4 Replies Latest reply on Jan 21, 2015 3:32 PM by philc452
    GTX680-Mac_What are the Correct Drivers for 10.8.5?
    philc452
      GTX680 on MacPro5, mid 2010.... and having issues. What are the correct drivers for Mac GeForce GTX680? And is there another driver for the OS as well? Or not in use when using GTX?
      I can not export without my system completely shutting down....many attempts...AME and direct. Using CUDA.
      Phil
        • 1. Re: GTX680-Mac_What are the Correct Drivers for 10.8.5?
          philc452 Level 1
          Update:
          OS 10.8.5 Mtn Lion
          PPro 2014_2 build 8.2
          current Cuda: 6.5.36
          can not export using CUDA or OpenCL....h264 as QT...h264 as mp4. Now trying software only export. I suspect CUDA driver issue as I was having stuttering playback with clips in source viewer. If I load clip into a seq...it would play fine...and then after that exercise would also play in Source viewer. I checked System Prefs and CUDA said update was avail-6.5.36...this seemed to fix the playback issue...but still having crash during export. And was hanging on export before the driver update.
          Other note....trashed preferences a couple times.
          Need some advice, gettng desparate...dead in the water and as usual...lots to do
          • 2. Re: GTX680-Mac_What are the Correct Drivers for 10.8.5?
            Alexander Eberhard Level 1
            Try latest Nvdia for GTX 680 series, normally no extra cube drivers need to be installed:
            NVIDIA Treiber Download
            • 3. Re: GTX680-Mac_What are the Correct Drivers for 10.8.5?
              philc452 Level 1
              According to NVIDIA I have all the current drivers:
              NVIDIA Web Driver: 313.01.04f01
              GTX680: 6.5.37
              What I don't understand is :
              Supports all NVIDIA products available on Mac HW.
              Note: this driver does not support the older generation GPUs with SM1.x. Please download the equivalent CUDA driver 6.5.36 which supports SM1.x.
              WHAT IS SM1.x? and how can I tell if it applies top me
              • 4. Re: GTX680-Mac_What are the Correct Drivers for 10.8.5?
                philc452 Level 1
                I'm not sure of the proper process to post crash logs so apologize for long text...but I am really needing help
                MacPro5, mid 2010
                OS 10.8.5 Mtn Lion
                64 GB RAM
                current Cuda: 6.5.37
                GTX680-2GB RAM
                3min seq...5760x864...I know large.  Edit clips...mostly mp4 with lots of repo and scaling but no other FX. Export to h284 or mp4 crashes system...tried OpenCL...CUDA...AME and Direct...but some success (vry slow) with softwr only. Can not export. Did cineform in 30sec chunk and struggle thru it.
                Tried different CUDA versions...reinstalled CC2014_2
                Any ideas?
                Here is one of the many logs:
                Interval Since Last Panic Report:  263815 sec
                Panics Since Last Report:          5
                Anonymous UUID:                    AD95F73E-7904-DFA2-7B2C-2376C652F401
                Tue Jan 20 20:29:34 2015
                panic(cpu 2 caller 0xffffff8002eb8945): Kernel trap at 0xffffff7f844b4633, type 14=page fault, registers:
                CR0: 0x0000000080010033, CR2: 0x0000000000000008, CR3: 0x0000000191d2f011, CR4: 0x00000000000206e0
                RAX: 0xffffff8080325628, RBX: 0xffffff807b2fae00, RCX: 0x0000000000000000, RDX: 0xffffff87093e3778
                RSP: 0xffffff87093e3740, RBP: 0xffffff87093e37b0, RSI: 0xffffff87093e3778, RDI: 0x0000000000000001
                R8:  0xffffff87093e32a0, R9:  0xffffff87093e3298, R10: 0xffffff8080325608, R11: 0x0000000000000000
                R12: 0xffffff80783064c0, R13: 0xffffff80783064b0, R14: 0xffffff808e702608, R15: 0xffffff8078306400
                RFL: 0x0000000000010283, RIP: 0xffffff7f844b4633, CS:  0x0000000000000008, SS:  0x0000000000000010
                Fault CR2: 0x0000000000000008, Error code: 0x0000000000000002, Fault CPU: 0x2
                Backtrace (CPU 2), Frame : Return Address
                0xffffff87093e33e0 : 0xffffff8002e1d636
                0xffffff87093e3450 : 0xffffff8002eb8945
                0xffffff87093e3620 : 0xffffff8002ecebfd
                0xffffff87093e3640 : 0xffffff7f844b4633
                0xffffff87093e37b0 : 0xffffff7f844b38f4
                0xffffff87093e3860 : 0xffffff7f844c0668
                0xffffff87093e38d0 : 0xffffff7f84486c60
                0xffffff87093e3910 : 0xffffff7f8447c20f
                0xffffff87093e3a90 : 0xffffff7f844a8a0b
                0xffffff87093e3b50 : 0xffffff7f8447aea1
                0xffffff87093e3ba0 : 0xffffff800326f789
                0xffffff87093e3bc0 : 0xffffff8003270d30
                0xffffff87093e3c20 : 0xffffff800326e74f
                0xffffff87093e3d70 : 0xffffff8002e98c21
                0xffffff87093e3e80 : 0xffffff8002e20b4d
                0xffffff87093e3eb0 : 0xffffff8002e10448
                0xffffff87093e3f00 : 0xffffff8002e1961b
                0xffffff87093e3f70 : 0xffffff8002ea6546
                0xffffff87093e3fb0 : 0xffffff8002ecf473
                      Kernel Extensions in backtrace:
                         com.apple.GeForceWeb(8.1.7)[B1C23155-23F5-39D0-8037-7FFB273DA8C6]@0xffffff7f84469000->0xf fffff7f84534fff
                            dependency: com.apple.iokit.IOPCIFamily(2.8)[2FAEA49C-EA4C-39C6-9203-FC022277A43C]@0xffffff7f83417000
                            dependency: com.apple.iokit.IONDRVSupport(2.3.7)[F16E015E-1ABE-3C40-AC71-BC54F4BE442E]@0xffffff7f835b c000
                            dependency: com.apple.iokit.IOGraphicsFamily(2.3.7)[9928306E-3508-3DBC-80A4-D8F1D87650D7]@0xffffff7f8 3579000
                            dependency: com.apple.NVDAResmanWeb(8.1.7)[CA80D169-93F0-36E0-AAD0-9A255D45C036]@0xffffff7f835d0000
                BSD process name corresponding to current thread: Adobe Premiere P
                Boot args: nvda_drv=1 darkwake=8
                Mac OS version:
                12F45
                Kernel version:
                Darwin Kernel Version 12.5.0: Sun Sep 29 13:33:47 PDT 2013; root:xnu-2050.48.12~1/RELEASE_X86_64
                Kernel UUID: EA38B02E-2B88-309F-BA68-1DE29F605DD8
                Kernel slide:     0x0000000002c00000
                Kernel text base: 0xffffff8002e00000
                System model name: MacPro5,1 (Mac-F221BEC8)
                System uptime in nanoseconds: 1380434831924
                last loaded kext at 248531634318: com.apple.filesystems.msdosfs 1.8.1 (addr 0xffffff7f84f9a000, size 65536)
                last unloaded kext at 308976154466: com.apple.filesystems.msdosfs 1.8.1 (addr 0xffffff7f84f9a000, size 57344)
                loaded kexts:
                com.nvidia.CUDA 1.1.0
                com.paceap.kext.pacesupport.snowleopard 5.8
                com.Cycling74.driver.Soundflower 1.6.6
                com.logmein.driver.LogMeInSoundDriver 1.0.3
                com.rogueamoeba.HermesAudio 4.1.0
                com.sonnettech.driver.SonnetSATA 2.2.9
                com.owc.driver.Accelsior 1.0 b2
                com.apple.filesystems.smbfs 1.8.4
                com.apple.driver.AppleHWSensor 1.9.5d0
                com.apple.filesystems.autofs 3.0
                com.apple.iokit.IOBluetoothSerialManager 4.1.7f2
                com.apple.driver.AppleTyMCEDriver 1.0.2d2
                com.apple.driver.AGPM 100.13.14
                com.apple.driver.AudioAUUC 1.60
                com.apple.driver.AppleMikeyHIDDriver 124
                com.apple.driver.AppleUpstreamUserClient 3.5.12
                com.apple.iokit.IOUserEthernet 1.0.0d1
                com.apple.driver.AppleHDA 2.4.7fc4
                com.apple.driver.AppleMCCSControl 1.1.11
                com.apple.GeForceWeb 8.1.7
                com.apple.driver.AppleMikeyDriver 2.4.7fc4
                com.apple.Dont_Steal_Mac_OS_X 7.0.0
                com.apple.iokit.BroadcomBluetoothHostControllerUSBTransport 4.1.7f4
                com.apple.driver.ApplePolicyControl 3.4.5
                com.apple.driver.AppleSMBusPCI 1.0.11d1
                com.apple.driver.AppleLPC 1.6.3
                com.apple.driver.ACPI_SMC_PlatformPlugin 1.0.0
                com.apple.iokit.IOUSBAttachedSCSI 1.0.4
                com.apple.iokit.SCSITaskUserClient 3.5.6
                com.apple.driver.XsanFilter 404
                com.apple.iokit.IOAHCIBlockStorage 2.3.5
                com.apple.driver.AppleFWOHCI 4.9.9
                com.apple.AppleFSCompression.AppleFSCompressionTypeDataless 1.0.0d1
                com.apple.driver.AppleUSBHub 635.4.0
                com.apple.AppleFSCompression.AppleFSCompressionTypeZlib 1.0.0d1
                com.apple.BootCache 34
                com.apple.driver.AirPort.Brcm4331 615.20.17
                com.apple.driver.Intel82574L 2.3.0b5
                com.apple.driver.AppleAHCIPort 2.6.6
                com.apple.driver.AppleUSBEHCI 621.4.6
                com.apple.driver.AppleUSBUHCI 621.4.0
                com.apple.driver.AppleUSBXHCI 635.4.0
                com.apple.driver.AppleRTC 1.5
                com.apple.driver.AppleHPET 1.8
                com.apple.driver.AppleACPIButtons 1.8
                com.apple.driver.AppleSMBIOS 1.9
                com.apple.driver.AppleACPIEC 1.8
                com.apple.driver.AppleAPIC 1.7
                com.apple.driver.AppleIntelCPUPowerManagementClient 214.0.0
                com.apple.nke.applicationfirewall 4.0.39
                com.apple.security.quarantine 2.1
                com.apple.driver.AppleIntelCPUPowerManagement 214.0.0
                com.apple.kext.triggers 1.0
                com.apple.iokit.IOSerialFamily 10.0.6
                com.apple.driver.DspFuncLib 2.4.7fc4
                com.apple.iokit.IOSurface 86.0.4
                com.apple.iokit.IOBluetoothFamily 4.1.7f2
                com.apple.nvidia.gk100halWeb 8.1.7
                com.apple.NVDAResmanWeb 8.1.7
                com.apple.iokit.IOAudioFamily 1.9.2fc7
                com.apple.kext.OSvKernDSPLib 1.12
                com.apple.iokit.IOBluetoothHostControllerUSBTransport 4.1.7f2
                com.apple.driver.AppleSMBusController 1.0.11d1
                com.apple.driver.AppleGraphicsControl 3.4.5
                com.apple.iokit.IONDRVSupport 2.3.7
                com.apple.iokit.IOFireWireIP 2.2.5
                com.apple.iokit.IOATAFamily 2.5.1
                com.apple.driver.AppleHDAController 2.4.7fc4
                com.apple.iokit.IOGraphicsFamily 2.3.7
                com.apple.iokit.IOHDAFamily 2.4.7fc4
                com.apple.driver.AppleSMC 3.1.5d4
                com.apple.driver.IOPlatformPluginLegacy 1.0.0
                com.apple.driver.IOPlatformPluginFamily 5.4.1d13
                com.apple.iokit.IOSCSIBlockCommandsDevice 3.5.6
                com.apple.driver.AppleUSBHIDKeyboard 170.2.4
                com.apple.driver.AppleHIDKeyboard 170.2.4
                com.apple.iokit.IOUSBHIDDriver 623.4.0
                com.apple.driver.AppleUSBMergeNub 621.4.6
                com.apple.driver.AppleUSBComposite 621.4.0
                com.apple.iokit.IOSCSIMultimediaCommandsDevice 3.5.6
                com.apple.iokit.IOBDStorageFamily 1.7
                com.apple.iokit.IODVDStorageFamily 1.7.1
                com.apple.iokit.IOCDStorageFamily 1.7.1
                com.apple.iokit.IOAHCISerialATAPI 2.5.5
                com.apple.iokit.IOSCSIArchitectureModelFamily 3.5.6
                com.apple.iokit.IOFireWireFamily 4.5.5
                com.apple.iokit.IO80211Family 530.5
                com.apple.iokit.IONetworkingFamily 3.0
                com.apple.iokit.IOUSBUserClient 630.4.4
                com.apple.iokit.IOAHCIFamily 2.5.1
                com.apple.iokit.IOUSBFamily 635.4.0
                com.apple.driver.AppleEFINVRAM 2.0
                com.apple.driver.AppleEFIRuntime 2.0
                com.apple.iokit.IOHIDFamily 1.8.1
                com.apple.iokit.IOSMBusFamily 1.1
                com.apple.security.sandbox 220.3
                com.apple.kext.AppleMatch 1.0.0d1
                com.apple.security.TMSafetyNet 7
                com.apple.driver.DiskImages 345
                com.apple.iokit.IOStorageFamily 1.8
                com.apple.driver.AppleKeyStore 28.21
                com.apple.driver.AppleACPIPlatform 1.8
                com.apple.iokit.IOPCIFamily 2.8
                com.apple.iokit.IOACPIFamily 1.4
                com.apple.kec.corecrypto 1.0
                Model: MacPro5,1, BootROM MP51.007F.B03, 8 processors, Quad-Core Intel Xeon, 2.4 GHz, 64 GB, SMC 1.39f11
                Graphics: NVIDIA GeForce GTX 680, NVIDIA GeForce GTX 680, PCIe, 2048 MB
                Memory Module: DIMM 1, 16 GB, DDR3 ECC, 1066 MHz, 0x0000, 0x000000000000000000000000000000000000
                Memory Module: DIMM 2, 16 GB, DDR3 ECC, 1066 MHz, 0x8394, 0x393731393830410000000000000000000000
                Memory Module: DIMM 5, 16 GB, DDR3 ECC, 1066 MHz, 0x0000, 0x000000000000000000000000000000000000
                Memory Module: DIMM 6, 16 GB, DDR3 ECC, 1066 MHz, 0x80AD, 0x484D54343247523741465234432D48392020
                AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.106.98.100.17)
                Bluetooth: Version 4.1.7f2 12718, 3 service, 21 devices, 2 incoming serial ports
                Network Service: Ethernet, Ethernet, en0
                Network Service: FireWire, FireWire, fw0
                PCI Card: NVIDIA GeForce GTX 680, sppci_displaycontroller, Slot-1
                PCI Card: NVIDIA GeForce GTX 680, NVDA,Parent, Slot-1
                PCI Card: pci1b73,1100, Slot-2
                PCI Card: pci1b4b,9230, sppci_ahci, Slot-3
                PCI Card: Sonnet Tempo SATA E4P, sppci_ide, Slot-4
                Serial ATA Device: HL-DT-ST DVD-RW GH61N
                Serial ATA Device: OWC Mercury Accelsior PCIe SSD, 119.88 GB
                Serial ATA Device: Hitachi HDS723020BLA642, 4 TB
                Serial ATA Device: WDC WD1001FALS-41Y6A0, 1 TB
                Serial ATA Device: Samsung SSD 840 EVO 500GB, 500.11 GB
                Serial ATA Device: MARVELL VIRTUALL
                USB Device: G-RAID, 0x4971, 0x8027, 0x07400000 / 3
                USB Device: G-RAID, 0x4971, 0x8027, 0x07200000 / 2
                USB Device: G-RAID, 0x4971, 0x8027, 0x07100000 / 1
                USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfa200000 / 2
                USB Device: Apple Keyboard, apple_vendor_id, 0x0220, 0xfa220000 / 3
                USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0x5a100000 / 2
                USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0x5a110000 / 3
                USB Device: CTH-670, 0x056a  (WACOM Co., Ltd.), 0x00df, 0x1d100000 / 2
                USB Device: USB Receiver, 0x046d  (Logitech Inc.), 0xc50a, 0x3d100000 / 2
                FireWire Device: built-in_hub, 800mbit_speed
