0 Replies Latest reply on Jan 27, 2015 3:46 PM by Johninus
    How to let the Stage will be scaled to fit the screen?
    Johninus Level 1
      Refer the code in Exploring full-screen mode in Flash Player | Adobe Developer Connection
      Error "mc is not defined for: mc.contextMenu = fullscreenCM;
      I changed it to: this.contextMenu = fullscreenCM;  without error but it dosen't work out for full screen issue. Thanks,
      // functions to enter and leave full screen mode;
      function goFullScreen(event:ContextMenuEvent):void
          stage.displayState = StageDisplayState.FULL_SCREEN;
      // An alternate full-screen function that uses hardware scaling to display the upper left corner of the stage in full screen.
      function goScaledFullScreen()
          var screenRectangle:Rectangle = new Rectangle(0,0,stage.stageWidth / 2,stage.stageHeight / 2);
          stage.fullScreenSourceRect = screenRectangle;
      function exitFullScreen(event:ContextMenuEvent):void
          stage.displayState = StageDisplayState.NORMAL;
      // function to enable and disable the context menu items,
      // based on what mode we are in.
      function menuHandler(event:ContextMenuEvent):void
          if (stage.displayState == StageDisplayState.NORMAL)
              event.target.customItems[0].enabled = true;
              event.target.customItems[1].enabled = false;
              event.target.customItems[0].enabled = false;
              event.target.customItems[1].enabled = true;
      // create the context menu, remove the built-in items,
      // and add our custom items
      var fullscreenCM:ContextMenu = new ContextMenu();
      fullscreenCM.addEventListener(ContextMenuEvent.MENU_SELECT, menuHandler);
      var fs:ContextMenuItem = new ContextMenuItem("Go Full Screen");
      fs.addEventListener(ContextMenuEvent.MENU_ITEM_SELECT, goFullScreen);
      fullscreenCM.customItems.push( fs );
      var xfs:ContextMenuItem = new ContextMenuItem("Exit Full Screen");
      xfs.addEventListener(ContextMenuEvent.MENU_ITEM_SELECT, exitFullScreen);
      fullscreenCM.customItems.push( xfs );
      // finally, attach the context menu to a movieclip
