3 Replies Latest reply on Jan 24, 2015 9:35 PM by A.T. Romano
    incompatible display driver
    talmanp30402182
      Can't open Adobe Premiere Elements 12 as I get an "incompatible display driver" error.  I read a few forums and deleted the BadDrivers.txt file but it keeps coming back. Computer is Dell XPS 8300 64 bit 8 GB Ram.  Display adapter (only 1) is AMD Radeon HD 6450.  Running Windows 7 Home Premium.
        • 1. Re: incompatible display driver
          A.T. Romano Level 7
          talmanp
          Did you find and delete the BadDrivers.txt file for Premiere Elements 12/12.1.
          After you delete this BadDrivers.txt file, close out of there, and reopen Premiere Elements, the program
          will generate a new BadDrivers.txt file (that is normal) and hopefully the problem with be gone.
          Are you saying that you made that deletion, shutdown the computer, re-started the computer and Premiere Elements
          and still got the Display Card error?
          Just in case message, before you deleted the BadDrivers.txt file, did you confirm that the AMD driver version was up to
          date according to the web site of the manufacturer of the card? Did you explore card/driver setting in any AMD control center
          on your computer for that card?
          We will be watching for your results.
          Thank you.
          ATR
          • 2. Re: incompatible display driver
            talmanp30402182 Level 1
            I had not rebooted.  It works now - thanks.
            • 3. Re: incompatible display driver
              A.T. Romano Level 7
              talmanp
              There are frequent reports of incompatible display driver messages. And, it is important to know what
              is working for those who run into this type of situation. So, thank you for the follow up with the good news of what worked
              for you to gain success. Great job.
              Best wishes.
              ATR
