2 Replies Latest reply on Jan 26, 2015 1:22 PM by fcrussell
    Stepping thru a list of variables
    fcrussell
      How can one step thru a list of variables without a long list of "If" statements? Each var gets a string consisting of one or more paragraphs used to fill a text box. The var is selected from a hierarchical list box.
      EXample:
      if (selectedValue == 1) {var TTHCov = dialogObject.TTHCov1;
        } else if (selectedValue == 2) {var TTHCov = dialogObject.TTHCov2;
        } else if (selectedValue == 3) {var TTHCov = dialogObject.TTHCov3;
        } else if (selectedValue == 4) {var TTHCov = dialogObject.TTHCov4;
        } else if (selectedValue == 5) {var TTHCov = dialogObject.TTHCov5;
        } else if (selectedValue == 6) {var TTHCov = dialogObject.TTHCov6;
        } else if (selectedValue == 7) {var TTHCov = dialogObject.TTHCov7;
        } else if (selectedValue == 8) {var TTHCov = dialogObject.TTHCov8;
        } else if (selectedValue == 9) {var TTHCov = dialogObject.TTHCov9;
        } else if (selectedValue == 10) {var TTHCov = dialogObject.TTHCov10;
        } else if (selectedValue == 11) {var TTHCov = dialogObject.TTHCov11;
        } else if (selectedValue == 12) {var TTHCov = dialogObject.TTHCov12;
        } else if (selectedValue == 13) {var TTHCov = dialogObject.TTHCov13;
        } else if (selectedValue == 14) {var TTHCov = dialogObject.TTHCov14;
        } else if (selectedValue == 15) {var TTHCov = dialogObject.TTHCov15;
        } else if (selectedValue == 16) {var TTHCov = dialogObject.TTHCov16;
        } else if (selectedValue == 17) {var TTHCov = dialogObject.TTHCov17;
        } else if (selectedValue == 18) {var TTHCov = dialogObject.TTHCov18;
        } else if (selectedValue == 19) {var TTHCov = dialogObject.TTHCov19;
        } else if (selectedValue == 20) {var TTHCov = dialogObject.TTHCov20;
        } else if (selectedValue == 21) {var TTHCov = dialogObject.TTHCov21;
        } else if (selectedValue == 22) {var TTHCov = dialogObject.TTHCov22;
        } else if (selectedValue == 23) {var TTHCov = dialogObject.TTHCov23;
        } else if (selectedValue == 24) {var TTHCov = dialogObject.TTHCov24;
        } else if (selectedValue == 25) {var TTHCov = dialogObject.TTHCov25;
        } else if (selectedValue == 26) {var TTHCov = dialogObject.TTHCov26;
        } else if (selectedValue == 27) {var TTHCov = dialogObject.TTHCov27;
        } else if (selectedValue == 28) {var TTHCov = dialogObject.TTHCov28;
        } else if (selectedValue == 29) {var TTHCov = dialogObject.TTHCov29;
        } else if (selectedValue == 30) {var TTHCov = dialogObject.TTHCov30;
        } else if (selectedValue == 31) {var TTHCov = dialogObject.TTHCov31;
        } else if (selectedValue == 32) {var TTHCov = dialogObject.TTHCov32;
        } else if (selectedValue == 33) {var TTHCov = dialogObject.TTHCov33;
        } else if (selectedValue == 34) {var TTHCov = dialogObject.TTHCov34;
        } else if (selectedValue == 35) {var TTHCov = dialogObject.TTHCov35;
        } else if (selectedValue == 36) {var TTHCov = dialogObject.TTHCov36;
        } else if (selectedValue == 37) {var TTHCov = dialogObject.TTHCov37;
        } else if (selectedValue == 38) {var TTHCov = dialogObject.TTHCov38;
        } else if (selectedValue == 39) {var TTHCov = dialogObject.TTHCov39;
        } else if (selectedValue == 40) {var TTHCov = dialogObject.TTHCov40;
        • 1. Re: Stepping thru a list of variables
          Magus069 Level 4
          Hi there, your list values are stored in an Object type, right?
          So, e.g. if you have your data list enumerated like this :
          var TTH = {"TTHCov1" : "value1",
                             "TTHCov2": "value2",
          By using a loop with the for statement, you can browse through the whole object
          for (var obj in TTH){
               if (selectedValue == TTH[obj]){
                    //This is the value selected inside the data object
          Hope this help!
          • 2. Re: Stepping thru a list of variables
            fcrussell Level 1
            HI Magus069,
            That's exactly what I did and it works great!
            Fred
