1 Reply Latest reply on Jan 21, 2015 3:38 AM by cc_merchant
    I used to export cut clips to tape (version 9.0)  but recently I bought the 13.0 version of PREMIERE and after cutting (etc) - to keep having the exàct same video-quality as what I IMPORTED/CAPTURED via an (analog) source - I export cut material simply to
    ronnyv41862055
      I used to export cut clips to tape (version 9.0)  but recently I bought the 13.0 version of PREMIERE and after cutting (etc) - to keep having the exàct same video-quality as what I IMPORTED/CAPTURED via an (analog) source - I export cut material simply to external HDs (so, actually to the computer)... but whatever I am trying  I notice that when I check the export-material with the original clip the first is NOT ONLY SMALLER but ALSO DOES NOT SEEM TO HAVE THE SAME RESOLUTION, DETAILNESS, SHARPNESS (or whatever you may call it) as what I origanally captured !! ... What am I  doing wrong? WHICH SETTINGS DO I HAVE TO MAKE - at least- IN ORDER TO KEEP THE SAME IMAGE-QUALITY (or even to enhance it) IN STORING ON THE COMPUTER ?!     Thanks, RVH
