3 Replies Latest reply on Feb 27, 2007 3:13 PM by Newsgroup_User
    TEXT AROUND PICTURE
    valla23 Level 1
      help me please!!!! how can i make text to go around picture, in a circular shape. My photo has a circular shape and i wnat to put some text around this circular shape using fireworks 8 but i don't know how to do it. Can somebody please help me . Tank you
        • 1. Re: TEXT AROUND PICTURE
          Level 7
          > how to do it.
          Draw a (vector) circle of an appropriate size. Make both edge and fill
          transparent. Type out the text. Select both the text and the circle.
          Text>Attach to Path[1]. Adjust as needed.
          [1] That's for FW6; it may have changed, but the command should still be
          there. The shortcut is Ctrl-Shift-Y.
          Joe Makowiec
          http://makowiec.net/
          Email: http://makowiec.net/email.php
          • 2. Re: TEXT AROUND PICTURE
            abeall Level 3
            Did you try Text > Attach to path? Just create a circle path and some text, select them both, and try that.
            • 3. Re: TEXT AROUND PICTURE
              Level 7
              What you want to do is attach text to a path.
              Draw a circle and type some text. Select both then go to the top menu
              bar - Text > Attach to Path.
              Play with the settings in the property panel to make it fit like you want.
              alex
