3 Replies Latest reply on Jan 21, 2015 7:45 AM by Mylenium
    Error (26 :: 0) - Crashes upon opening
    deanrockne
      Hi, I recently got a file from a freelancer that produces a couple errors when I attempt to open it (screen shots below).  I had him resend files and he claims they work fine for him.  I was able to import the problem project file into a new project, but that generated the same errors.  It didn't crash immediately, but it does crash if I attempt to open certain comps.  I know that I am missing several effects, but I'm unable to get a full list of what they are (so far it looks like Plexus, Particular, MBL, RSMB Pro, Sapphire Suite).  I am currently using the latest build of AE.  I do not know what version the freelancer is using.  In researching this issue I came across a problem with Knoll UnMult, but supposedly that issue was fixed in 13.1.1 and I'm on 13.2.
      Could not having the required effects cause crashes like this?
      Is this freelancer sandbagging me in an attempt to win future business doing the edits?
        • 1. Re: Error (26 :: 0) - Crashes upon opening
          Your freelancer can generate a report about the effects used using the collect files option. Otherwise we can't really know what is going on, but it looks like a referenced layer in an effect is breaking down.
          Mylenium
          • 2. Re: Error (26 :: 0) - Crashes upon opening
            deanrockne Level 1
            Thanks Mylenium, I had him generate a list:
            Rendering plug-ins:
              Classic 3D
            Effects used:  55
            Effect:  3D Point Control
            Effect:  Alpha Levels
            Effect:  BCC UpRez
            Effect:  Box Blur
            Effect:  Brightness & Contrast
            Effect:  Card Wipe
            Effect:  Card Wipe Master Control
            Effect:  CC Ball Action
            Effect:  CC Light Sweep
            Effect:  Checkbox Control
            Effect:  Color Control
            Effect:  Color Key
            Effect:  Curves
            Effect:  Drop Shadow
            Effect:  Fast Blur
            Effect:  Fill
            Effect:  Fractal Noise
            Effect:  Glow
            Effect:  Gradient Ramp
            Effect:  Grid
            Effect:  Invert
            Effect:  Iris Wipe
            Effect:  Levels
            Effect:  Linear Wipe
            Effect:  Magic Bullet Looks
            Effect:  Motion Tile
            Effect:  Nodes 2
            Effect:  Noise
            Effect:  Optical Flares
            Effect:  Paint
            Effect:  Particular
            Effect:  Plexus
            Effect:  Plexus Lines Renderer
            Effect:  Plexus Noise Effector
            Effect:  Plexus Points Renderer
            Effect:  Plexus Primitives Object
            Effect:  Plexus Toolkit
            Effect:  Plexus Transform
            Effect:  Point Control
            Effect:  Puppet
            Effect:  Roughen Edges
            Effect:  RSMB Pro
            Effect:  S_FilmDamage
            Effect:  S_Vignette
            Effect:  Scribble
            Effect:  Sharpen
            Effect:  Shatter
            Effect:  Slider Control
            Effect:  Three Color Ramp
            Effect:  Threshold
            Effect:  Tint
            Effect:  Turbulent Displace
            Effect:  Turbulent Noise
            Effect:  VC Color Vibrance
            Effect:  Vegas
            • 3. Re: Error (26 :: 0) - Crashes upon opening
              Do you have all the commercial plug-ins listed in the report? There's quite a lot of them in there. If not it might be a good idea to at least install their demo versions...
              BorisFX Continuum Complete
              Effect:  BCC UpRez
              Red Giant Magic Bullet Looks
              FX Factory Yanobox Nodes 2
              Effect:  Nodes 2
              Video CoPilot
              Trapcode Particular
              Effect:  Particular
              Plexus
              Effect:  Plexus
              RevisionFX ReelSmart MotionBlur
              Effect:  RSMB Pro
              GenArts Sapphire
              Effect:  S_Vignette
              Video CoPilot
              There are also some expression controls, so double-check whether you are not seeing a breakdown there.
              Mylenium
