1 Reply Latest reply on Feb 26, 2015 4:01 AM by armeller32351712
    Creative Cloud  con Yosemite
    Giuseppe Rampazzo
      Qual'è il problema?
      06/18/13 08:32:58:792 | [INFO] |  | OOBE | DE |  |  |  | 1743587 | DEVersion: 5.0.0.0
      06/18/13 08:32:58:807 | [INFO] |  | OOBE | DE |  |  |  | 1743587 | Loading library from /Applications/Utilities/Adobe Application Manager/DECore/DE5/Setup.dylib
      [       0] Tue Jun 18 08:32:58 2013  INFO
      ::START TIMER:: [Total Timer]
      CHECK: Single instance running
      CHECK : Credentials
      Load Deployment File
      CHECK : Another Native OS installer already running
      Create Required Folders
      Assuming uninstall mode
      Lookup for master payload
      [       0] Tue Jun 18 08:32:58 2013 ERROR
      DW040: The product "{7F311193-9368-453B-989F-939FEBF374CC}" is not installed. Cannot proceed with the uninstall
      :: END TIMER :: [Total Timer] took 52 milliseconds (0.052 seconds) DTR = 769.231 KBPS (0.751202 MBPS)
      -------------------------------------- Summary --------------------------------------
      - 0 fatal error(s), 1 error(s), 0 warning(s)
      ERROR: DW040: The product "{7F311193-9368-453B-989F-939FEBF374CC}" is not installed. Cannot proceed with the uninstall
      Please search the above error/warning string(s) to find when the error occurred.
      These errors resulted in installer Exit Code mentioned below.
      Exit Code: 33 - The product is not installed, cannot uninstall.
      Please see specific errors and warnings for troubleshooting. For example, ERROR: DW040 ...
      06/25/13 10:14:06:372 | [INFO] |  | OOBE | DE |  |  |  | 2851490 | DEVersion: 5.0.0.0
      06/25/13 10:14:06:392 | [INFO] |  | OOBE | DE |  |  |  | 2851490 | Loading library from /Applications/Utilities/Adobe Application Manager/DECore/DE5/Setup.dylib
      [       0] Tue Jun 25 10:14:06 2013  INFO
      CHECK : Credentials
      [       0] Tue Jun 25 10:14:06 2013 ERROR
      :: END TIMER :: [Total Timer] took 28 milliseconds (0.028 seconds) DTR = 571.429 KBPS (0.558036 MBPS)
      07/17/13 07:51:40:160 | [INFO] |  | OOBE | DE |  |  |  | 2075974 | DEVersion: 5.0.0.0
      07/17/13 07:51:40:170 | [INFO] |  | OOBE | DE |  |  |  | 2075974 | Loading library from /Applications/Utilities/Adobe Application Manager/DECore/DE5/Setup.dylib
      [       0] Wed Jul 17 07:51:40 2013  INFO
      CHECK : Credentials
      [       0] Wed Jul 17 07:51:40 2013 ERROR
      :: END TIMER :: [Total Timer] took 59 milliseconds (0.059 seconds) DTR = 406.78 KBPS (0.397246 MBPS)
      08/24/13 15:06:23:836 | [INFO] |  | OOBE | DE |  |  |  | 19184 | DEVersion: 5.0.0.0
      08/24/13 15:06:23:837 | [INFO] |  | OOBE | DE |  |  |  | 19184 | Loading library from /Applications/Utilities/Adobe Application Manager/DECore/DE5/Setup.dylib
      [       0] Sat Aug 24 15:06:23 2013  INFO
      CHECK : Credentials
      [       0] Sat Aug 24 15:06:24 2013 ERROR
      [       0] Sat Aug 24 15:06:24 2013  INFO
      :: END TIMER :: [Total Timer] took 186 milliseconds (0.186 seconds)
      09/06/13 14:22:18:936 | [INFO] |  | OOBE | DE |  |  |  | 10983189 | DEVersion: 5.0.0.0
      09/06/13 14:22:18:977 | [INFO] |  | OOBE | DE |  |  |  | 10983189 | Loading library from /Applications/Utilities/Adobe Application Manager/DECore/DE5/Setup.dylib
      [       0] Fri Sep  6 14:22:19 2013  INFO
      CHECK : Credentials
      [       0] Fri Sep  6 14:22:19 2013 ERROR
      :: END TIMER :: [Total Timer] took 67 milliseconds (0.067 seconds) DTR = 179.104 KBPS (0.174907 MBPS)
      10/29/13 09:56:42:752 | [INFO] |  | OOBE | DE |  |  |  | 7023 | DEVersion: 5.0.0.0
      10/29/13 09:56:42:754 | [INFO] |  | OOBE | DE |  |  |  | 7023 | Loading library from /Applications/Utilities/Adobe Application Manager/DECore/DE5/Setup.dylib
      [       0] Tue Oct 29 09:56:42 2013  INFO
      CHECK : Credentials
      [       0] Tue Oct 29 09:56:42 2013 ERROR
      :: END TIMER :: [Total Timer] took 44 milliseconds (0.044 seconds) DTR = 727.273 KBPS (0.710227 MBPS)
      11/06/13 19:29:32:508 | [INFO] |  | OOBE | DE |  |  |  | 12672 | DEVersion: 5.0.0.0
      11/06/13 19:29:32:530 | [INFO] |  | OOBE | DE |  |  |  | 12672 | Loading library from /Applications/Utilities/Adobe Application Manager/DECore/DE5/Setup.dylib
      [       0] Wed Nov  6 19:29:32 2013  INFO
      CHECK : Credentials
      [       0] Wed Nov  6 19:29:32 2013 ERROR
      :: END TIMER :: [Total Timer] took 48 milliseconds (0.048 seconds)
      12/26/13 15:52:21:997 | [INFO] |  | OOBE | DE |  |  |  | 73384 | DEVersion: 5.0.0.0
      12/26/13 15:52:22:013 | [INFO] |  | OOBE | DE |  |  |  | 73384 | Loading library from /Applications/Utilities/Adobe Application Manager/DECore/DE5/Setup.dylib
      [       0] Thu Dec 26 15:52:22 2013  INFO
      CHECK : Credentials
      [       0] Thu Dec 26 15:52:22 2013 ERROR
      :: END TIMER :: [Total Timer] took 59 milliseconds (0.059 seconds) DTR = 135.593 KBPS (0.132415 MBPS)
      02/05/14 15:52:07:871 | [INFO] |  | OOBE | DE |  |  |  | 5180385 | DEVersion: 5.0.0.0
      02/05/14 15:52:07:960 | [INFO] |  | OOBE | DE |  |  |  | 5180385 | Loading library from /Applications/Utilities/Adobe Application Manager/DECore/DE5/Setup.dylib
      [       0] Wed Feb  5 15:52:08 2014  INFO
      CHECK : Credentials
      [       0] Wed Feb  5 15:52:08 2014 ERROR
      :: END TIMER :: [Total Timer] took 275 milliseconds (0.275 seconds)
      02/14/14 10:50:40:439 | [INFO] |  | OOBE | DE |  |  |  | 6284 | DEVersion: 5.0.0.0
      02/14/14 10:50:40:441 | [INFO] |  | OOBE | DE |  |  |  | 6284 | Loading library from /Applications/Utilities/Adobe Application Manager/DECore/DE5/Setup.dylib
      [       0] Fri Feb 14 10:50:40 2014  INFO
      CHECK : Credentials
      [       0] Fri Feb 14 10:50:40 2014 ERROR
      :: END TIMER :: [Total Timer] took 184 milliseconds (0.184 seconds) DTR = 21.7391 KBPS (0.0212296 MBPS)
      03/12/14 19:02:56:570 | [INFO] |  | OOBE | DE |  |  |  | 6194 | DEVersion: 5.0.0.0
      03/12/14 19:02:56:571 | [INFO] |  | OOBE | DE |  |  |  | 6194 | Loading library from /Applications/Utilities/Adobe Application Manager/DECore/DE5/Setup.dylib
      [       0] Wed Mar 12 19:02:56 2014  INFO
      CHECK : Credentials
      [       0] Wed Mar 12 19:02:56 2014 ERROR
      :: END TIMER :: [Total Timer] took 109 milliseconds (0.109 seconds)
      Che devo fare?
