0 Replies Latest reply on Jan 20, 2015 4:41 PM by viktorb40932833
    how to export  sequence of  identical audio files?
    viktorb40932833
      Adobe Premier Pro CC 7.2.1
      I have a big audio mix on the soundtrack consisting of many short different  same duration audio files. now I need to export a sequence of identical files into separate audio track for further processing in to the DAW. the best way to do it is change the color of each identical audio, but I have not found this function or mute from project or just see titles or set up so that when I add  new audio file  it created a separate channel in the mixer not available for other or something like this... otherwise I must push each audio to see title to drag sequence of identical audio file to separate channel and mute others. my mistake is that from  beginning I did not put the identical files to separate channel and now everything is mixed. is there any solution?
