1 Reply Latest reply on Jan 23, 2015 8:36 AM by Peter Spier
    Table Help
    michellerau02
      In a table, I am trying to distribute columns evenly, row by row.  I want the cells in each row to distribute evenly but not match the row above.
      See attached images.
      I want cells in the bottom row to distribute evenly.  You will notice the bottom row has a larger cell right now.
      I faked this by making 4 separate tables and putting them together but this is not the answer and it is also not perfect!  I can't get the tables to align perfect and be the same size Screen Shot 2015-01-23 at 11.21.29 AM.png
      Your help will be greatly appreciated
      Michelle
        • 1. Re: Table Help
          In ID tables column widths are "global" for the table, so the only way to do that in ID with a single table would be to have sufficient columns to have a column edge at every point you want a cell boundary, then to selectively merge cells row by row. It might be easier to do a table for each row.
