I'm dropping both pngs and jpgs into BC's email marketing tool. For some reason, they display correctly in BC, but when I send a test email out to myself, the images do not display. Help!
I, too, was having issues with jpgs displaying in emails even when they showed up on BC. What I found is that when there is a physical space in between words in the name of the file, it will display in BC and on the webpages but not in an email. If you rename the file without the space it will work. There may be an easier way fix it through the coding or something, but I have found this way to work fine.
Spaces and funny characters in file names on the web is basically something to NOT do.
A few browsers, coding solutions, API work, Email clients can all be effected by this and cause rendering issues. Just stick to the lower case, no spaces or character rule on file names.
Also avoid scaling the images in the editor - May look good and may come out in some email clients but some like Outlook will keep the image size as its natural size and emails will come out not as you expect because of this.
