4 Replies Latest reply on Jan 22, 2015 9:05 PM by Teetan VK
    How the ratiobutton call function?
    Teetan VK Level 1
      Hi everyone
      I got this script
        var d=app.dialogs.add({name:”Define Empty Pages”});
        var radioBtns = d.dialogColumns.add().radiobuttonGroups.add();
        radioBtns.radiobuttonControls.add({staticLabel:”Save”,checkedState:true});
        radioBtns.radiobuttonControls.add({staticLabel:”No Save”});
        radioBtns.radiobuttonControls.add({staticLabel:“Exit”});
        if(!d.show()){d.destroy();}
        var saveOption = radioBtns.selectedButton;
                  d.destroy();
                  var docs = app.documents;
                  for (var i = docs.length-1; i >= 0; i--) {
                      if (docs[i].saved == false) {
                          docs[i].save(new File(“~/Desktop/myTestDocument” + (i+1) + “.indd”));
                          docs[i].close();
                      else {
                          docs[i].close(SaveOptions.NO);
      for close docs without save, but
      I want to remain choice for those unsaved files, so I add open dialog in case for me to decide if I save those unsaved files.
      Now, the problem is I don’t know how to let the ratiobutton call function
      My aim:
      1) If choose “Save” means save unsaved files, but not others
      2) If choose “No save” means all files no save
      2) If choose “Exit” means unsaved files Exit (remain open) but close others
      Regard
      Teetan
        • 1. Re: How the ratiobutton call function?
          Chinnadk Level 4
          Try this,
          var d=app.dialogs.add({name:"Define Empty Pages"});
          var save = radioBtns.radiobuttonControls.add({staticLabel:"Save",checkedState:true});
          var nosave = radioBtns.radiobuttonControls.add({staticLabel:"No Save"});
          var exit = radioBtns.radiobuttonControls.add({staticLabel:"Exit"});
          switch(radioBtns.selectedButton)
                  case 0:
                      for(var i =0;i<docs.length;i++)
                              if(docs[i].saved == false)
                                      docs[i].close();
                              else
                      break;
                  case 1:
                      break;
                  case 2:
                      exit()
                      break;
          Regards,
          Chinna
          • 2. Re: How the ratiobutton call function?
            Teetan VK Level 1
            Thank you Chinna
            Thank you very much
            but can you help me to fix line 46
            which error in wrong syntax
            line 46: "else" not vaild
            var myDate = new Date;
            Date.prototype.monthName = function() {
                var myMonth = ['January', 'February', 'March', 'April', 'May', 'June', 'July', 'August', 'September', 'October', 'November', 'December'];
                return myMonth[this.getMonth()];
            }//This line was proposed by Marijan Tompa (tomaxxi)
            var myMonthName = myDate.monthName();
            var myYear = myDate.getFullYear();
            var myHour = myDate.getHours();
            var myMinutes = myDate.getMinutes();
            //open dialog
            var d=app.dialogs.add({name:"Unsaved files Save or not"});
                    case 0:
                        for(var i = docs.length-1; i >= 0; i--)
                                        docs[i].save(new File("~/Desktop/Doc" + (i+1) + "-" + myDate.getDate() + " " + myMonthName + " " + myYear + " " + myHour + myMinutes + ".indd"));
                                        docs[i].close();
                                else
                        break;
                    case 1:
                        break;
                    case 2:
                                if(docs[i].saved == false)exit();
                                else // no vaild
                        break;
            thank you so much
            Regard
            Teetan
            • 3. Re: Re: How the ratiobutton call function?
              Chinnadk Level 4
              Corrected,
              //open dialog
              var _exit = radioBtns.radiobuttonControls.add({staticLabel:"Exit"});
                      case 0:
                                          docs[i].close();
                                  else
                          break;
                      case 1:
                          break;
                      case 2:
                                          exit();
                                  else // no vaild
                                  break;
              Regards,
              Chinna
              • 4. Re: How the ratiobutton call function?
                Teetan VK Level 1
                Thank you Chinna
                Thank you so much!
                Teetan
