1 Reply Latest reply on Jan 29, 2015 12:38 PM by A.T. Romano
    making the final DVD
    Littlefeather
      i am using PE  10.  is it o.k. to take my edited timeline directly to DVD or should i save the edited timeline to AVI or Mpeg ffirst and use that in a new Project?
        • 1. Re: making the final DVD
          A.T. Romano Level 7
          Littlefeather
          I would avoid the detours and take your Timeline with or without menus to
          Share
          Disc
          DVD disc
          with the burn preset that is consistent with your project settings...
          So, if you have a 4:3 project, then NTSC_Dolby DVD, and, if you have a 16:9 project, then NTSC_Widescreen_Dolby DVD. Same if PAL setup.
          The only time I burn to folder to get the VIDEO_TS Folder to burn to DVD in ImgBurn is when Premiere Elements does not recognize the burner or the disc.
          Just in case mention...when you export your Timeline to file saved to the computer hard, you cannot create a file with menus saved to the computer hard
          drive. You could take the file into another project, do the menus, and then the burn to disc. Too many steps for me unless I am forced into that workaround because of burn to
          disc problems.
          Please consider.
          Any questions or need clarification, please do not hesitate to ask.
          Thank you.
          ATR
