4 Replies Latest reply on Jan 24, 2015 12:45 AM by FLAM
    Visibility in IE11 of an Edge Animate file via Muse
    FLAM
      Hi everyone,
      I'm not as familiar with forums, but in a closed discussion about Edge Animate, Muse and IE11, I read the last post of "elainefinnell" that the Muse Team has created a hotfix te resolve the problem with the visibility of an Edge Animate in IE11.
      My question is: where can I find this hotfix, and is this also effective when using Edge Animate 1.5 with Muse CC?
      If the hotfix would not work in that case, how can I nevertheless solve the problem?
      Hopefully I can find a solution in this way to get a file .oam working.
      Very curious about reactions and saluting,
      Frans
        • 1. Re: Visibility in IE11 of an Edge Animate file via Muse
          joel_pau Level 5
          Later versions solves this issue.
          Using Edge Animate 1.5 and IE 11, you have to customize the html file changing this tag:
          • Before: <meta http-equiv="X-UA-Compatible" content="IE=Edge"/>
          • After:    <meta http-equiv='X-UA-Compatible' content='IE=10'/>
          This tag is within the head tag.
          • 2. Re: Visibility in IE11 of an Edge Animate file via Muse
            FLAM Level 1
            Hi joel_pau,
            Thank you for your comment!
            I could not find your "Before" text in the html file in the assets directory and not in the index.html.
            But I changed with your "After" text the text:
            <meta http-equiv = "X-UA-Compatible" content = "IE = Edge, chrome = IE8" />
            in the html file in the assets directory, and the text:
            <meta http-equiv = "X-UA-Compatible" content = "chrome = IE8" />
            in the index.html.
            Unfortunately this did not produce the desired result.
            Nevertheless, thanks,
            Frans.
            • 3. Re: Visibility in IE11 of an Edge Animate file via Muse
              joel_pau Level 5
              If you put IE8, it will never runs! IE8 cannot read animations. You have to select the poster option. Pictures replace your animation.
              Using EA 1.5 and IE 11:
              <meta http-equiv="X-UA-Compatible" content="IE=Edge"/> ==> IE 11 runs as IE 11, therefore you will not see your animation built with 1.5.
              <meta http-equiv='X-UA-Compatible' content='IE=10'/> ==> IE 11 runs as IE 10, therefore you will see your animation built with 1.5.
              <meta http-equiv='X-UA-Compatible' content='IE=9'/> ==> IE 11 runs as IE 9, therefore you will see your animation built with 1.5.
              • 4. Re: Visibility in IE11 of an Edge Animate file via Muse
                FLAM Level 1
                Hi joel_pau,
                Again thanks for your comment.
                Maybe I was not clear, but the text in the index.html are:
                <meta http-equiv = "X-UA-Compatible" content = "IE = 10 '/>
                And in the html file of the animation:
                But the animation is not yet visible.
                Grtz, Frans.
