple.ImageCapture (9.0 - 9.0) <7FB65DD4-56B5-35C4-862C-7A2DED991D1F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                                  0x7fff94414000 -     0x7fff94473fff  com.apple.AE (681.2 - 681.2) <181B3B06-2DC6-3E4D-B44A-2551C5E9CF6F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                                  0x7fff94501000 -     0x7fff9451bff7  com.apple.Kerberos (3.0 - 1) <7760E0C2-A222-3709-B2A6-B692D900CEB1> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                                  0x7fff94ee1000 -     0x7fff94ee1fff  com.apple.Cocoa (6.8 - 21) <EAC0EA1E-3C62-3B28-A941-5D8B1E085FF8> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                                  0x7fff94fdf000 -     0x7fff94fe7fff  libsystem_platform.dylib (63) <64E34079-D712-3D66-9CE2-418624A5C040> /usr/lib/system/libsystem_platform.dylib
                                  0x7fff94feb000 -     0x7fff94febff7  libunc.dylib (29) <5676F7EA-C1DF-329F-B006-D2C3022B7D70> /usr/lib/system/libunc.dylib
                                  0x7fff94ffb000 -     0x7fff95084ff7  com.apple.CoreSymbolication (3.1 - 57020.1) <85707039-0C8A-3409-B0B5-153431CC1841> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                                  0x7fff95085000 -     0x7fff95140ff7  com.apple.DiscRecording (9.0 - 9000.4.2) <4655B4B8-523D-3AE6-92A0-8486A2258B3B> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
                                  0x7fff95242000 -     0x7fff95242ff7  liblaunch.dylib (559.20.9) <FA89A113-696E-3271-8FE1-A0D7324E8481> /usr/lib/system/liblaunch.dylib
                                  0x7fff9524e000 -     0x7fff952bafff  com.apple.framework.CoreWLAN (5.0 - 500.35.2) <5E228544-77A9-3AA5-8355-E8F6626F50E7> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                                  0x7fff952bb000 -     0x7fff952c6fff  libcommonCrypto.dylib (60061) <D381EBC6-69D8-31D3-8084-5A80A32CB748> /usr/lib/system/libcommonCrypto.dylib
                                  0x7fff952c7000 -     0x7fff952d2ff7  com.apple.CrashReporterSupport (10.10 - 631) <D87A64FA-64B1-3B23-BB43-ADE173C108C6> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                                  0x7fff952d3000 -     0x7fff95364ff7  libCoreStorage.dylib (471.20.7) <ECD8903C-F131-3A9A-BBF4-E124DA028909> /usr/lib/libCoreStorage.dylib
                                  0x7fff95365000 -     0x7fff95372ff7  com.apple.SpeechRecognitionCore (2.1.2 - 2.1.2) <551322E2-C1E4-3378-A218-F362985E3E3C> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
                                  0x7fff95a15000 -     0x7fff95a5bff7  libFontRegistry.dylib (134.1) <CE41D8C2-BEED-345C-BC4F-3775CC06C672> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                                  0x7fff95a5c000 -     0x7fff95afafff  com.apple.Metadata (10.7.0 - 917.35) <8CBD1D32-4F4B-3F9A-AC65-76F2B5376FBF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                                  0x7fff95afb000 -     0x7fff95b04fff  com.apple.DisplayServicesFW (2.9 - 372.1) <30E61754-D83C-330A-AE60-533F27BEBFF5> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
                                  0x7fff95b05000 -     0x7fff95b09ff7  libGIF.dylib (1237) <0990002D-CA11-325D-A432-3A333F2CC088> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                                  0x7fff95b0a000 -     0x7fff95b0cff7  libsystem_coreservices.dylib (9) <41B7C578-5A53-31C8-A96F-C73E030B0938> /usr/lib/system/libsystem_coreservices.dylib
                                  0x7fff95b54000 -     0x7fff95b56fff  com.apple.EFILogin (2.0 - 2) <3BA837D8-94F5-3240-9CF7-E40DC2808446> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
                                  0x7fff95bb2000 -     0x7fff95bb8fff  libsystem_trace.dylib (72.20.1) <840F5301-B55A-3078-90B9-FEFFD6CD741A> /usr/lib/system/libsystem_trace.dylib
                                  0x7fff95bb9000 -     0x7fff95c0afff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <450293F7-DAE7-3DD0-8F7C-71FC2FD72627> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                                  0x7fff95c14000 -     0x7fff95c16fff  libquarantine.dylib (76.20.1) <7AF90041-2768-378A-925A-D83161863642> /usr/lib/system/libquarantine.dylib
                                  0x7fff95c17000 -     0x7fff95c51ffb  com.apple.DebugSymbols (115 - 115) <6F03761D-7C3A-3C80-8031-AA1C1AD7C706> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                                  0x7fff95c9c000 -     0x7fff95d5fff7  libvMisc.dylib (516) <21497A28-8DCB-3EB8-BDAC-93C93382B0AA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                                  0x7fff95d60000 -     0x7fff95d66ff7  libsystem_networkextension.dylib (167.1.10) <29AB225B-D7FB-30ED-9600-65D44B9A9442> /usr/lib/system/libsystem_networkextension.dylib
                                  0x7fff95d67000 -     0x7fff95d69ff3  com.apple.SafariServices.framework (10600 - 10600.6.3) <54FC1B67-2013-3964-8937-4C29E66FC45E> /System/Library/PrivateFrameworks/SafariServices.framework/Versions/A/SafariServices
                                  0x7fff95de9000 -     0x7fff95e3dfff  libc++.1.dylib (120) <1B9530FD-989B-3174-BB1C-BDC159501710> /usr/lib/libc++.1.dylib
                                  0x7fff95eb6000 -     0x7fff95f2eff7  com.apple.SystemConfiguration (1.14 - 1.14) <06A8405D-53BA-30A9-BA8A-222099176091> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                                  0x7fff95f2f000 -     0x7fff95f75ff7  libauto.dylib (186) <A260789B-D4D8-316A-9490-254767B8A5F1> /usr/lib/libauto.dylib
                                  0x7fff95f76000 -     0x7fff95f7fff7  libsystem_notify.dylib (133.1.1) <61147800-F320-3DAA-850C-BADF33855F29> /usr/lib/system/libsystem_notify.dylib
                                  0x7fff95feb000 -     0x7fff96018fff  com.apple.CoreVideo (1.8 - 145.1) <18DB07E0-B927-3260-A234-636F298D1917> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                                  0x7fff96026000 -     0x7fff96033fff  libxar.1.dylib (255) <7CD69BB5-97BA-3858-8A8B-2F33F129E6E7> /usr/lib/libxar.1.dylib
                                  0x7fff96034000 -     0x7fff9611eff7  com.apple.QuickLookUIFramework (5.0 - 675.42) <86EE3D40-4554-3813-8C8B-B583A5F6F7E3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
                                  0x7fff9612b000 -     0x7fff9612efff  com.apple.help (1.3.3 - 46) <CA4541F4-CEF5-355C-8F1F-EA65DC1B400F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                                  0x7fff9612f000 -     0x7fff9612ffff  com.apple.Carbon (154 - 157) <9BF51672-1684-3FDE-A561-FC59A2864EF8> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                                  0x7fff96146000 -     0x7fff9615cff7  libsystem_asl.dylib (267) <F153AC5B-0542-356E-88C8-20A62CA704E2> /usr/lib/system/libsystem_asl.dylib
                                  0x7fff9615d000 -     0x7fff96168ff7  libcsfde.dylib (471.20.7) <44E51549-CECC-3C7B-867B-01901CA9C756> /usr/lib/libcsfde.dylib
                                  0x7fff9623c000 -     0x7fff96353fe7  libvDSP.dylib (516) <DFEDB210-49D1-3803-88A2-C61DB6A45C3D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                                  0x7fff96354000 -     0x7fff963e0ff7  libsystem_c.dylib (1044.10.1) <86FBED7A-F2C8-3591-AD6F-486DD57E6B6A> /usr/lib/system/libsystem_c.dylib
                                  0x7fff964df000 -     0x7fff964e3fff  libspindump.dylib (182.4) <929670EB-4963-3496-AD24-8B50E388803C> /usr/lib/libspindump.dylib
                                  0x7fff964e4000 -     0x7fff96505fff  com.apple.framework.Apple80211 (10.3 - 1030.71.6) <D3862426-2586-3DF7-BA75-9A184FCD74C4> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                                  0x7fff96506000 -     0x7fff9650dfff  com.apple.network.statistics.framework (1.2 - 1) <61B311D1-7F15-35B3-80D4-99B8BE90ACD9> /System/Library/PrivateFrameworks/NetworkStatistics.framework/Versions/A/NetworkStatistic s
                                  0x7fff9650e000 -     0x7fff96517ff3  com.apple.CommonAuth (4.0 - 2.0) <BA9F5A09-D200-3D18-9F4A-20C789291A30> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                                  0x7fff96564000 -     0x7fff9659ffff  com.apple.Symbolication (1.4 - 56045) <D64571B1-4483-3FE2-BD67-A91360F79727> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                                  0x7fff965a0000 -     0x7fff965caff7  libdispatch.dylib (442.1.4) <502CF32B-669B-3709-8862-08188225E4F0> /usr/lib/system/libdispatch.dylib
                                  0x7fff965cb000 -     0x7fff969a2fe7  com.apple.CoreAUC (211.1.0 - 211.1.0) <12645629-E065-388E-A6B5-094A240578CE> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                                  0x7fff969a3000 -     0x7fff969b4fff  libsystem_coretls.dylib (35.20.2) <6084A531-2523-39F8-B030-811FA1A32FB5> /usr/lib/system/libsystem_coretls.dylib
                                  0x7fff96ae8000 -     0x7fff96bdcfff  libFontParser.dylib (134.2) <9F57B025-AB9C-31DD-9D54-2D7AB1298885> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                                  0x7fff96bdd000 -     0x7fff96c9dff7  com.apple.backup.framework (1.6.4 - 1.6.4) <A67CE7D7-AAE4-3AC0-86B7-EAF403853D09> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                                  0x7fff96cfb000 -     0x7fff96d03ffb  libcopyfile.dylib (118.1.2) <0C68D3A6-ACDD-3EF3-991A-CC82C32AB836> /usr/lib/system/libcopyfile.dylib
                                  0x7fff96d04000 -     0x7fff96d28ff7  com.apple.Sharing (328.16 - 328.16) <F96C7040-5FAF-3BC6-AE1E-5BF9CBE786C4> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
                                  0x7fff96d29000 -     0x7fff96d76ff3  com.apple.CoreMediaIO (601.0 - 4760) <B2B71300-A863-30F8-8F00-B852CF843264> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                                  0x7fff96d77000 -     0x7fff96d7bfff  libpam.2.dylib (20) <E805398D-9A92-31F8-8005-8DC188BD8B6E> /usr/lib/libpam.2.dylib
                                  0x7fff96d8b000 -     0x7fff96db3fff  libsystem_info.dylib (459.20.1) <AEB3FE62-4763-3050-8352-D6F9AF961AE6> /usr/lib/system/libsystem_info.dylib
                                  0x7fff96e4c000 -     0x7fff970b6ff7  com.apple.security (7.0 - 57031.20.26) <6568520A-587D-3167-BB79-60CE6FEADC64> /System/Library/Frameworks/Security.framework/Versions/A/Security
                                  0x7fff970b7000 -     0x7fff9744fff7  com.apple.CoreFoundation (6.9 - 1153.18) <5C0892B8-9691-341F-9279-CA3A74D59AA0> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                  0x7fff974b6000 -     0x7fff974b6fff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <B92888D0-ED3F-3430-8F3A-6E56FD16C5F1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                                  0x7fff974b7000 -     0x7fff974bcff7  libunwind.dylib (35.3) <BE7E51A0-B6EA-3A54-9CCA-9D88F683A6D6> /usr/lib/system/libunwind.dylib
                                  0x7fff974bd000 -     0x7fff974ceff7  libz.1.dylib (55) <88C7C7DE-04B8-316F-8B74-ACD9F3DE1AA1> /usr/lib/libz.1.dylib
                                  0x7fff974cf000 -     0x7fff974e9ff7  liblzma.5.dylib (7) <1D03E875-A7C0-3028-814C-3C27F7B7C079> /usr/lib/liblzma.5.dylib
                                  0x7fff974ea000 -     0x7fff974eafff  com.apple.audio.units.AudioUnit (1.12 - 1.12) <E5335492-7EFE-31EA-BE72-4A9CEE68D58E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                                  0x7fff974eb000 -     0x7fff974edff7  com.apple.securityhi (9.0 - 55006) <5DB5773C-FC07-302C-98FE-4B80D88D481A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                                  0x7fff974ee000 -     0x7fff97632ff7  com.apple.QTKit (7.7.3 - 2890) <EA6DCA1E-CBAB-328F-B230-1F9B9104E110> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                                  0x7fff97633000 -     0x7fff97636ff7  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <BCC15965-7869-34F4-9019-9D0A41DD6AFF> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
                                  0x7fff97637000 -     0x7fff97662fff  com.apple.DictionaryServices (1.2 - 229) <F03DFAC6-6285-3176-9C6D-7CC50F8CD52A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                                  0x7fff97a01000 -     0x7fff97a05fff  libCoreVMClient.dylib (79.1) <201EF6DF-5074-3CB7-A361-398CF957A264> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                                  0x7fff97c8b000 -     0x7fff97cfdfff  com.apple.framework.IOKit (2.0.2 - 1050.20.2) <09C0518C-90DF-3FC3-96D6-34D35F72C8EF> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                                  0x7fff97df6000 -     0x7fff97df8fff  libRadiance.dylib (1237) <8F1E898B-74F6-3242-B929-CAF58AFCE319> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                                  0x7fff97df9000 -     0x7fff97e1dff7  com.apple.quartzfilters (1.10.0 - 1.10.0) <1AE50F4A-0098-34E7-B24D-DF7CB94073CE> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
                                  0x7fff97e3d000 -     0x7fff97e8cff7  libstdc++.6.dylib (104.1) <803F6AC8-87DC-3E24-9E80-729B551F6FFF> /usr/lib/libstdc++.6.dylib
                                  0x7fff97e8d000 -     0x7fff97e97ff7  com.apple.NetAuth (5.2 - 5.2) <2BBD749A-8E18-35B8-8E48-A90347C1CCA7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                                  0x7fff97e98000 -     0x7fff97fc8fff  com.apple.UIFoundation (1.0 - 1) <466BDFA8-0B9F-3AB0-989D-F9779422926A> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
                                  0x7fff97fc9000 -     0x7fff97fe9fff  com.apple.IconServices (47.1 - 47.1) <E83DFE3B-6541-3736-96BB-26DC5D0100F1> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
                                  0x7fff97fea000 -     0x7fff982ecffb  com.apple.GeoServices (1.0 - 1077.0.18) <2BBF8B44-DD46-3432-8C84-6D6AA004C233> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
                                  0x7fff982ed000 -     0x7fff982faff3  com.apple.ProtocolBuffer (1 - 228.0.1) <3429EB06-9F0E-355F-B9AB-F72879177398> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
                                  0x7fff98593000 -     0x7fff98607ffb  com.apple.securityfoundation (6.0 - 55126) <42589E18-D38C-3E25-B638-6E29740C224C> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                                  0x7fff98608000 -     0x7fff98631ffb  libxslt.1.dylib (13) <AED1143F-B848-3E73-81ED-71356F25F084> /usr/lib/libxslt.1.dylib
                                  0x7fff98632000 -     0x7fff9863bfff  libGFXShared.dylib (11.1.2) <0BAF2EA8-3BC4-3BF4-ABB6-A6E0A1F3F6A5> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                                  0x7fff9863d000 -     0x7fff98656ffb  com.apple.openscripting (1.4 - 162.1) <E6B42781-A556-355A-8A49-82A8D2B347FF> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                                  0x7fff98657000 -     0x7fff986b2ff7  libTIFF.dylib (1237) <690B205E-55D9-3F2C-B4EA-78B1AC3D3231> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                                  0x7fff986b3000 -     0x7fff986f3ff7  libGLImage.dylib (11.1.2) <260A4BF3-DC45-369C-A0CD-B667F9D17179> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                                  0x7fff9874c000 -     0x7fff987ebe27  com.apple.AppleJPEG (1.0 - 1) <6627DDD9-A8FE-3968-B23A-B6A29AA3919A> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
                                  0x7fff98847000 -     0x7fff988aeff7  com.apple.framework.CoreWiFi (3.0 - 300.4) <19269C1D-EB29-384A-83F3-7DDDEB7D9DAD> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                                  0x7fff98944000 -     0x7fff9894fff7  com.apple.DirectoryService.Framework (10.10 - 187) <85675744-B77D-37ED-805B-4BD0DD20845D> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
                                  0x7fff98950000 -     0x7fff98967fff  com.apple.ScriptingBridge (1.3.2 - 66) <89EF2F7B-077A-3AD4-A92B-C36C74B30CE5> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
                                  0x7fff98968000 -     0x7fff98970ff7  com.apple.icloud.FindMyDevice (1.0 - 1) <9CE67F85-2BA8-3093-97BA-07BF5C04A5D6> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
                                  0x7fff98971000 -     0x7fff989a9fff  com.apple.RemoteViewServices (2.0 - 99) <C9A62691-B0D9-34B7-B71C-A48B5F4DC553> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                                  0x7fff989aa000 -     0x7fff989aafff  com.apple.ApplicationServices (48 - 48) <5BF7910B-C328-3BF8-BA4F-CE52B574CE01> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                                  0x7fff989ed000 -     0x7fff989f8fff  com.apple.CommerceCore (1.0 - 376.24) <1B2B5206-43B6-3CA4-B057-8A7252CE6902> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
                                  0x7fff989f9000 -     0x7fff98a1eff7  libJPEG.dylib (1237) <8AC8EFA6-2283-3725-9F28-01537DF51766> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                                  0x7fff98b01000 -     0x7fff98b03fff  libsystem_configuration.dylib (699.1.5) <20F3B077-179D-3CB0-A3C1-C8602D53B4DB> /usr/lib/system/libsystem_configuration.dylib
                                  0x7fff98b04000 -     0x7fff98b06fff  com.apple.loginsupport (1.0 - 1) <DAAD7013-A19D-3858-BFF7-DE1DAF664401> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
                                  0x7fff98b10000 -     0x7fff98b1bff7  com.apple.speech.synthesis.framework (5.3.3 - 5.3.3) <A5640275-E2A6-3856-95EF-5F0DC440B10C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                                  0x7fff98bf3000 -     0x7fff98c05ff7  libsasl2.2.dylib (194.1) <35371406-75EF-304A-A073-956C40373555> /usr/lib/libsasl2.2.dylib
                                  0x7fff98c1e000 -     0x7fff98d10ff7  libiconv.2.dylib (42) <2A06D02F-8B76-3864-8D96-64EF5B40BC6C> /usr/lib/libiconv.2.dylib
                                  0x7fff98f5f000 -     0x7fff99087ff7  com.apple.coreui (2.1 - 308.6) <DEA5D3E1-D333-302B-A6CF-7643BFDFAED0> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                                  0x7fff990af000 -     0x7fff990ccfff  libsystem_kernel.dylib (2782.20.48) <EAFD7BD0-0C30-3E7D-9528-F9916BA0167C> /usr/lib/system/libsystem_kernel.dylib
                                  0x7fff990cd000 -     0x7fff99127ff7  com.apple.LanguageModeling (1.0 - 1) <ACA93FE0-A0E3-333E-AE3C-8EB7DE5F362F> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
                                  0x7fff99128000 -     0x7fff9912dffb  libheimdal-asn1.dylib (398.10.1) <A7B6447A-6680-3625-83C3-993B58D5C43F> /usr/lib/libheimdal-asn1.dylib
                                  0x7fff9912e000 -     0x7fff9912efff  com.apple.Accelerate (1.10 - Accelerate 1.10) <F1B96A61-7E4B-31BD-A35B-BA7EF1F16EF4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                                  0x7fff9912f000 -     0x7fff9914aff7  libCRFSuite.dylib (34) <D64842BE-7BD4-3D0C-9842-1D202F7C2A51> /usr/lib/libCRFSuite.dylib
                                  0x7fff9914b000 -     0x7fff99199fff  libcurl.4.dylib (83.1.2) <462767FC-C7F2-39F1-8C10-DA4114945F55> /usr/lib/libcurl.4.dylib
                                  0x7fff9919a000 -     0x7fff991a5fff  com.apple.AppSandbox (4.0 - 238.20.2) <BEFAB7F2-B189-391B-9B2D-FFF3EE2B77B6> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
                                  0x7fff991a6000 -     0x7fff991a7fff  libsystem_secinit.dylib (18) <581DAD0F-6B63-3A48-B63B-917AF799ABAA> /usr/lib/system/libsystem_secinit.dylib
                                  0x7fff991de000 -     0x7fff99206fff  libxpc.dylib (559.20.9) <D35D0DB2-D7BD-3BE4-8378-062BFE545E1D> /usr/lib/system/libxpc.dylib
                                  0x7fff9921e000 -     0x7fff9a1e0ffb  com.apple.WebCore (10600 - 10600.5.17) <587F71B3-28E7-3EBC-87B3-1F5E1D8C1349> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
                                  0x7fff9a223000 -     0x7fff9a2b9ff7  com.apple.cloudkit.CloudKit (283.67.2 - 283.67.2) <79F5AD38-61D5-30E6-96DC-974351D4195B> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
                                  0x7fff9a2ba000 -     0x7fff9a2bbff7  libsystem_blocks.dylib (65) <9615D10A-FCA7-3BE4-AA1A-1B195DACE1A1> /usr/lib/system/libsystem_blocks.dylib
                                  0x7fff9a2bc000 -     0x7fff9a3d5ffb  com.apple.CoreText (352.0 - 454.6) <D45790B0-E1A3-3C7D-8BA2-AB71D2CFA7FB> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                                  0x7fff9a3d6000 -     0x7fff9a425ff7  com.apple.opencl (2.4.2 - 2.4.2) <4A9574ED-15CF-3EBB-B4C0-D30F644D6C74> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                                  0x7fff9a426000 -     0x7fff9a62046f  libobjc.A.dylib (647) <759E155D-BC42-3D4E-869B-6F57D477177C> /usr/lib/libobjc.A.dylib
                                  0x7fff9a621000 -     0x7fff9ae7cff3  com.apple.CoreGraphics (1.600.0 - 779.11) <EFAB294A-B307-38C5-A3B0-159159B41057> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                                  0x7fff9ae7d000 -     0x7fff9af11fff  com.apple.ink.framework (10.9 - 213) <8E029630-1530-3734-A446-13353F0E7AC5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                                  0x7fff9af12000 -     0x7fff9afe8ff3  com.apple.DiskImagesFramework (10.10.1 - 396) <1149D3E1-CC6C-3177-916D-2BE066DC9344> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
                                  0x7fff9aff0000 -     0x7fff9aff0fff  com.apple.CoreServices (62 - 62) <C69DA8A7-B536-34BF-A93F-1C170E2C6D58> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                                  0x7fff9b071000 -     0x7fff9b076fff  libsystem_stats.dylib (163.20.16) <FBC3F80F-A0FB-3BD6-9A7E-800DE45F092E> /usr/lib/system/libsystem_stats.dylib
                                  0x7fff9b077000 -     0x7fff9b088fff  libcmph.dylib (1) <46EC3997-DB5E-38AE-BBBB-A035A54AD3C0> /usr/lib/libcmph.dylib
                                  0x7fff9b089000 -     0x7fff9b2f3ff7  com.apple.imageKit (2.6.1 - 848) <CBCF1292-3DC5-3A1F-A333-AAE462BBB3F3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
                                  0x7fff9b2f4000 -     0x7fff9b396fff  com.apple.Bluetooth (4.3.4 - 4.3.4f4) <A1120885-F31B-3C13-9B0D-2589F391CC7A> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
                                  0x7fff9b397000 -     0x7fff9b3a4ff7  libbz2.1.0.dylib (36) <2DF83FBC-5C08-39E1-94F5-C28653791B5F> /usr/lib/libbz2.1.0.dylib
                              External Modification Summary:
                                Calls made by other processes targeting this process:
                                  task_for_pid: 1
                                  thread_create: 0
                                  thread_set_state: 0
                                Calls made by this process:
                                  task_for_pid: 0
                                  thread_create: 0
                                  thread_set_state: 0
                                Calls made by all processes on this machine:
                                  task_for_pid: 12898
                                  thread_create: 1
                                  thread_set_state: 0
                              VM Region Summary:
                              ReadOnly portion of Libraries: Total=304.5M resident=235.1M(77%) swapped_out_or_unallocated=69.5M(23%)
                              Writable regions: Total=114.8M written=10.5M(9%) resident=41.3M(36%) swapped_out=0K(0%) unallocated=73.5M(64%)
                              REGION TYPE                      VIRTUAL
                              Activity Tracing                   2048K
                              CG backing stores                  7656K
                              CG image                            392K
                              CG shared images                    240K
                              CoreImage                             8K
                              CoreServices                        580K
                              CoreUI image data                    60K
                              Kernel Alloc Once                     8K
                              MALLOC                             70.2M
                              MALLOC (admin)                       32K
                              Memory Tag 242                       12K
                              OpenCL                               16K
                              STACK GUARD                        56.1M
                              Stack                              15.7M
                              VM_ALLOCATE                        17.1M
                              __DATA                             26.8M
                              __IMAGE                             528K
                              __LINKEDIT                         76.8M
                              __TEXT                            227.8M
                              __UNICODE                           552K
                              mapped file                        73.7M
                              shared memory                         4K
                              TOTAL                             576.0M
