6 Replies Latest reply on Jan 27, 2015 5:10 AM by GS1234
    BC Ecommerce SOAP Error: Server did not recognize the value of HTTP Header SOAPAction
    GS1234 Level 1
      I am trying to add a product to an ecommerce site with this soap action: Product_UpdateInsert
      I have followed this very brief instruction: https://jollyrogers.worldsecuresystems.com/catalystwebservice/catalystecommercewebservice. asmx?op=Product_UpdateInsert
      I have a html page in a secure area with a jQuery ajax soap script.
      I get the this error when I run the script:
      <?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><soap:Body><soap:Fault><faultcode>soap:Client</faultcode><faultstring>Server did not recognize the value of HTTP Header SOAPAction: https://jollyrogers.worldsecuresystems.com/CatalystDeveloperService/CatalystEcommerceWebse rvice/Product_UpdateInsert.</faultstring><detail /></soap:Fault></soap:Body></soap:Envelope>
      I have also tried to add a header with the Soap action with the beforeSend in the ajax call.
      This must have been solved before I suppose?
      Here is my script:
      <!DOCTYPE html>
      <html lang="en">
      <head>
      <title>Test SOAP Request</title>
          <script type="text/javascript" src="//code.jquery.com/jquery-1.10.2.min.js"></script>
          <script type="text/javascript" src="//cdnjs.cloudflare.com/ajax/libs/jquery-cookie/1.3.1/jquery.cookie.min.js"></script>
          <script type="text/javascript" src="//cdnjs.cloudflare.com/ajax/libs/underscore.js/1.5.1/underscore-min.js"></script>
          <script type="text/javascript" src="//cdnjs.cloudflare.com/ajax/libs/backbone.js/1.0.0/backbone-min.js"></script>
          <script type="text/javascript" src="//cdn.worldsecuresystems.com/bcapi/bcapi-0.0.1.min.js"></script>
      </head>
      <body>
      <script>
      var wsUrl = "https://jollyrogers.worldsecuresystems.com/catalystwebservice/catalystecommercewebservice. asmx";
      var soapRequest =
      '<?xml version="1.0" encoding="utf-8"?> \
      <soap12:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soap12="http://www.w3.org/2003/05/soap-envelope"> \
        <soap12:Body> \
          <Product_UpdateInsert xmlns="https://jollyrogers.worldsecuresystems.com/CatalystDeveloperService/CatalystEcommerceWebse rvice"> \
            <username>myEmailAdress</username> \
            <password>mySecretPassw</password> \
            <siteId>1894001</siteId> \
            <productList> \
              <Products> \
                <productCode>ZJAWEyuuyN</productCode> \
                <productName>My test product</productName> \
                <description>Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.</description> \
                <smallImage>/images/product1/small.jpg</smallImage> \
                <largeImage>/images/product1/large.jpg</largeImage> \
               <cataloguesArray> \
                   <string>/Store/</string> \
                </cataloguesArray> \
                <pricesSaleArray> \
                  <string>US/19.95,3/17.96,7/16.96</string> \
                </pricesSaleArray> \
                <pricesRetailArray> \
                  <string>US/20,5/19,8/20</string> \
                </pricesRetailArray> \
                <pricesWholesaleArray> \
                </pricesWholesaleArray> \
                <wholesaleTaxCodeArray> \
                  <string>US/0.00</string> \
                </wholesaleTaxCodeArray> \
                <taxCodeArray> \
                  <string>GB/VAT</string> \
                </taxCodeArray> \
                <groupProducts> \
                  <string>580H0036BL</string> \
                  <string>ACAI60</string> \
                  <string>ABC-123</string> \
                </groupProducts> \
                <groupProductsDescriptions> \
                  <string>Lorem ipsum dolor sit amet</string> \
                  <string>consectetur adipisicing elit</string> \
                </groupProductsDescriptions> \
                <supplierEntityId>1234</supplierEntityId> \
                <supplierCommission>0</supplierCommission> \
                <weight>30</weight> \
                <tags>NEW!</tags> \
                <unitType>string</unitType> \
                <minUnits>0</minUnits> \
                <maxUnits>2</maxUnits> \
                <inStock>43</inStock> \
                <onOrder>3</onOrder> \
                <reOrder>2</reOrder> \
                <inventoryControl>true</inventoryControl> \
                <canPreOrder>true</canPreOrder> \
                <custom1>Text in custom field 1</custom1> \
                <custom2>Text in custom field 2</custom2> \
                <custom3>Text in custom field 3</custom3> \
                <custom4>Text in custom field 4</custom4> \
                <popletImages>/images/image1.jpg;/images/image2.jpg;</popletImages> \
                <enabled>true</enabled> \
                <deleted>false</deleted> \
                <captureDetails>true</captureDetails> \
                <downloadLimitCount>20</downloadLimitCount> \
                <limitDownloadsToIP>0</limitDownloadsToIP> \
                <isOnSale>true</isOnSale> \
                <hideIfNoStock>true</hideIfNoStock> \
                <productAttributes>Size*|5|Y:L||UK/2|US/20,S||UK/1|US/10</productAttributes> \
                <isGiftVoucher>false</isGiftVoucher> \
                <enableDropShipping>true</enableDropShipping> \
                <productWeight>0</productWeight> \
                <productWidth>0</productWidth> \
                <productHeight>0</productHeight> \
                <productDepth>0</productDepth> \
                <excludeFromSearch>false</excludeFromSearch> \
                <productTitle>My product title</productTitle> \
                <cycletypeId>3</cycletypeId> \
                <cycletypeCount>-1</cycletypeCount> \
                <slug>my-product</slug> \
                <hasVariations>true</hasVariations> \
                <variations> \
                  <ProductVariation xsi:nil="true" /> \
                </variations> \
              </Products> \
            </productList> \
          </Product_UpdateInsert> \
        </soap12:Body> \
      </soap12:Envelope>';
      $.ajax({
           type: "POST",
           beforeSend: function(xhr){xhr.setRequestHeader('SOAPAction', 'https://jollyrogers.worldsecuresystems.com/CatalystDeveloperService/CatalystEcommerceWebse rvice/Product_UpdateInsert');},
           url: wsUrl,
           contentType: "text/xml",
           dataType: "xml",
           data: soapRequest,
           success: processSuccess,
           error: processError
      function processSuccess(data, status, req)
         if (status == "success")
         alert("Success!");
      function processError(data, status, req)
         alert("Failed!");
         alert(req.responseText + " " + status);
      </script>
      </body>
      </html>
