2 Replies Latest reply on Feb 27, 2007 1:20 AM by David_S_deB
    Turn off CSS compile warning
    David_S_deB Level 1
      Hi all,
      How do I turn off the compiler warning about unused CSS styles. I need the solution for both locally compiled SWF and those compiled in Flex Data Services. flex-config.xml doesn´t have the node option.
      David
        • 1. Re: Turn off CSS compile warning
          Try the following option:
          -compiler.show-unused-type-selector-warnings
          alias -show-unused-type-selector-warnings
          toggle whether warnings generated from unused type selectors are displayed
          Or if you want the system to not remove the styles at all:
          -compiler.keep-all-type-selectors
          alias -keep-all-type-selectors
          disables the pruning of unused type selectors (advanced)
          • 2. Re: Turn off CSS compile warning
            David_S_deB Level 1
            Thanks Brent for your quick response. That works well with the compile locally option. I found the solution if you are compiling with FDS.
            Its in the docs under:
            Building and Deploying Flex 2 Applications > Building Flex Applications > Flex 2 SDK and Flex Data Services Configuration > Flex Data Services configuration
            You can change the flex-webtier-config.xml file and turn the production setting on, or use the queryString parameter (showAllWarnings=false) if you are just testing.
            Cheers
            David
