I am using TCS 4 with FM 12 and RH 11.
I have an animation built in Flash and published to a SWF file.
The animation is added to a FM doc. Publishing to PDF shows the animation as expected.
I link an RH project to the FM book and the animation is missing. There is an empty frame where the animation should be, and what is in the frame is a blank PNG with a made up name (i.e. filename004.png). I can add the SWF file manually into the frame but it gets wiped during the next update. I can turn off updates but that defeats the purpose of Single Sourcing. There is no setting I can find in RH to manage importing media files.
Any help?
Is it in an anchored frame? Try a test – try importing into a blank project instead of linking to see if there’s a difference.
Another thought – try adding it as a baggage file to the RH project & generate.
Yep, anchored frame.
Adding baggage files did not help.
Embedding or linking within FM did not help.
Starting with your suggestions I did a little testing and found the problem. There are, in fact, 2 SWFs in the one frame, and that was causing RH to give up on the frame entirely. If I only put a single SWF in the frame, it seems to work.
I went back into Flash and glued both SWFs together to make one, which has solved it. However it would be interesting to know if there is a way to have 2 SWFs in a single FM frame.
Thanks for the help.
Aha! The old “2 SWFs in 1 frame” trick! LOL ;>)
