1 Reply Latest reply on Feb 13, 2015 6:24 AM by Alex Pavelescu
    What about moving sites later?
    donnelj
      I'm considering this platform as a solution to replace an existing VPS with about 30 clients. what if at a later time, I wanted to move a site off BC to another server?  Will the code stand alone separate of BC?
        • 1. Re: What about moving sites later?
          Alex Pavelescu Adobe Employee
          Hi!
          All pages, static content, cs and javascript should work. All dinamic content though, templates on e-commerce or other pages, information rendered from the database in the front-end via our tags and modules, that won't be saved. That only works on our platform as it's the very aspect that defines the advantage of using the platform in the first place. The use of easy to manage tags and modules to render content dynamically.
          Nevertheless, you can export contacts, webapps, products, pretty much everything relevant that you may need to take away with you, should you choose to switch to another hosting.
          Kind Regards,
          Alex Pavelescu
