1 Reply Latest reply on Jan 22, 2015 12:07 PM by JeffLambert
    [AS ID CC2014] How to change character style in cells selection?
    JeffLambert Level 1
      I've been racking my brain over this one for a while now and I can't come up with something that works.
      I know I can use this to applied a character style to ALL my text within the selected cells.
      tell text 1 of cells of selection
        set applied character style to myCharacterStyle
        end tell
      Now if I want to affect only the text of cells that have a particular Paragraph style, then, it gets really complicated.
      I've tried with the whose clause like this
        tell (cells of selection whose paragraph style of text 1 is myParagraphStyle)
         try
        set properties of text 1 to {applied character style:myCharacterStyle}
        end try
        end tell
      and this:
      tell text 1 of cells of selection whose Paragraphe style is myParagraphStyle
      I've also tried with a repeat loop but can't get it to work either.
      set mySelection to cells of selection
        repeat with i from 1 to count of items of mySelection
        tell item i of mySelection
        tell text 1 of item i
        --if paragraph style is myParagraphStyle then
        try
        end try
        --end if
        end tell
        end tell
        end repeat
      and a bunch of other ways, but I can't figure it out. If someone knows how to do this, it would really be cool:-)
      TIA
      Jeff
        • 1. Re: [AS ID CC2014] How to change character style in cells selection?
          JeffLambert Level 1
          Ok, so I figured it out. But it's slow.
          Here's what I've got:
            end tell
            tell cells of selection
            set fill color to mycolor10
            end tell
            tell selection
            repeat with i from (count of cells) to 1 by -1
            tell text 1 of cell i
            try
            if applied paragraph style is myParagraphEntete then
            set applied character style to myCharacterStyleNone
            clear overrides
            end if
            if contents contains "2012" then
            end if
            if contents contains "2013" then
            end if
            if contents contains "2014" then
            end if
            end try
            end tell
            end repeat
            end tell
            end tell
          end tell
          I know I know the if then part is all messed up but I didn't know how to make the "or" work, something about not the right boolean type or something.
          As you can see, I start by applying a character style on all cells cause that way faster, then I have to go through all cells and check if they have that paragraph style where I don't want the character style, but, there is some execptions so if there is a year in those cells, that has to be with the myCharacterStyle (a semibold in that case).
          Of corse, it's not the whole script, but you get the idea with this chuck.
          Jeff
