2 Replies Latest reply on Jan 30, 2015 7:14 AM by brownmc
    Capture a photo from video using Premiere Elements 13?
    brownmc
      How can you export a photo from video using Premiere Elements 13? I am having difficulty finding the function with the latest upgrade.
        • 1. Re: Capture a photo from video using Premiere Elements 13?
          A.T. Romano Level 7
          brownmc
          What computer operating system is involved?
          You should be able to
          In the Expert workspace, move the Timeline Indicator to the frame for the Freeze Frame, then
          Publish+Share
          Computer
          or
          Use the small scroll bar to the right of the Publish+Share/Computer choices, and scroll down to Image which is toward
          the bottom of the Publish+Share/Computer/ choices.
          Also, can be done for insert into Timeline
          Expert workspace
          Tools Menu (at top of workspace) or Tools Tab (at bottom of workspace)
          Freeze Frame
          Above is for one frame at a time. If you go the Publish+Share/Computer/Image way and place a check mark next to Export As Sequence
          in the Advanced export settings, you can actually get a freeze frame for every frame in the video.
          Please review and consider. If any questions or need clarification, please do not hesitate to ask.
          ATR
          • 2. Re: Capture a photo from video using Premiere Elements 13?
            brownmc Level 1
            I am using Windows 7. I will try your suggestions. Thank you!
