2 Replies Latest reply on Jan 28, 2015 5:18 PM by rlr29711
    Import CinemaDNG (Blackmagic) into AE @ wrong FPS
    rlr29711 Level 1
      Hi There,
      When I import a clip (Cinema DNG sequence) After Effects interprets the footage at 30fps instead of the 23.976 that it was shot at.  I have to manually change each clip's fps.  Am I doing something wrong or is this a bug?
      Also, I've filed a bug report for a related issue, but when I import a Premiere Pro Project or XML from Premiere Pro AE imports a single still frame instead of interpreting it as a clip. I've tried replacing the footage via 'replace footage' function but the timecode doesn't match up. (The related bug report is that 'replace with after effects comp' function does not work with CinemaDNG sequences from the Blackmagic cameras)
      Randy
