3 Replies Latest reply on May 12, 2017 6:57 AM by waltoncreative
    Book PDF Export - Bleed disappears;  Individual Files are fine
    Figures In Motion
      I am having a problem with the bleed after exporting my book. I have an InDesign book comprising of 8 files. After preflight, when I select "Export Book to PDF", the document bleed settings are not followed. The bleed is being cut off at the crop marks.
      The "Export Adobe PDF" settings are as follows:
      Printer's Marks selected:
      Crop Marks                         Type: Default
      Registration Marks               Weight 0.25 pt
      Color Bars                              Offset 0.125
      Bleed and Sug:
      Use Document Bleed Settings (which are all 0.125)
      After I export this (AS A BOOK) the bleeds do not show up. Everything is cut off at the crop marks. But if I export the individual files that make up the book, it shows up just as expected, which the same Export Adobe PDF Settings.
      Thanks so much for your help. I am at a loss for what to do.
