1 Reply Latest reply on Jan 24, 2015 4:35 PM by Herbert2001
    Getting layers aligned exactly as they were in photoshop
    reindeer4 Level 1
      I have a photoshop cs6 document 10240 x 2560 pixels with 3 different layers showing objects in different styles.
      How can I get these perfectly aligned as 3 separate layers in Fireworks CS6?
      I exported the layers as separate png files - but when I try to bring these in in Fireworks through import, they show different size bounding boxes.
      When I try bringing the whole photoshop document in or 'open in firefox' it won't let me (not sure if there's a pixel dimension limit)
      Thanks for any help.
        • 1. Re: Getting layers aligned exactly as they were in photoshop
          Herbert2001 Level 4
          You are correct: the maximum document dimensions in FW are 6000 by 6000 pixels. A simple change in a preference file serves as a workaround, although I do not recall how far you can push these numbers (there is limit).
          Make sure that Fireworks is closed, open Fireworks CS6 Preferences.txt file located in:
          Windows 7/Vista: C:\Users\USERNAME\AppData\Roaming\Adobe\Fireworks CS6\English\
          Windows XP: C:\Documents and Settings\USERNAME\AppData\Roaming\Adobe\Fireworks CS6\English\
          MacOS X: Library/Preferences/Adobe Fireworks CS6/en/
          and change
          or adjust this number as needed.
