2 Replies Latest reply on Jan 28, 2015 7:37 AM by superchitilin
    Export specified pages as jpg at defined resolution
    superchitilin
      Hello inDesign Community -
      I have a script that allows me to export pages specified from a dialog prompt as jpgs at a specific resolution (500px wide).
      This is great for making thumbnails, however It uses the dimensions of the active document page to set the resolution formula.
      This works unless there are different sized pages, at which point you get different sized jpg.
      How can use the page dimensions of each page that is being exported individually.
      I assume there is a way to get an array from jpegExportPreferences.pageString that can then be looped through.
      Thanks in advance
      // which pages to export
      var pagesToExport
      // final jpg demensions
      var myLargeWidth = 500;
      var myLargeHeight = 500;
      // create a variable for current active document
      var docRef = app.activeDocument;
      // remove ententions from end of file path
      myFilename = docRef.name.replace(/\.[^\.]+$/, '');
      // set variable to save file in same directory as active document
      myFolder = docRef.filePath;
      // set document measurments to points and reset ruler orgin
      docRef.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
      docRef.viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
      docRef.viewPreferences.rulerOrigin = RulerOrigin.PAGE_ORIGIN;
      docRef.zeroPoint = [0,0];
      //bounds    Array of Measurement Unit (Number or String)    readonly    The bounds of the Page, in the format [y1, x1, y2, x2].
      // find width of page
      var myCurrentWidth = app.activeWindow.activePage.bounds[3]-app.activeWindow.activePage.bounds[1];
      // find height of page
      var myCurrentHeight = app.activeWindow.activePage.bounds[2]-app.activeWindow.activePage.bounds[0];
      function exportJPG() {
        // export large jpg
                  if (myLargeWidth > 0) {
                      // Calculate the scale percentage
                      var myResizePercentage = myLargeWidth/myCurrentWidth;
                      var myExportRes = myResizePercentage * 72;
                      // exportResolution is only accurate to 1 decimal place, so round
                  else {
                      var myResizePercentage = myLargeHeight/myCurrentHeight;
                  // use caluclated percentage as resolution
                  app.jpegExportPreferences.exportResolution = myExportRes;
                  // export jpg in myfolder add .jpg to end.
                  docRef.exportFile(ExportFormat.JPG, File(myFolder+"/"+myFilename+"-500px.jpg"));
                  // reset back to inches
                  docRef.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.inches;
                  docRef.viewPreferences.verticalMeasurementUnits = MeasurementUnits.inches;
      var myName = myInput ();
      // rest of the script
      function myInput ()
        var myWindow = new Window ("dialog", "Pages to export as JPG");
        var myCommentGroup = myWindow.add ("group");
        myCommentGroup.add ("statictext", undefined, "export some jpgs", {multiline:true});
        //myCommentGroup.maximumSize.width = 200;
        var myInputGroup = myWindow.add ("group");
        myInputGroup.add ("statictext", undefined, "Pages: (1-3,8,10)");
        var myText = myInputGroup.add ("edittext", undefined, "1");
        myText.characters = 20;
        myText.active = true;
        var myButtonGroup = myWindow.add ("group");
        myButtonGroup.alignment = "right";
        myButtonGroup.add ("button", undefined, "OK");
        myButtonGroup.add ("button", undefined, "Cancel");
        if (myWindow.show () == 1)
        return myText.text, pagesToExport = myText.text;
        else
        exit ();
      // jpg export preferences
      app.jpegExportPreferences.exportingSpread= false;
      app.jpegExportPreferences.jpegQuality = JPEGOptionsQuality.HIGH;
      app.jpegExportPreferences.jpegExportRange = ExportRangeOrAllPages.EXPORT_RANGE;
      app.jpegExportPreferences.pageString = pagesToExport;
      app.jpegExportPreferences.embedColorProfile = false;
      app.jpegExportPreferences.jpegColorSpace= JpegColorSpaceEnum.RGB;
      app.jpegExportPreferences.antiAlias = true;
      exportJPG();
      // run function
        • 1. Re: Export specified pages as jpg at defined resolution
          Jump_Over Level 5
          1. You need to insert myCurrentWidth & Height calculation into function exportJPG() and execute it for each page;
          2. This function supposes to be run with each chosen page and different exportPreferences;
          3. So  you need split a string variable pageToExport into array collecting separate pages.
          Like this:
          var pagesToExport;
          function exportJPG(cPage) {
          // export large jpg
          var myCurrentWidth = cPage.bounds[3]-cPage.bounds[1];
          var myCurrentHeight = cPage.bounds[2]-cPage.bounds[0];
          else {
          app.jpegExportPreferences.pageString = cPage.name;
          docRef.exportFile(ExportFormat.JPG, File(myFolder+"/"+myFilename + "_" + cPage.name + "-500px.jpg"));
          // SUI Dialog
          myInput ();
          // run function (loop through chosen pages)
          var b, c, d, stop;
          b = pagesToExport.split(",");
          while (c = b.shift() ) {
            d = c.split("-");
            stop = parseInt(d[0]);
            while (stop <= parseInt(d[d.length-1]) ) {
                 exportJPG(docRef.pages.item(stop-1));
                 stop++;
          function myInput ()
            return pagesToExport = myText.text;
            else
            exit ();
          Notice that different page sizes can lead to different width/height proportions.
          In this case JPGs will still differ. (by height)
          Jarek
          • 2. Re: Export specified pages as jpg at defined resolution
            superchitilin Level 1
            Thanks Jump_Over
            This is exactly what I needed but I did not know how to write the loop.
            Coming from a design background, coding is still a mystery. I looking forward to breaking apart the loop to see how it works.
            Thanks Again, this is a tremendous help
