1 Reply Latest reply on Feb 26, 2007 10:33 AM by Newsgroup_User
    HELP ME with CFLogin and Application.cfc
    fbs70
      I am trying to get a login scenario that is similar in functionality to what adobe.com has. When you click on account it takes you to a login page where you enter your username and password. once you login you are directed to you a “YOUR ACCOUNT PAGE” which is in a secure directory. All of this I can do with the login scenario that I have created using an application.cfc within my personal directory.
      But what I am having a hard time doing is when the user returns to the home page of the site, I would like to display that the user is logged in with a “Welcome Username” and a link to their “Account” page as well as a logout link.
      What I have in my root application.cfc is this
      <webroot>/Application.cfc
      <cfcomponent>
      <!--- set Application settings --->
      <cfset this.name="OurCompany">
      <cfset this.loginStorage="session">
      <cfset this.sessionManagement="true">
      <cfset this.setClientCookies="false">
      <cfset this.sessionTimeout = createTimeSpan(0,0,30,0)> <!--- 30 minutes --->
      <cfset this.applicationTimeout=CreateTimeSpan(0,0,30,0)> <!--- 30 minutes --->
      <cferror type="request" template="/error/errorrequest.cfm" mailto="me@OurCompany.com">
      <cferror type="exception" template="/error/errorexception.cfm" mailto=" me@ OurCompany.com ">
      <cferror type="validation" template="/error/errorvalidation.cfm" mailto=" me@ OurCompany .com ">
      <cffunction name="OnApplicationStart" output="false" returntype="void">
      <cfset Application.dataSource = "ourDB">
      <cfset Application.companyname="Company Name">
      </cffunction>
      <cffunction name="onRequestStart" returnType="boolean" output="true">
      <cfreturn true>
      </cffunction>
      <cffunction name="onError" returntype="void" output="false">
      <cfargument name="exception" required="yes">
      <cfargument name="eventName" type="string" required="yes">
      <!--- use the cflog tag to record info on the error --->
      <cfif arguments.eventName is "">
      <cflog file="#this.name#" type="error" text="#arguments.exception.message#">
      <cfelse>
      <cflog file="#this.name#" type="error" text="Error in Method [#arguments.eventname#] #arguments.exception.message#">
      </cfif>
      <!--- Let the <cferror> tags to their job --->
      <cfthrow object="#arguments.exception#">
      </cffunction>
      </cfcomponent>
      I also have an ApplicationProxy.cfc which just extends my Application.cfc
      <webroot>/ApplicationProxy.cfc
      <cfcomponent extends="Application">
      </cfcomponent>
      Personal/Application.cfc (directory that i want secured)
      <cfcomponent extends="ApplicationProxy">
      <cfset this.name=" OurCompany_personal">
      <cfinclude template="/forceuserlogin.cfm">
      <cfreturn true>
      </cffunction>
      </cfcomponent>
        • 1. Re: HELP ME with CFLogin and Application.cfc
          Level 7
          > ?YOUR ACCOUNT PAGE? which is in a secure directory. All of this I can do with
          > personal directory.
          > ?Welcome Username? and a link to their ?Account? page as well as a logout link.
          > <cfcomponent>
          > OurCompany.com ">
          > OurCompany .com ">
          > </cffunction>
          > <cfreturn true>
          > </cffunction>
          > <cfelse>
          > </cfif>
          > </cffunction>
          > </cfcomponent>
          > </cfcomponent>
          > <cfreturn true>
          > </cffunction>
          > </cfcomponent>
          you can store the login values in session variables:
          inside your login code set some session vars, i.e.
          session.userdata.username = "xxx", etc (if you are using the cflogin
          framework, set these before the <cfloginuser> tag). in your main
          Application.cfc in OnRequestStart check for existance of
          session.userdata structure -> if it exists, then display
          session.userdata.username linked to personal account page; if it doesn't
          display a Log In link to the login page...
          Azadi Saryev
          Sabai-dee.com
          Vientiane, Laos
          http://www.sabai-dee.com
