1 Reply Latest reply on Feb 23, 2007 7:09 AM by Devendran
    loaded text remains blank...
    lostinscript Level 1
      I am trying to load an external fla that has a textfield in it into a _level0 fla. When i do this, the text field remains blank event though flash has found the files to load, why is this, what am i doing wrong? Flash is finding the files as i have tried calling the textfile to load by a different name and get an error message saying the file cant found. However, when i call the textfile by the correct name (in flash) i have no error messages (just a black text field) so im assuming flash has found the files. Could someone point out what im doing wrong?
      Thanks...
        • 1. Re: loaded text remains blank...
          Devendran Level 1
          Hi Pls check the file format u have used. Try to Create a new TextFile using notepad and Paste your CSS style there. And save it then load your CSS file.
          another thing stylesLV.onload function check if(Success) it should be small as you mentioned in the argument.
          some time if flash can't able to read the file format it will return nothing....
