1 Reply Latest reply on Jan 27, 2015 9:06 AM by try67
    Sending XML with HTTP Submit button
    thodte
      Hello!
      I have following question: I have a LC Designer form with a http submit button. I send the XML to a servlet.
      During sending a failure can happen for example no connection or error on server. I want to evalute the response. But I can't see any possibility to intercept the submit button.
      The pre- and postsubmit event doesn't work.
      I found the FormCalc method post(). But this is only working in formcalc and not in JS. I do more things in JS so I can't use it (I found no bridge between formcalc and JS)
      Is there a possibility to check the result of a http response when sending data?
      (I can't use SOAP because there are no ReaderExtensions!)
      Regards,
      Christoph
