3 Replies Latest reply on Jan 29, 2015 12:05 AM by Peter Spier
    Help me edit a InDesign sample JavaScript
    EddieBrooklyn Level 1
      Hi, There is a sample InDesign JavaScript called ImageCatalog.jsx, I would like to edit it so that it only searches for and lays out images with a given prefix, so instead of returning all of the images in the directory, I would like to specify a set PREFIX such as the number "100" or the word "apple". Can someone please help me out?
      Here is the entire script.
      //ImageCatalog.jsx
      //An InDesign CS6 JavaScript
      @@@BUILDINFO@@@ "ImageCatalog.jsx" 3.0.0 15 December 2009
      //Creates an image catalog from the graphic files in a selected folder.
      //Each file can be labeled with the file name, and the labels are placed on
      //a separate layer and formatted using a paragraph style ("label") you can
      //modify to change the appearance of the labels.
      //For more information on InDesign scripting, go to http://www.adobe.com/products/indesign/scripting/index.html
      //Or visit the InDesign Scripting User to User forum at http://www.adobeforums.com .
      //The myExtensions array contains the extensions of the graphic file types you want
      //to include in the catalog. You can remove extensions from or add extensions to this list.
      //myExtensions is a global. Mac OS users should also look at the file types in the myFileFilter function.
      main();
      function main(){
        var myFilteredFiles;
        //Make certain that user interaction (display of dialogs, etc.) is turned on.
        app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
        myExtensions = [".jpg", ".jpeg", ".eps", ".ps", ".pdf", ".tif", ".tiff", ".gif", ".psd", ".ai"]
        //Display the folder browser.
          var myFolder = Folder.selectDialog("Select the folder containing the images", "");
          //******This is what i will be replacinf it with instaed of the line above , as i have a fixed  directory *************.
        //var myFolder = Folder("/Volumes/Creative_Working/Universal/PRODUCT%20KNOWLEDGE%20IMAGES/FY15/");
        //Get the path to the folder containing the files you want to place.
        if(myFolder != null){
        if(File.fs == "Macintosh"){
        myFilteredFiles = myMacOSFileFilter(myFolder);
        else{
        myFilteredFiles = myWinOSFileFilter(myFolder);
        if(myFilteredFiles.length != 0){
        myDisplayDialog(myFilteredFiles, myFolder);
        alert("Done!");
      //Windows version of the file filter.
      function myWinOSFileFilter(myFolder){
        var myFiles = new Array;
        var myFilteredFiles = new Array;
        for(myExtensionCounter = 0; myExtensionCounter < myExtensions.length; myExtensionCounter++){
        myExtension = myExtensions[myExtensionCounter];
              myFiles = myFolder.getFiles("*"+ myExtension);
        if(myFiles.length != 0){
        for(var myFileCounter = 0; myFileCounter < myFiles.length; myFileCounter++){
        myFilteredFiles.push(myFiles[myFileCounter]);
        return myFilteredFiles;
      function myMacOSFileFilter(myFolder){
        var myFilteredFiles = myFolder.getFiles(myFileFilter);
      //Mac OS version of file filter
      //Have to provide a separate version because not all Mac OS users use file extensions
      //and/or file extensions are sometimes hidden by the Finder.
      function myFileFilter(myFile){
        var myFileType = myFile.type;
        switch (myFileType){
        case "JPEG":
        case "EPSF":
        case "PICT":
        case "TIFF":
        case "8BPS":
        case "GIFf":
        case "PDF ":
        return true;
        break;
        default:
        for(var myCounter = 0; myCounter<myExtensions.length; myCounter++){
        var myExtension = myExtensions[myCounter];
        if(myFile.name.indexOf(myExtension)>-1){
        return true;
        break;
        return false;
      function myDisplayDialog(myFiles, myFolder){
        var myLabelWidth = 112;
        var myStyleNames = myGetParagraphStyleNames(app);
        var myLayerNames = ["Layer 1", "Labels"];
        var myDialog = app.dialogs.add({name:"Image Catalog"});
        with(myDialog.dialogColumns.add()){
        with(dialogRows.add()){
        staticTexts.add({staticLabel:"Information:"});
        with(borderPanels.add()){
        with(dialogColumns.add()){
        staticTexts.add({staticLabel:"Source Folder:", minWidth:myLabelWidth});
        staticTexts.add({staticLabel:myFolder.path + "/" + myFolder.name});
        staticTexts.add({staticLabel:"Number of Images:", minWidth:myLabelWidth});
        staticTexts.add({staticLabel:myFiles.length + ""});
        staticTexts.add({staticLabel:"Options:"});
        staticTexts.add({staticLabel:"Number of Rows:", minWidth:myLabelWidth});
        var myNumberOfRowsField = integerEditboxes.add({editValue:3});
        staticTexts.add({staticLabel:"Number of Columns:", minWidth:myLabelWidth});
        var myNumberOfColumnsField = integerEditboxes.add({editValue:3});
        staticTexts.add({staticLabel:"Horizontal Offset:", minWidth:myLabelWidth});
        var myHorizontalOffsetField = measurementEditboxes.add({editValue:12, editUnits:MeasurementUnits.points});
        staticTexts.add({staticLabel:"Vertical Offset:", minWidth:myLabelWidth});
        var myVerticalOffsetField = measurementEditboxes.add({editValue:24, editUnits:MeasurementUnits.points});
        with (dialogRows.add()){
        staticTexts.add({staticLabel:"Fitting:", minWidth:myLabelWidth});
        var myFitProportionalCheckbox = checkboxControls.add({staticLabel:"Proportional", checkedState:true});
        var myFitCenterContentCheckbox = checkboxControls.add({staticLabel:"Center Content", checkedState:true});
        var myFitFrameToContentCheckbox = checkboxControls.add({staticLabel:"Frame to Content", checkedState:true});
        var myRemoveEmptyFramesCheckbox = checkboxControls.add({staticLabel:"Remove Empty Frames:", checkedState:true});
        staticTexts.add({staticLabel:""});
        var myLabelsGroup = enablingGroups.add({staticLabel:"Labels", checkedState:true});
        with (myLabelsGroup){
        //Label type
        staticTexts.add({staticLabel:"Label Type:", minWidth:myLabelWidth});
        var myLabelTypeDropdown = dropdowns.add({stringList:["File name", "File path", "XMP description", "XMP author"], selectedIndex:0});
        //Text frame height
        staticTexts.add({staticLabel:"Label Height:", minWidth:myLabelWidth});
        var myLabelHeightField = measurementEditboxes.add({editValue:24, editUnits:MeasurementUnits.points});
        //Text frame offset
        staticTexts.add({staticLabel:"Label Offset:", minWidth:myLabelWidth});
        var myLabelOffsetField = measurementEditboxes.add({editValue:0, editUnits:MeasurementUnits.points});
        //Style to apply
        staticTexts.add({staticLabel:"Label Style:", minWidth:myLabelWidth});
        var myLabelStyleDropdown = dropdowns.add({stringList:myStyleNames, selectedIndex:0});
        //Layer
        staticTexts.add({staticLabel:"Layer:", minWidth:myLabelWidth});
        var myLayerDropdown = dropdowns.add({stringList:myLayerNames, selectedIndex:0});
              var myResult = myDialog.show();
              if(myResult == true){
        var myNumberOfRows = myNumberOfRowsField.editValue;
        var myNumberOfColumns = myNumberOfColumnsField.editValue;
        var myRemoveEmptyFrames = myRemoveEmptyFramesCheckbox.checkedState;
        var myFitProportional = myFitProportionalCheckbox.checkedState;
        var myFitCenterContent = myFitCenterContentCheckbox.checkedState;
        var myFitFrameToContent = myFitFrameToContentCheckbox.checkedState;
        var myHorizontalOffset = myHorizontalOffsetField.editValue;
        var myVerticalOffset = myVerticalOffsetField.editValue;
        var myMakeLabels = myLabelsGroup.checkedState;
        var myLabelType = myLabelTypeDropdown.selectedIndex;
        var myLabelHeight = myLabelHeightField.editValue;
        var myLabelOffset = myLabelOffsetField.editValue;
        var myLabelStyle = myStyleNames[myLabelStyleDropdown.selectedIndex];
        var myLayerName = myLayerNames[myLayerDropdown.selectedIndex];
        myDialog.destroy();
        myMakeImageCatalog(myFiles, myNumberOfRows, myNumberOfColumns, myRemoveEmptyFrames, myFitProportional, myFitCenterContent, myFitFrameToContent, myHorizontalOffset, myVerticalOffset, myMakeLabels, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle,  myLayerName);
        else{
        myDialog.destroy();
      function myGetParagraphStyleNames(myDocument){
        var myStyleNames = new Array;
        var myAddLabelStyle = true;
        for(var myCounter = 0; myCounter < myDocument.paragraphStyles.length; myCounter++){
        myStyleNames.push(myDocument.paragraphStyles.item(myCounter).name);
        if (myDocument.paragraphStyles.item(myCounter).name == "Labels"){
        myAddLabelStyle = false;
        if(myAddLabelStyle == true){
        myStyleNames.push("Labels");
        return myStyleNames;
      function myMakeImageCatalog(myFiles, myNumberOfRows, myNumberOfColumns, myRemoveEmptyFrames, myFitProportional, myFitCenterContent, myFitFrameToContent, myHorizontalOffset, myVerticalOffset, myMakeLabels, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle,  myLayerName){
        var myPage, myFile, myCounter, myX1, myY1, myX2, myY2, myRectangle, myLabelStyle, myLabelLayer;
        var myParagraphStyle, myError;
        var myFramesPerPage = myNumberOfRows * myNumberOfColumns;
        var myDocument = app.documents.add();
        myDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
        myDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
        var myDocumentPreferences = myDocument.documentPreferences;
        var myNumberOfFrames = myFiles.length;
        var myNumberOfPages = Math.round(myNumberOfFrames / myFramesPerPage);
        if ((myNumberOfPages * myFramesPerPage) < myNumberOfFrames){
        myNumberOfPages++;
        //If myMakeLabels is true, then add the label style and layer if they do not already exist.
        if(myMakeLabels == true){
        try{
        myLabelLayer = myDocument.layers.item(myLayerName);
        //if the layer does not exist, trying to get the layer name will cause an error.
        myLabelLayer.name;
        catch (myError){
        myLabelLayer = myDocument.layers.add({name:myLayerName});
        //If the paragraph style does not exist, create it.
        try{
        myParagraphStyle = myDocument.paragraphStyles.item(myLabelStyle);
        myParagraphStyle.name;
        catch(myError){
        myDocument.paragraphStyles.add({name:myLabelStyle});
        myDocumentPreferences.pagesPerDocument = myNumberOfPages;
        myDocumentPreferences.facingPages = false;
        var myPage = myDocument.pages.item(0);
        var myMarginPreferences = myPage.marginPreferences;
        var myLeftMargin = myMarginPreferences.left;
        var myTopMargin = myMarginPreferences.top;
        var myRightMargin = myMarginPreferences.right;
        var myBottomMargin = myMarginPreferences.bottom;
        var myLiveWidth = (myDocumentPreferences.pageWidth - (myLeftMargin + myRightMargin)) + myHorizontalOffset
        var myLiveHeight = myDocumentPreferences.pageHeight - (myTopMargin + myBottomMargin)
        var myColumnWidth = myLiveWidth / myNumberOfColumns
        var myFrameWidth = myColumnWidth - myHorizontalOffset
        var myRowHeight = (myLiveHeight / myNumberOfRows)
        var myFrameHeight = myRowHeight - myVerticalOffset
        var myPages = myDocument.pages;
        // Construct the frames in reverse order. Don't laugh--this will
        // save us time later (when we place the graphics).
        for (myCounter = myDocument.pages.length-1; myCounter >= 0; myCounter--){
        myPage = myPages.item(myCounter);
        for (var myRowCounter = myNumberOfRows; myRowCounter >= 1; myRowCounter--){
        myY1 = myTopMargin + (myRowHeight * (myRowCounter-1));
        myY2 = myY1 + myFrameHeight;
        for (var myColumnCounter = myNumberOfColumns; myColumnCounter >= 1; myColumnCounter--){
        myX1 = myLeftMargin + (myColumnWidth * (myColumnCounter-1));
        myX2 = myX1 + myFrameWidth;
        myRectangle = myPage.rectangles.add(myDocument.layers.item(-1), undefined, undefined, {geometricBounds:[myY1, myX1, myY2, myX2], strokeWeight:0, strokeColor:myDocument.swatches.item("None")});
        // Because we constructed the frames in reverse order, rectangle 1
        // is the first rectangle on page 1, so we can simply iterate through
        // the rectangles, placing a file in each one in turn. myFiles = myFolder.Files;
        for (myCounter = 0; myCounter < myNumberOfFrames; myCounter++){
        myFile = myFiles[myCounter];
        myRectangle = myDocument.rectangles.item(myCounter);
        myRectangle.place(File(myFile));
        myRectangle.label = myFile.fsName.toString();
        //Apply fitting options as specified.
        if(myFitProportional){
        myRectangle.fit(FitOptions.proportionally);
        if(myFitCenterContent){
        myRectangle.fit(FitOptions.centerContent);
        if(myFitFrameToContent){
        myRectangle.fit(FitOptions.frameToContent);
        //Add the label, if necessary.
        myAddLabel(myRectangle, myLabelType, myLabelHeight, myLabelOffset, myLabelStyle, myLayerName);
        if (myRemoveEmptyFrames == 1){
        for (var myCounter = myDocument.rectangles.length-1; myCounter >= 0;myCounter--){
        if (myDocument.rectangles.item(myCounter).contentType == ContentType.unassigned){
        myDocument.rectangles.item(myCounter).remove();
        else{
        //As soon as you encounter a rectangle with content, exit the loop.
        break;
      //Function that adds the label.
      function myAddLabel(myFrame, myLabelType, myLabelHeight, myLabelOffset, myLabelStyleName, myLayerName){
        var myDocument = app.documents.item(0);
        var myLabel;
        var myLabelStyle = myDocument.paragraphStyles.item(myLabelStyleName);
        var myLabelLayer = myDocument.layers.item(myLayerName);
        var myLink =myFrame.graphics.item(0).itemLink;
        //Label type defines the text that goes in the label.
        switch(myLabelType){
        //File name
        case 0:
        myLabel = myLink.name;
        break;
        //File path
        case 1:
        myLabel = myLink.filePath;
        break;
        //XMP description
        case 2:
        try{
        myLabel = myLink.linkXmp.description;
        if(myLabel.replace(/^\s*$/gi, "")==""){
        throw myError;
        catch(myError){
        myLabel = "No description available.";
        break;
        //XMP author
        case 3:
        try{
        myLabel = myLink.linkXmp.author
        throw myError;
        catch(myError){
        myLabel = "No author available.";
        break;
        var myX1 = myFrame.geometricBounds[1];
        var myY1 = myFrame.geometricBounds[2] + myLabelOffset;
        var myX2 = myFrame.geometricBounds[3];
        var myY2 = myY1 + myLabelHeight;
        var myTextFrame = myFrame.parent.textFrames.add(myLabelLayer, undefined, undefined,{geometricBounds:[myY1, myX1, myY2, myX2], contents:myLabel});
        myTextFrame.textFramePreferences.firstBaselineOffset = FirstBaseline.leadingOffset;
        myTextFrame.parentStory.texts.item(0).appliedParagraphStyle = myLabelStyle;
